    I need an explanation of how the magic mirror system works
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    12 Posts 3 Posters 8.6k Views 3 Watching
      sdetweil @aljosie
      @aljosie correct… all in one…
      you can also access the server from a remote system using the same web url address (if permitted)
      some MM implementations also have a single use mode… server only (no ui locally) or client only (no server, just access server).
      MM has all of that
        aljosie @sdetweil
        @sdetweil can u give me link of module for turn on/off light with this smart mirror
          sdetweil @aljosie
          @aljosie sorry… missed ‘this mirror’
          again, using what technology
          PIR (Pi Infrared sensor), camera, voice, ?
          does your monitor support electronic on/off. (mine dont)
          but did u mean room lights? again, these need to be electronically controlled…
          what technology? hue, insteon, wifi (lots of different apis there)
          A 2 Replies Last reply Reply Quote 0
            aljosie @sdetweil
            @sdetweil i’m wanna control light room (turn on/off) with voice comand and i want the comand show on the magic mirror interface, can help me?
              aljosie @sdetweil
              @sdetweil and i want only my voice can execute the comand, and i’m using the beardboard, light indicator and relay for this project, so this project just like for home automation system controlling the light room with voice.
              ejay-ibmE 1 Reply Last reply Reply Quote 0
              • ejay-ibmE Offline
                ejay-ibm Project Sponsor Module Developer @aljosie
                @aljosie You need some philips hue light a philps hue bridge and then you can use MMM-Hue module and see your light status. But you need first to configure your system for google home usage. Then with Mk2 assisant you can request to turn on/ off your lights as the philps hue system is be connected to google home account that you use as well on your miror.
                there’s few setup to make before all works. But I have this at home and it work like a charm .
                Ejay
                  aljosie @ejay-ibm
                  @ejay-ibm can u give me the link tutorial about that?
                  • ejay-ibmE Offline
                    @aljosie thisis the first link I found on google.
                    Their’s tons of doc if you search .
                    https://www.tomsguide.com/us/connect-google-home-philips-hue,review-4217.html
                    Ejay
