    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 288.8k Views 35 Watching
    • lavolp3L
      lavolp3 Module Developer @ianperrin
      @ianperrin Table mode doesn’t seem to rotate the actual data into monthly data for me. I have done a run of 6.4 km on Tuesday. But much more in Jan and Feb :-)
      Can you confirm that?
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • I
        ianperrin @lavolp3
        @lavolp3 said in MMM-Strava:
        Hi @lavolp3 - can you post your config for the module and if possible the output from the log?
        “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
        • lavolp3L
          @ianperrin said in MMM-Strava:
          rom the log?
          My config:
                  //disabled: true,
                  module: 'MMM-Strava',
                  position: 'bottom_right',
                      client_id: "2xxxx",
                      client_secret: "9bdxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                      // strava_id: '23128899',
                      // access_token: 'af1a3e4xxxxxxxxxxxxxxxxxxxxxxxxxxxx',
                      // period: 'recent',
                      auto_rotate: true,
                      animationSpeed: 0,
                      mode: "chart",
                      debug: true
          Regarding logs: This comes from the developer’s tab:
          Load script: modules/MMM-Strava//MMM-Strava.js loader.js:182:4
          Check MagicMirror version for module 'MMM-Strava' - Minimum version:  2.2.0 - Current version: 2.6.0 module.js:469:3
          Module registered: MMM-Strava module.js:477:2
          Bootstrapping module: MMM-Strava loader.js:152:3
          Scripts loaded for: MMM-Strava loader.js:157:4
          Load stylesheet: modules/MMM-Strava/MMM-Strava.css loader.js:197:4
          Styles loaded for: MMM-Strava loader.js:159:5
          MMM-Strava - Load translation: translations/de.json translator.js:172:5
          MMM-Strava - Load translation fallback: translations/en.json translator.js:174:5
          Translations loaded for: MMM-Strava loader.js:161:6
          Starting module: MMM-Strava MMM-Strava.js:114:9
          MMM-Strava received a system notification: ALL_MODULES_STARTED module.js:156:4
          MMM-Strava received a system notification: MODULE_DOM_CREATED module.js:156:4
          MMM-Strava received a system notification: DOM_OBJECTS_CREATED module.js:156:4
          MMM-Strava: "Receiving notification: DATA for module_25_MMM-Strava" MMM-Strava.js:201:13
          MMM-Strava received a module notification: DARK_SKY_FORECAST_WEATHER_UPDATE from sender: MMM-DarkSkyForecast
          npm start dev does only give me:
          MMM-Strava: "Received notification: SET_CONFIG"
          • I
            ianperrin @lavolp3
            @lavolp3 - thanks and good spot. Currently rotation is only supported for table mode. I’ve pushed a fix to the develop branch to enforce this behaviour. Please use git pull to get and test the changes.
            • lavolp3L
              @ianperrin Confirmed! Chart is not rotating anymore.
              However it might be worth to think about several rotating charts. Like for weekdays and a range of several months?
              • I
                ianperrin @lavolp3
                @ianperrin … it might be worth to think about several rotating charts. Like for weekdays and a range of several months?
                Good idea, could you add it as an issue in the Github repository so I don’t forget it?
                • H
                  hattlegr @ianperrin
                  @ianperrin I too am stuck on the authorization; I am not sure where to get a valid “web address” and “call back domain “ from to complete the API Application on the strava site To obtain my client ID and client secret numbers The local Host:8080/MMM-Strava/auto does bring up the same screen you posted, but the authorization process fails, I presume because I don’t have the correct client information.
                  I lavolp3L 2 Replies Last reply Reply Quote 0
                  • I
                    ianperrin @hattlegr
                    @hattlegr thanks for testing and sorry to hear you’re having issues. Perhaps you can post your config and any logs from the mirror.
                    • H
                      hattlegr @ianperrin
                      @ianperrin
                      Here is my config file
                      			module: "MMM-Strava",
                      			position:  "bottom_right",
                      				client_id: "6054923"
                      				// client_secret: "tokin"
                      I got my client ID using the last series of numbers from the Strava URL after I log in.
                      I am not sure how to get through the Strava API application. to get client secret code.
                      Here is the error i get after running authorise from my localhost:8080 URL
                      {"message":"Bad Request","errors":[{"resource":"Application","field":"client_id","code":"invalid"}]}
                      • lavolp3L
                        lavolp3 Module Developer @hattlegr
                        @hattlegr said in MMM-Strava:
                        On your personal Strava API website (strava.com/settings/api), you need to set a “callback domain” for your project. What did you set?
                        • H
                          hattlegr @lavolp3
                          @lavolp3 I am not sure how to setup a call back domain.
                          • lavolp3L
                            @hattlegr You need to create an application in your strava account to use this module. Have you done that?
