    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 911.6k Views 74 Watching
    • Cr4z33C Offline
      Cr4z33 @epi
      @epi said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
      1. “Feels like”
      Indeed comes very handy to me when in Summer.
      The weather here is usually very wet and in Summer ie. 35° C give a feeling of 42° C so I wish I could know it before getting out. :sun: :fire:
      E 1 Reply Last reply Reply Quote 1
        j.e.f.f Project Sponsor Module Developer @mielu80
        @mielu80 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
        I’ve installed this weather module and I find it very nice but I have a little issue with it,a strange character like a rectangle appear in front of the temperature value.
        I’ve just tried with your config and I can’t duplicate this problem. That said, when I inspect that part of the screen with the dev tools, it looks like there is an extra character there, but in my case it just appears as white space. But there’s nothing I can see in the markup where this is…
        M E S 3 Replies Last reply Reply Quote 0
        • E Offline
          epi @Cr4z33
          @Cr4z33 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
          1. “Feels like”
          Its the opposite in Latvia - due to cold weather and wind, taking into consideration that the sea is very close, even -1 Celsius might feel like -7.
            chris1971
            Oh my god… everything was running and I have shoot the system…and try to install it again.
            Now the module is not loading anymore. here is my config:
            module: “MMM-DarkSkyForecast”,
            header: “Wetter in Mülheim”,
            position: “top_right”,
            classes: “default everyone”,
            disabled: false,
            apikey: “xxxxxxxxxxxxxxxxxxxx”,
            latitude: “51.4185682”,
            longitude: “6.8845226”,
            iconset: “3c”,
            maxHourliesToShow: 4,
            maxDailiesToShow: 4,
            useAnimatedIcons: true,
            label_timeFormat: “k[h]”,
            concise: false,
            forecastLayout: “table”
            Do you see any problems? I only see in the top right region “Weeter in Mülheim” and Loading… but the module isn’t running…
            Please advise - Thanks, Chris
            • O Offline
              onkelbobby
              I implemented this fantastic Modus and it integrates almost seamlessly into our existing mirror layout. To make it perfect I need to reduce the gap between the time and the icon as wells between the day and the icon (yellow arrows). and also between the individual block’s (arrows in red)
              I know that I have to modify the .css file can someone give me a hint what would be the correct values to be changed?
              • Cr4z33C Offline
                Cr4z33 @chris1971
                @chris1971 maybe the API key has expired or has been blacklisted?
                I had this issue 1 month ago and using another API key solved the issue. :)
                  mielu80 @j.e.f.f
                  @j-e-f-f
                  Hello j.e.f.f,
                  Thank you for your update about this issue.
                  I did try another thing:
                  -I’ve commented out my whole config for DarkSkyForecast module
                  -copied the default config from module’s github and pasted it my config file from MM
                  -restarted MM
                  Unfortunately the result is the same,still had that odd character even with the default config for this module.
                  Thank you very much for your effort.
                    chris1971 @Cr4z33
                    @Cr4z33 - Thx - I tried a new API and the module is running. Does anybody know how to minimize the font size in the module. Especially in the tiled view?
                    • O Offline
                      onkelbobby
                      Minimizing to font size should not be a big thing. If you open the module specific css file you an search for font and play with the values in that section. Note that you need to restart MM after saving the modified css file.
                        chris1971
                        how can I delete the 2 lines in the forecast?
                          surger13 Project Sponsor @chris1971
                          @chris1971
                          concise: true,
                          Hello, Chris,
                          you can set concise: true. Then wind direction and speed are gone. Unfortunately also with the current weather.
                          My wish would also be that wind direction and wind speed can only be displayed for the current weather. Does anyone know a solution for this?
                          Greetings
                            chris1971
                            The crazy situation is, that I have done it before… after a crash I had to config the system again, but I do not know how I have done this in the past. My backup didn’t work and the file was corrupt… :-(
                            This is the design I would like to have again.
                              I hope so, too. Just like on your picture I would configure it for myself.
                              • O Offline
                                onkelbobby
                                @chris1971
                                if you just wanna remove the wind in the forecast tile try to add that line in MMM_DarkSkyForecast.css
                                .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .wind-container{
                                  display: none;
                                of course it makes sense to remove the existing line before
                                hope this helps
                                • E Offline
                                  evil_gusgus @j.e.f.f
                                  @j-e-f-f
                                  Hey there, I’ve also run into this issue. Not sure if anyone has made any progress on it?
                                    sdetweil @j.e.f.f
                                    @j-e-f-f this looks like a null character before some translation…
                                    I think it is caused by this line of code in MMM-DarkSkyForecast.js
                                            animatedIconId: this.config.useAnimatedIcons ? this.getAnimatedIconId() : null,
                                    and I think the template check has failed
                                              {% if forecast.currently.animatedIconId %}
                                      pugsly
                                      Trying to find out how to remove this spacing circled in RED.
                                      lavolp3L J 2 Replies Last reply Reply Quote 0
                                        mydiva
                                        Hi all, why my day forecast jambs to the hourly forecast? This happens not always just rendemly?0_1553890445243_49a02d18-cc4e-40b9-85f4-336acfe0f773.jpg image url)
                                        • lavolp3L Offline
                                          lavolp3 Module Developer @pugsly
                                          @pugsly You can check out the css of the part using the developer’s tools of your browser.
                                          The css properties can then be switched on and off and with that you can find out what is responsible for the space.
                                          I would guess your module has become broader due to another module. The forecast part, however, seems to have a fixed width and is aligned left. Then you get an empty space on the right.
                                          How to troubleshoot modules
                                          MMM-soccer v2, MMM-AVStock
                                          • lavolp3L Offline
                                            lavolp3 Module Developer @mydiva
                                            @mydiva The width of your module seems to have become so big that the daily forecast slips into hourly line. I would suggest to set a fixed width for this part or control the width of the other module influencing this.
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
