    [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates
    76 Posts 13 Posters 77.3k Views 13 Watching
      sdetweil @swvalenti
      @swvalenti the master repo has master and develop as branches
        shbatm Module Developer @Cr4z33
        @cr4z33 try adding them using the customCommands config setting (see the develop branch README.
        Cr4z33C 2 Replies Last reply Reply Quote 0
        • Cr4z33C Offline
          Cr4z33 @shbatm
          @shbatm OK thanks I will try that tomorrow.
          • Cr4z33C Offline
            Cr4z33 @shbatm
            @shbatm said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
            I set the dev branch module like the following:
            			module: 'MMM-Remote-Control',
            			disabled: false,
            			customCommand: {
            					monitorOnCommand: 'echo on 0 | cec-client -s -d 1',
            					monitorOffCommand: 'echo standby 0 | cec-client -s -d 1',
            					monitorStatusCommand: 'echo pow 0 | cec-client -s -d 1'
            None of the commands are working. :confused_face:
            I get the ‘Done’ message, but then nothing happens…
            The syntax is 100% correct and working if used in the terminal.
              mohace
              Hi, I can’t see newsfeed options in Module Controls.
              Can you help me please?
              • Cr4z33C Offline
                Cr4z33 @mohace
                @mohace I can.
                Double check if you edited anything or try deleting and reinstalling the module?
                  bolish
                  Hi @shbatm
                  I already asked this question on git issues on Jopyth’s version but I just figured out that you are the guy behind the custom menu!
                  Would it be possible to have an action item for a menu?
                  I mean, when you click on the menu, it opens the menu but also as the ability to trigger an action.
                  Regards
                    bolish @Cr4z33
                    @Cr4z33
                    Please check the output of echo pow when your screen is on and off.
                    The original setting related to screen status into the node.js was NOK for me. (indeed, it is something like “ON” / “OFF” / “HDMI” etc…) but my TV was answering with “power status: on” and “power status: standby”.
                    So I had to modify line 610 and 620 with my own.
                    BTW, @shbatm , would be better if those parameters could be configurable also.
                    Regards
                      mohace @Cr4z33
                      @Cr4z33 said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                      @mohace I can.
                      I meant not in that menu but in
                      alt text
                      • Cr4z33C Offline
                        Cr4z33 @bolish
                        @bolish OK, but you have to tell me how to do it. :smiling_face_with_open_mouth_cold_sweat:
                        By the way I have problems turning on and off my TV too.
                        Even if I edited files to enter the needed CEC commands somehow it doesn’t work (same commands in terminal work fine).
                        @mohace huh?
                        I don’t have those menu’s entries at all.
                        Are you using a custom version of the module or? :confused_face:
                          bolish
                          @Cr4z33
                          Make trials with your terminal :
                          • Turn screen on by pasting that in your terminal : echo on 0 | cec-client -s -d 1
                          • Check the feedback status sent by the TV by putting that in terminal : echo pow 0 | cec-client -s -d 1
                          • Remind the result
                          Do exactly the same with turn off :
                          • Turn screen on by pasting that in your terminal : echo standby 0 | cec-client -s -d 1
                          • Remind the result
                          The 2 results you will get should be updated in node.js line 610 / 620.
                          • Cr4z33C Offline
                            Cr4z33 @bolish
                            @bolish as I wrote before that’s EXACTLY what I already did. ;)
                            Terminal commands work straight away while the same commands in MMM-Remote-Control have no effect when used by tapping the buttons in the menu.
                              bolish
                              @Cr4z33
                              So, the ouput you got in the terminal by sending the “pow 0” command is in line with what is written into node helper.js line 610 / 620?
                              • Cr4z33C Offline
                                Cr4z33 @bolish
                                @bolish yep 100% that’s why I tried reporting that to @shbatm , but he didn’t reply about that yet. :grimacing_face:
                                  bolish
                                  @Cr4z33
                                  Strange, it worked for me… FMI, what output do you get in the terminal with “echo pow 0 | cec-client -s -d 1”.
                                  When the screen is ON? When the screen is “OFF”?
                                  • Cr4z33C Offline
                                    Cr4z33 @bolish
                                    @bolish depending wheter the TV is on or off it says power status: on or power status: standby.
                                      bolish
                                      @Cr4z33 same as me…let’s try to cross check our node helper .js to see if they are written the same on line 610 and 620.
                                      • Cr4z33C Offline
                                        Cr4z33 @bolish
                                        @bolish wait cannot remember if I am using perhaps the developer version, but line numbers are different.
                                        Mine are 601 (on), 604 (off) and 607 (status).
                                          bolish
                                          This is what I did on my side :
                                                      if (["MONITORTOGGLE", "MONITORSTATUS", "MONITORON"].indexOf(action) !== -1) {
                                                          screenStatus = exec(monitorStatusCommand, opts, (error, stdout, stderr) => {
                                                              if (stdout.indexOf("TV is off") !== -1 || stdout.indexOf("false") !== -1) { // REPLACE "TV is off" or "false" by "power status: standby"
        // Screen is OFF, turn it ON
        status = "off";
        if (action === "MONITORTOGGLE" || action === "MONITORON") {
        exec(monitorOnCommand, opts, (error, stdout, stderr) => {
        this.checkForExecError(error, stdout, stderr, res, { monitor: "on" });
        this.sendSocketNotification("USER_PRESENCE", true);
        return;
                                                              } else if (stdout.indexOf("HDMI") !== -1 || stdout.indexOf("true") !== -1) { // REPLACE "HDMI" OR "true" by "power status: on"
        // Screen is ON, turn it OFF
        status = "on";
        if (action === "MONITORTOGGLE") {
        this.monitorControl("MONITOROFF", opts, res);
        return;
                                          At least this is what worked for me.
                                          • Cr4z33C Offline
                                            Cr4z33 @bolish
                                            @bolish what about the previous lines?
                                            I thought that was the part to edit by replacing monitor commands with HDMI CEC ones like mines?
                                                    monitorControl: function(action, opts, res) {
                                                        let status = "unknown";
                                                        let monitorOnCommand = (this.initialized && "monitorOnCommand" in this.thisConfig.customCommand) ?
                                                            this.thisConfig.customCommand.monitorOnCommand :
                                                            "echo on 0 | cec-client -s -d 1";
                                                        let monitorOffCommand = (this.initialized && "monitorOffCommand" in this.thisConfig.customCommand) ?
                                                            this.thisConfig.customCommand.monitorOffCommand :
                                                            "echo standby 0 | cec-client -s -d 1";
                                                        let monitorStatusCommand = (this.initialized && "monitorStatusCommand" in this.thisConfig.customCommand) ?
                                                            this.thisConfig.customCommand.monitorStatusCommand :
                                                            "echo pow 0 | cec-client -s -d 1";
                                            • 3 / 4
