    Do you use a PIR sensor? How do you hide it?
    21 Posts 11 Posters 21.8k Views 11 Watching
      boblazer @sdetweil
      @sdetweil said in Do you use a PIR sensor? How do you hide it?:
      maybe you only need 2mm of that to make the sensor work…
      Yeah, that’s my understanding. I can’t find the post but it was here on this site. A guy did some experiments to find the smallest size hole his PIR sensor actually required. He tried 1mm, 2mm and 4mm(?). He said it worked just fine with a 2mm hole.
      yawnsY 1 Reply Last reply
      • yawnsY
        yawns Moderator @boblazer
        @boblazer said in Do you use a PIR sensor? How do you hide it?:
        You are referring to this one: https://forum.magicmirror.builders/topic/557/pir-sensor-behind-glass/33
        B 1 Reply Last reply
        • qu1queQ
          qu1que Project Sponsor
          I’ve made an 8 mm hole, as you can see here:
          https://forum.magicmirror.builders/topic/7263/my-first-smart-mirror-in-a-frame-of-40-x-30-cm-with-raspberry-pi-zero-w/2
            boblazer @yawns
            @yawns Yes! Thanks.
              boblazer @qu1que
              @qu1que Having other lights there like you do makes it fit in a little better. That’s something to think about. Maybe I’m trying to make mine look too old-fashioned.
              • htilburgsH
                htilburgs
                I made a 8 mm hole on the backside and a 2 mm hole on the frontside.
                Removed the cap from the motion sensor and placed it in the 8 mm hole.
                Works great and you can hardly see the 2 mm hole.
                Backside:
                alt text
                Frontside:
                alt text
                (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                  boblazer
                  Nice pic, thanks for showing us how it actually looks.
                  It still bugs me though. Looking at yours I wonder if putting a power light (or something light) next to the PIR hole would make the PIR hole look like less of a forced design choice. You know, it could even be a chiche looking light that blends into the wood and lights up in such a way that it doesn’t make the mirror look tacky and also doesn’t give you the feeling that it’s like a monitor power light.
                  I don’t know what that would look like. Not super bright. Maybe kind of dull but not so dull that it looks weak. Maybe a good complimentary color to the wood. Maybe not a circle or a rectangle but a cool shape like a rhombus. Maybe you could put a logo or text of some sort on the face of the mirror and hide the hole there and it wouldn’t look out of place.
                  • htilburgsH
                    htilburgs
                    I still have to paint the frame, thinking of a kind of ‘white-wash’ so you keep seeing the wood grains. Maybe it’s less ‘obvious’.
                    But you know and I know, but most visitors I’ve had didn’t even see it or looking for it 🤔
                      BluP Project Sponsor @htilburgs
                      @htilburgs
                        BluP Project Sponsor @BluP
                        @BluP said in Do you use a PIR sensor? How do you hide it?:
                        @htilburgs
                        You May also think of some different solution: I‘m using a Hue Motion detector which is in my corridor anyway and controls the MM via MM-remotecontrol using the Http get requests through HomeKit and homebridge
                        • O
                          onkelbobby
                          I did not use PIR sensor because it needs to “see” through the frame. After a little research I found an microwave based motion sensor called
                          RWCL-0516. This tiny PCB works super reliable even though ma 20mm thick wooden frame.
                          • htilburgsH
                            htilburgs
                            @onkelbobby, seems nice for my next mirror ;-)
                            How let you this interact with the Pi and MagicMirror? Is there a module, or do you use a Python script?
                              MadScientist
                              The microwave sensor is compatible with the MMM-PIR-sensor module.
                                boblazer @onkelbobby
                                @onkelbobby It works through 20mm of wood for $3.59!? This seems too good to be true! I ordered one. Might be a week or two before I have a chance to test it out. …Actually shipping on that item is super slow (about a month). Still, I’m holding off on drilling the PIR hole until I can try it out the RWCL-0516.
                                Edit - Found it here for $1. Shipping times are still brutal though unless you pay about $30 for air mail. btw dimensions of the little fella are 35.9 X 17.3mm/1.41 X 0.68inch
                                  MadScientist
                                  I could use mine because it worked through the prick wall behind the mirror.
                                    cyberphox
                                    Hide it? Why it goes in it’s own enclosure of course? :)
                                    • O
                                      onkelbobby
                                      @htilburgs
                                      mine is connected to an Arduino micro 3.3V version and this one is controlling a simple relais switching the monitor inside the mirror. But as @MadScientist already mentioned you can also hook it up to the Raspberry Pi since It works perfectly with MMM-PIR-Sensor.
                                      • A
                                        audreyspency
                                        • G
                                          gismet181
                                          Hi, I’ve been busy with this problem for a long time until I found the solution. And it’s called RCWL-0516 Microwave Radar Sensor. Guys, forget PIR sensor, the RCWL-0516 you can completely obstruct in the frame behind the mirror. It works perfectly with paviro / MMM PIR sensor. You get 5 pieces for 8 € on Amazon. I hope I could help you. And forgive me my bad English. Regards