                            1. Go to www.strava.com/settings/api
                            2. Create an application. As far as I understand the only really important value is the callback domain. I GUESS (!!) this would need to be http://localhost OR the hostname (or IP) of your magicmirror, something like http://magicmirror
                            3. Then you get a client secret and access token, which you need for the further procedure.
                            • I
                              ianperrin @lavolp3
                              The easiest way to authorise the module is
                              1. On the My API Application page update the application by entering localhost as the callback domain.
                              2. Once the Strava API application is updated, copy the client id and client secret from the same page, then use these to update the module configuration in the config.js file and restart the Magic Mirror.
                              3. Finally, on the Pi itself, browse to http://localhost:8080/MMM-Strava/auth/ and follow the steps.
                              If it helps, here are the settings I’ve been using to test the module:
                              • H
                                hattlegr @ianperrin
                                @ianperrin The description above is very good and I have successfully got through this process.
                                I have added my new Client ID and Client-secret to the config file.
                                When I run my magicmirror I am asked to follow link to strava/auth.
                                I am able to select the module and click the authorize button. This brings me to an the authorize page with the three check boxes as described, when I click on the authorize button it brings me to the Stava login page. I am able to login, but the screen takes me to my dashboard page. with no home / back / close buttons. (it replaces the MM page). So I can’t get out of this stage.
                                Out of interest, I tried opening a browser using localhost:8080 once MM is running and get the same screen. When I click on the authorize button in the browser environment the process works fine and I am eventually taken back to the MM page and the strava data is working. However, when I shut down and star again the authorization is forgotten.
                                • I
                                  ianperrin @hattlegr
                                  @hattlegr okay so we’re making progress. What is the output in the log file or the debug console in the browser? Once you’ve authorised the module, was a tokens.json file created in the MMM-Strava module folder?
                                  • H
                                    hattlegr @ianperrin
                                    @ianperrin No, there is no file called tokens.json
                                    • I
                                      ianperrin @hattlegr
                                      @hattlegr how about the logs or debug console?
                                      H 2 Replies Last reply Reply Quote 0
                                      • H
                                        hattlegr @ianperrin
                                        @ianperrin Sorry, I can’t find any logs or sure what a debug console is.
                                        • I
                                          ianperrin @hattlegr
                                          @hattlegr okay, so the Magic Mirror creates logs in two places.
                                          1. On the Pi itself. If you use pm2 to start your mirror, these can be viewed by running pm2 logs mm
                                          2. In the browser console. These can be viewed in the browser’s Developer Tools (usually activated by CTRL-SHIFT-i).
                                          Let us know what you find.
                                          • H
                                            hattlegr @ianperrin
                                            @ianperrin Here is the log after installing --production.
                                            1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'install', '--production' ]
                                            2 info using npm@5.6.0
                                            3 info using node@v9.11.2
                                            4 verbose npm-session 72bb8575f86ed6c8
                                            5 silly install runPreinstallTopLevelLifecycles
                                            6 silly preinstall MMM-Strava@2.0.0-BETA
                                            7 info lifecycle MMM-Strava@2.0.0-BETA~preinstall: MMM-Strava@2.0.0-BETA
                                            8 silly install loadCurrentTree
                                            9 silly install readLocalPackageData
                                            10 silly install loadIdealTree
                                            11 silly install cloneCurrentTreeToIdealTree
                                            12 silly install loadShrinkwrap
                                            13 silly saveTree MMM-Strava@2.0.0-BETA
                                            14 verbose stack SyntaxError: Unexpected token < in JSON at position 9216
                                            14 verbose stack     at JSON.parse (<anonymous>)
                                            14 verbose stack     at module.exports (/usr/lib/node_modules/npm/lib/utils/parse-json.js:3:15)
                                            14 verbose stack     at BB.join (/usr/lib/node_modules/npm/lib/install/read-shrinkwrap.js:31:20)
                                            14 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
                                            14 verbose stack     at Holder$3._callFunction (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:14:44)
                                            14 verbose stack     at Holder$3.checkFulfillment (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:29:30)
                                            14 verbose stack     at Promise.eval (eval at thenCallback (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:14:16), <anonymous>:6:20)
                                            14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:566:21)
                                            14 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
                                            14 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:693:18)
                                            14 verbose stack     at Promise._fulfill (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:638:18)
                                            14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:582:21)
                                            14 verbose stack     at /usr/lib/node_modules/npm/node_modules/bluebird/js/release/nodeback.js:42:21
                                            15 verbose cwd /home/pi/MagicMirror/modules/mmm-strava
                                            16 verbose Linux 4.9.80-v7+
                                            17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "--production"
                                            18 verbose node v9.11.2
                                            19 verbose npm  v5.6.0
                                            20 error Unexpected token < in JSON at position 9216
                                            21 verbose exit [ 1, true ]
                                            • 3 / 7
