    [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates
    76 Posts 13 Posters 77.3k Views 13 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor @sdetweil
      @sdetweil on the dev branch below is the error
      git checkout master
      error: pathspec ‘master’ did not match any file(s) known to git.
        sdetweil @swvalenti
        @swvalenti ok, what does git branch say
        swvalentiS 1 Reply Last reply Reply Quote 0
          @sdetweil develop
          • shbatm-develop
            sdetweil @swvalenti
            @swvalenti so there is no branch called ‘master’
              @sdetweil oh boy that is odd, how do I get the master back?
                sdetweil @swvalenti
                @swvalenti rename the current folder/directory out of the way, and git clone the remote repo (your fork or his ) again.
                then get to the right branch, and then copy any modified files from the saved repo into this new copy,
                once complete, remove the old saved directory
                  sdetweil @swvalenti
                  @swvalenti the master repo has master and develop as branches
                    shbatm Module Developer @Cr4z33
                    @cr4z33 try adding them using the customCommands config setting (see the develop branch README.
                    Cr4z33C 2 Replies Last reply Reply Quote 0
                    • Cr4z33C Offline
                      Cr4z33 @shbatm
                      @shbatm OK thanks I will try that tomorrow.
                      • Cr4z33C Offline
                        Cr4z33 @shbatm
                        @shbatm said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                        I set the dev branch module like the following:
                        			module: 'MMM-Remote-Control',
                        			disabled: false,
                        			customCommand: {
                        					monitorOnCommand: 'echo on 0 | cec-client -s -d 1',
                        					monitorOffCommand: 'echo standby 0 | cec-client -s -d 1',
                        					monitorStatusCommand: 'echo pow 0 | cec-client -s -d 1'
                        None of the commands are working. :confused_face:
                        I get the ‘Done’ message, but then nothing happens…
                        The syntax is 100% correct and working if used in the terminal.
                          mohace
                          Hi, I can’t see newsfeed options in Module Controls.
                          Can you help me please?
                          • Cr4z33C Offline
                            Cr4z33 @mohace
                            @mohace I can.
                            Double check if you edited anything or try deleting and reinstalling the module?
                              bolish
                              Hi @shbatm
                              I already asked this question on git issues on Jopyth’s version but I just figured out that you are the guy behind the custom menu!
                              Would it be possible to have an action item for a menu?
                              I mean, when you click on the menu, it opens the menu but also as the ability to trigger an action.
                              Regards
                                bolish @Cr4z33
                                @Cr4z33
                                Please check the output of echo pow when your screen is on and off.
                                The original setting related to screen status into the node.js was NOK for me. (indeed, it is something like “ON” / “OFF” / “HDMI” etc…) but my TV was answering with “power status: on” and “power status: standby”.
                                So I had to modify line 610 and 620 with my own.
                                BTW, @shbatm , would be better if those parameters could be configurable also.
                                Regards
                                  mohace @Cr4z33
                                  @Cr4z33 said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                                  @mohace I can.
                                  I meant not in that menu but in
                                  alt text
                                  • Cr4z33C Offline
                                    Cr4z33 @bolish
                                    @bolish OK, but you have to tell me how to do it. :smiling_face_with_open_mouth_cold_sweat:
                                    By the way I have problems turning on and off my TV too.
                                    Even if I edited files to enter the needed CEC commands somehow it doesn’t work (same commands in terminal work fine).
                                    @mohace huh?
                                    I don’t have those menu’s entries at all.
                                    Are you using a custom version of the module or? :confused_face:
                                      bolish
                                      @Cr4z33
                                      Make trials with your terminal :
                                      • Turn screen on by pasting that in your terminal : echo on 0 | cec-client -s -d 1
                                      • Check the feedback status sent by the TV by putting that in terminal : echo pow 0 | cec-client -s -d 1
                                      • Remind the result
                                      Do exactly the same with turn off :
                                      • Turn screen on by pasting that in your terminal : echo standby 0 | cec-client -s -d 1
                                      • Remind the result
                                      The 2 results you will get should be updated in node.js line 610 / 620.
                                      • Cr4z33C Offline
                                        Cr4z33 @bolish
                                        @bolish as I wrote before that’s EXACTLY what I already did. ;)
                                        Terminal commands work straight away while the same commands in MMM-Remote-Control have no effect when used by tapping the buttons in the menu.
                                          bolish
                                          @Cr4z33
                                          So, the ouput you got in the terminal by sending the “pow 0” command is in line with what is written into node helper.js line 610 / 620?
                                          • Cr4z33C Offline
                                            Cr4z33 @bolish
                                            @bolish yep 100% that’s why I tried reporting that to @shbatm , but he didn’t reply about that yet. :grimacing_face:
                                            • 2 / 4
