    Do you use a PIR sensor? How do you hide it?
    21 Posts 11 Posters 20.6k Views 11 Watching
      boblazer
      Nice pic, thanks for showing us how it actually looks.
      It still bugs me though. Looking at yours I wonder if putting a power light (or something light) next to the PIR hole would make the PIR hole look like less of a forced design choice. You know, it could even be a chiche looking light that blends into the wood and lights up in such a way that it doesn’t make the mirror look tacky and also doesn’t give you the feeling that it’s like a monitor power light.
      I don’t know what that would look like. Not super bright. Maybe kind of dull but not so dull that it looks weak. Maybe a good complimentary color to the wood. Maybe not a circle or a rectangle but a cool shape like a rhombus. Maybe you could put a logo or text of some sort on the face of the mirror and hide the hole there and it wouldn’t look out of place.
      • htilburgsH Offline
        htilburgs
        I still have to paint the frame, thinking of a kind of ‘white-wash’ so you keep seeing the wood grains. Maybe it’s less ‘obvious’.
        But you know and I know, but most visitors I’ve had didn’t even see it or looking for it 🤔
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          BluP Project Sponsor @htilburgs
          @htilburgs
            BluP Project Sponsor @BluP
            @BluP said in Do you use a PIR sensor? How do you hide it?:
            @htilburgs
            You May also think of some different solution: I‘m using a Hue Motion detector which is in my corridor anyway and controls the MM via MM-remotecontrol using the Http get requests through HomeKit and homebridge
            • O Offline
              onkelbobby
              I did not use PIR sensor because it needs to “see” through the frame. After a little research I found an microwave based motion sensor called
              RWCL-0516. This tiny PCB works super reliable even though ma 20mm thick wooden frame.
                htilburgs
                @onkelbobby, seems nice for my next mirror ;-)
                How let you this interact with the Pi and MagicMirror? Is there a module, or do you use a Python script?
                  MadScientist
                  The microwave sensor is compatible with the MMM-PIR-sensor module.
                    boblazer @onkelbobby
                    @onkelbobby It works through 20mm of wood for $3.59!? This seems too good to be true! I ordered one. Might be a week or two before I have a chance to test it out. …Actually shipping on that item is super slow (about a month). Still, I’m holding off on drilling the PIR hole until I can try it out the RWCL-0516.
                    Edit - Found it here for $1. Shipping times are still brutal though unless you pay about $30 for air mail. btw dimensions of the little fella are 35.9 X 17.3mm/1.41 X 0.68inch
                      MadScientist
                      I could use mine because it worked through the prick wall behind the mirror.
                        cyberphox
                        Hide it? Why it goes in it’s own enclosure of course? :)
                        • O Offline
                          onkelbobby
                          @htilburgs
                          mine is connected to an Arduino micro 3.3V version and this one is controlling a simple relais switching the monitor inside the mirror. But as @MadScientist already mentioned you can also hook it up to the Raspberry Pi since It works perfectly with MMM-PIR-Sensor.
                            audreyspency
                            Yeah, that’s my understanding. I can’t find the post but it was here on this site. A guy did some experiments to find the smallest size hole his PIR sensor actually required. He tried 1mm, 2mm and 4mm(?). He said it worked just fine with a 2mm hole.
                            • G Offline
                              gismet181
                              Hi, I’ve been busy with this problem for a long time until I found the solution. And it’s called RCWL-0516 Microwave Radar Sensor. Guys, forget PIR sensor, the RCWL-0516 you can completely obstruct in the frame behind the mirror. It works perfectly with paviro / MMM PIR sensor. You get 5 pieces for 8 € on Amazon. I hope I could help you. And forgive me my bad English. Regards
