    pm2 Error auto starting
    5 Posts 3 Posters 1.8k Views 3 Watching
    • Q Offline
      qqqqqqqq
      I’ve followed all the instructions mentioned here
      This is the error that I’m facing
      pi@raspberrypi:~ $ pm2 start mm.sh
      [PM2] Applying action restartProcessId on app [mm](ids: 0)
      [PM2] [mm](0) ✓
      [PM2] Process successfully started
      │ Name │ id │ mode │ status  │ ↺   │ cpu │ memory │
      │ mm   │ 0  │ fork │ stopped │ 136 │ 0%  │ 0 B    │
       Use `pm2 show <id|name>` to get more details about an app
      pi@raspberrypi:~ $ pm2 logs mm
      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
      0|mm       | bash: /home/pi/mm.sh: Permission denied
      ^C
      pi@raspberrypi:~ $
        sdetweil @qqqqqqqq
        @qqqqqqqq
        mm.sh is not marked executable at all or for the user trying to execute it…
        to make it executable for the user… but not any other user
        use the command
        chmod 766  /home/pi/mm.sh
        to make it executable by ANY user (root/pi/…)
        do
        chmod +x /home/pi/mm.sh
        Q 1 Reply Last reply Reply Quote 0
        • Q Offline
          qqqqqqqq @sdetweil
          @sdetweil said in pm2 Error auto starting:
          @qqqqqqqq
          use the command
          do
          Thanks! Worked perfectly.
          But I wonder why it didn’t give mm.sh the permission when i used the command.
          chmod +x mm.sh
            sdetweil @qqqqqqqq
            @qqqqqqqq said in pm2 Error auto starting:
            what folder where u in at the time you issued the chmod +x mm.sh?
            if MagicMirror , then it would have failed… should have given and error
            • ejay-ibmE Offline
              ejay-ibm Project Sponsor Module Developer
              I would say is more ‘sure’ when you are in the right folder to do :
              sudo chmod +x ./mm.sh
