    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 288.8k Views 35 Watching
    • H
      hattlegr @ianperrin
      @ianperrin I too am stuck on the authorization; I am not sure where to get a valid “web address” and “call back domain “ from to complete the API Application on the strava site To obtain my client ID and client secret numbers The local Host:8080/MMM-Strava/auto does bring up the same screen you posted, but the authorization process fails, I presume because I don’t have the correct client information.
      I lavolp3L 2 Replies Last reply Reply Quote 0
      • I
        ianperrin @hattlegr
        @hattlegr thanks for testing and sorry to hear you’re having issues. Perhaps you can post your config and any logs from the mirror.
        “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
        • H
          hattlegr @ianperrin
          @ianperrin
          Here is my config file
          			module: "MMM-Strava",
          			position:  "bottom_right",
          				client_id: "6054923"
          				// client_secret: "tokin"
          I got my client ID using the last series of numbers from the Strava URL after I log in.
          I am not sure how to get through the Strava API application. to get client secret code.
          Here is the error i get after running authorise from my localhost:8080 URL
          {"message":"Bad Request","errors":[{"resource":"Application","field":"client_id","code":"invalid"}]}
          • lavolp3L
            lavolp3 Module Developer @hattlegr
            @hattlegr said in MMM-Strava:
            On your personal Strava API website (strava.com/settings/api), you need to set a “callback domain” for your project. What did you set?
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • H
              hattlegr @lavolp3
              @lavolp3 I am not sure how to setup a call back domain.
              • lavolp3L
                @hattlegr You need to create an application in your strava account to use this module. Have you done that?
                1. Go to www.strava.com/settings/api
                2. Create an application. As far as I understand the only really important value is the callback domain. I GUESS (!!) this would need to be http://localhost OR the hostname (or IP) of your magicmirror, something like http://magicmirror
                3. Then you get a client secret and access token, which you need for the further procedure.
                • I
                  ianperrin @lavolp3
                  @lavolp3 said in MMM-Strava:
                  The easiest way to authorise the module is
                  1. On the My API Application page update the application by entering localhost as the callback domain.
                  2. Once the Strava API application is updated, copy the client id and client secret from the same page, then use these to update the module configuration in the config.js file and restart the Magic Mirror.
                  3. Finally, on the Pi itself, browse to http://localhost:8080/MMM-Strava/auth/ and follow the steps.
                  If it helps, here are the settings I’ve been using to test the module:
                  • H
                    hattlegr @ianperrin
                    @ianperrin The description above is very good and I have successfully got through this process.
                    I have added my new Client ID and Client-secret to the config file.
                    When I run my magicmirror I am asked to follow link to strava/auth.
                    I am able to select the module and click the authorize button. This brings me to an the authorize page with the three check boxes as described, when I click on the authorize button it brings me to the Stava login page. I am able to login, but the screen takes me to my dashboard page. with no home / back / close buttons. (it replaces the MM page). So I can’t get out of this stage.
                    Out of interest, I tried opening a browser using localhost:8080 once MM is running and get the same screen. When I click on the authorize button in the browser environment the process works fine and I am eventually taken back to the MM page and the strava data is working. However, when I shut down and star again the authorization is forgotten.
                    • I
                      ianperrin @hattlegr
                      @hattlegr okay so we’re making progress. What is the output in the log file or the debug console in the browser? Once you’ve authorised the module, was a tokens.json file created in the MMM-Strava module folder?
                      • H
                        hattlegr @ianperrin
                        @ianperrin No, there is no file called tokens.json
                        • I
                          ianperrin @hattlegr
                          @hattlegr how about the logs or debug console?
                          H 2 Replies Last reply Reply Quote 0
                          • H
                            hattlegr @ianperrin
                            @ianperrin Sorry, I can’t find any logs or sure what a debug console is.
                            • I
                              ianperrin @hattlegr
                              @hattlegr okay, so the Magic Mirror creates logs in two places.
                              1. On the Pi itself. If you use pm2 to start your mirror, these can be viewed by running pm2 logs mm
                              2. In the browser console. These can be viewed in the browser’s Developer Tools (usually activated by CTRL-SHIFT-i).
                              Let us know what you find.
                              • H
                                hattlegr @ianperrin
                                @ianperrin Here is the log after installing --production.
