    Do you use a PIR sensor? How do you hide it?
    21 Posts 11 Posters 21.8k Views 11 Watching
      BluP Project Sponsor @htilburgs
      @htilburgs
      B 1 Reply Last reply
        BluP Project Sponsor @BluP
        @BluP said in Do you use a PIR sensor? How do you hide it?:
        @htilburgs
        You May also think of some different solution: I‘m using a Hue Motion detector which is in my corridor anyway and controls the MM via MM-remotecontrol using the Http get requests through HomeKit and homebridge
        • O
          onkelbobby
          I did not use PIR sensor because it needs to “see” through the frame. After a little research I found an microwave based motion sensor called
          RWCL-0516. This tiny PCB works super reliable even though ma 20mm thick wooden frame.
          • htilburgsH
            htilburgs
            @onkelbobby, seems nice for my next mirror ;-)
            How let you this interact with the Pi and MagicMirror? Is there a module, or do you use a Python script?
            (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
              MadScientist
              The microwave sensor is compatible with the MMM-PIR-sensor module.
                boblazer @onkelbobby
                @onkelbobby It works through 20mm of wood for $3.59!? This seems too good to be true! I ordered one. Might be a week or two before I have a chance to test it out. …Actually shipping on that item is super slow (about a month). Still, I’m holding off on drilling the PIR hole until I can try it out the RWCL-0516.
                Edit - Found it here for $1. Shipping times are still brutal though unless you pay about $30 for air mail. btw dimensions of the little fella are 35.9 X 17.3mm/1.41 X 0.68inch
                  MadScientist
                  I could use mine because it worked through the prick wall behind the mirror.
                    cyberphox
                    Hide it? Why it goes in it’s own enclosure of course? :)
                    • O
                      onkelbobby
                      @htilburgs
                      mine is connected to an Arduino micro 3.3V version and this one is controlling a simple relais switching the monitor inside the mirror. But as @MadScientist already mentioned you can also hook it up to the Raspberry Pi since It works perfectly with MMM-PIR-Sensor.
                      • A
                        audreyspency
                        Yeah, that’s my understanding. I can’t find the post but it was here on this site. A guy did some experiments to find the smallest size hole his PIR sensor actually required. He tried 1mm, 2mm and 4mm(?). He said it worked just fine with a 2mm hole.
                        • G
                          gismet181
                          Hi, I’ve been busy with this problem for a long time until I found the solution. And it’s called RCWL-0516 Microwave Radar Sensor. Guys, forget PIR sensor, the RCWL-0516 you can completely obstruct in the frame behind the mirror. It works perfectly with paviro / MMM PIR sensor. You get 5 pieces for 8 € on Amazon. I hope I could help you. And forgive me my bad English. Regards