                                1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'install', '--production' ]
                                2 info using npm@5.6.0
                                3 info using node@v9.11.2
                                4 verbose npm-session 72bb8575f86ed6c8
                                5 silly install runPreinstallTopLevelLifecycles
                                6 silly preinstall MMM-Strava@2.0.0-BETA
                                7 info lifecycle MMM-Strava@2.0.0-BETA~preinstall: MMM-Strava@2.0.0-BETA
                                8 silly install loadCurrentTree
                                9 silly install readLocalPackageData
                                10 silly install loadIdealTree
                                11 silly install cloneCurrentTreeToIdealTree
                                12 silly install loadShrinkwrap
                                13 silly saveTree MMM-Strava@2.0.0-BETA
                                14 verbose stack SyntaxError: Unexpected token < in JSON at position 9216
                                14 verbose stack     at JSON.parse (<anonymous>)
                                14 verbose stack     at module.exports (/usr/lib/node_modules/npm/lib/utils/parse-json.js:3:15)
                                14 verbose stack     at BB.join (/usr/lib/node_modules/npm/lib/install/read-shrinkwrap.js:31:20)
                                14 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
                                14 verbose stack     at Holder$3._callFunction (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:14:44)
                                14 verbose stack     at Holder$3.checkFulfillment (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:29:30)
                                14 verbose stack     at Promise.eval (eval at thenCallback (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:14:16), <anonymous>:6:20)
                                14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:566:21)
                                14 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
                                14 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:693:18)
                                14 verbose stack     at Promise._fulfill (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:638:18)
                                14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:582:21)
                                14 verbose stack     at /usr/lib/node_modules/npm/node_modules/bluebird/js/release/nodeback.js:42:21
                                15 verbose cwd /home/pi/MagicMirror/modules/mmm-strava
                                16 verbose Linux 4.9.80-v7+
                                17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "--production"
                                18 verbose node v9.11.2
                                19 verbose npm  v5.6.0
                                20 error Unexpected token < in JSON at position 9216
                                21 verbose exit [ 1, true ]
                                • H
                                  hattlegr @hattlegr
                                  @hattlegr Note the error on line 20 related to a token which could be a possible reason MM does not remember the authorization.
                                  • I
                                    ianperrin @hattlegr
                                    @hattlegr it sounds like you’ve got at least a couple of issues here. One relating to the install of the module and another related to the authorisation process. Let’s take them one at a time.
                                    What command are you running to install the module and which directory are you in at the time?
                                    • H
                                      hattlegr @ianperrin
                                      @ianperrin I went right back to the beginning and started the installation again to ensure I save each step.
                                      During the process I picked up on an error I did not follow up on. After installing --production I had to run ‘npm audit fix’
                                      After running this I tried the authentication again. This time the process did add the token.js file to the MMM=Strava module.
                                      I believe it is working now. I have logged off and rebooted to confirm and the Strava module was working correctly.
                                      pi@raspberrypi:~/MagicMirror/modules/MMM-Strava $ git checkout develop && git pull
                                      Branch develop set up to track remote branch develop from origin.
                                      Switched to a new branch 'develop'
                                      Already up-to-date.
                                      pi@raspberrypi:~/MagicMirror/modules/MMM-Strava $ npm install --production
                                      npm WARN conflict A git conflict was detected in package-lock.json. Attempting to auto-resolve.
                                      npm WARN conflict To make this happen automatically on git rebase/merge, consider using the npm-merge-driver:
                                      npm WARN conflict $ npx npm-merge-driver install -g
                                      npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
                                      added 55 packages from 67 contributors and audited 3075 packages in 32.396s
                                      found 1 moderate severity vulnerability
                                        run `npm audit fix` to fix them, or `npm audit` for details // Was important to run this command to make authentication process work correctly
                                      pi@raspberrypi:~/MagicMirror/modules/MMM-Strava $ npm audit fix
                                      added 537 packages from 583 contributors in 92.726s
                                      fixed 1 of 1 vulnerability in 3075 scanned packages
                                                             === npm audit security report ===
                                      found 0 vulnerabilities
                                      // Config
                                      			position:  "center",
                                      				client_id: "3---6",
                                      				client_secret: "f22b--------------------0d9f7",
                                      				mode: "chart",
                                      				auto_rotate: "true",
                                      				units: "imperial"
                                      • lavolp3L
                                        lavolp3 Module Developer @ianperrin
                                        @ianperrin said in MMM-Strava:
                                        @zerodegree79 , @Val07300, @ctatos (and others I may have missed).
                                        A new (beta) version of the module with support for Strava’s new authentication flow is available.
                                        Just wanted to report that the module is working fine until now using the development branch.
                                        What I would like to implement is some kind of a record panel showing the fastest 1k, 5k, 10k for running 20k, 40k, for cycling etc.
                                        I can’t see this in the API. Does anyone know a way to extract these values?
                                        • L
                                          Lorenz
                                          When i use the new development branch the api for profile switcher isn’t working anymore. (the notification from MMM-Remote to be exact)
                                          • lavolp3L
                                            Hi all, Hi @ianperrin
                                            I love hunting for segments and for that I would like to include some kind of “crown board” calculating golden, silver and bronze crowns for first, second and third places in segments.
                                            At a later stage I can imagine including more information, e.g. some kind of notification if you lose a first pace to someone else.
                                            However, it’s not easy to get these numbers via the API.
                                            So, to summarise: I need the count of podium places for segments in running and cycling. These can change over time! So need to be checked and counted regularly.
                                            For these I need all segments the athlete has competed in.
                                            My approach would be:
                                            Go through ALL activities, pick segment ID’s, combine these and search through each segment leaderboard for the athlete’s name.
                                            However, this would be a LOT of API calls. And these are limited to 600 in 15 min. With a few hundred activities these can be exceed easily.
                                            So the call would somehow need to be stretched and used not with every other call.
                                            Any other ideas or input for this idea?
                                            Thanks for every input, as always!
                                            • 3 / 7
