    [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates
    76 Posts 13 Posters 76.7k Views 13 Watching
      shbatm Module Developer @robiv8
      @robiv8 I don’t have a debug mode, but you can try adding:
      console.log(notification, payload); to Line #988 of node_helper.js to print all notifications received by the back-end from other modules; or console.log(query) to Line #644. If you are using the API, you should be getting a response back in the browser or Postman.
      Looking at your list, I have a sneaking suspicion that Page-Selector is causing the issues, just because it may be inadvertently suspending the module. If you troubleshoot and find that to be the case, and can’t find a work around with that module, you can try using MMM-Carousel w/ Navigation which is what Page-Selector was originally based off of. I know there is an option in that module to “exclude” a module from being suspended.
        robiv8 @shbatm
        @shbatm
        Thanks for your explanation
        I will try it tonight and then report it.
        And yes, I also suspect that it is the page selector.
        Whereby I set “Alert, notification, buttons and podcast2” to exclude. And nevertheless.
        I’ll take a look.
        • Cr4z33C Offline
          Cr4z33 @shbatm
          @shbatm I’ve done the Italian translation if you want to add it. ;)
          https://www.dropbox.com/s/u8hwhecv0exrmcj/it.json?dl=0
            robiv8 @shbatm
            @shbatm
            are you sure with console.log(notification, payload); to Line #988
            my node_helper.js is going only to line 958
              shbatm Module Developer @Cr4z33
              @cr4z33 thanks! I’ll add it when I get a chance.
                @robiv8 make sure your are on the develop branch (git checkout develop from a command line inside the module folder).
                https://github.com/shbatm/MMM-Remote-Control/blob/develop/node_helper.js#L988
                  robiv8 @shbatm
                    robiv8
                    OK So i can see that:
                    REMOTE_CLIENT_CONNECTED {}
                    0|mm  | REMOTE_ACTION { data: 'translations' }
                    0|mm  | REMOTE_ACTION { action: 'SHOW_ALERT',
                    0|mm  |   type: 'alert',
                    0|mm  |   title: 'Test',
                    0|mm  |   message: 'This is a test text',
                    0|mm  |   timer: '4' }
                    but nothing happened!
                    The Devtools says:
                    alert is suspended.
                    updatenotification is suspended.
                    so I mean you are right with MMM-Page-Selector
                    Good to know on the one hand,
                    but on the other SHIT
                    I spent a lot of time making it look and working with the page selector.
                    Now I can start over :-(
                      robiv8
                      One more question!
                      Now I have 6 pages that I use with physical buttons.
                      If I restart the setup now with Carousel which example am I taking?
                      Global, Positional or Slides
                      I found it out myself. :-)
                      Thank you
                      • Cr4z33C Offline
                        Cr4z33 @shbatm
                        @shbatm I need to replace the monitor ON / OFF commands with these TV ones from the package ‘cec-client’.
                        Where do I have to look at?
                        TV ON:
                        echo on 0 | cec-client -s -d 1
                        TV OFF:
                        echo standby 0 | cec-client -s -d 1
                        TV Status:
                        echo pow 0 | cec-client -s -d 1
                        • swvalentiS Offline
                          swvalenti Project Sponsor @shbatm
                          @shbatm said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                          @nobita said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                          I have to Remove from jopyth or not
                          You can checkout my fork/branch without removing @Jopyth’s by adding a remote:
                          $ cd ~/MagicMirror/modules/MMM-Remote-Control
                          $ git remote add shbatm https://github.com/shbatm/MMM-Remote-Control.git
                          $ git fetch shbatm
                          $ git checkout -b shbatm-develop shbatm/develop
                          $ npm install
                          After that you can switch back and forth using git checkout master and git checkout shbatm-develop
                          @shbatm
                          I followed this and I am on the dev branch but when I launch the remote in browser I don’t see any of the added features?
                            shbatm Module Developer @swvalenti
                            @swvalenti Most of the changes are in the background with the API and are enabled by default, but the new front-end features have to be turned on in your config:
                                module: 'MMM-Remote-Control'
                                // , position: 'bottom_left'
                                    customCommand: {},  // Optional, See "Using Custom Commands" below
                                    customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                                    showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                                    pm2ProcessName: "mm",  // Optional, if you don't use the default PM2 process, provide the name here.
                                    apiKey: "",         // Optional, See API/README.md for details
                            • Cr4z33C Offline
                              Cr4z33 @shbatm
                              @shbatm please see my post. ;)
                                I am unable to switch back to master after git checkout master in the $ cd ~/MagicMirror/modules/MMM-Remote-Control what am I doing wrong?
                                • Cr4z33C Offline
                                  Cr4z33 @Cr4z33
                                  @cr4z33 said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                                  TV ON:
                                  TV OFF:
                                  TV Status:
                                  @shbatm so I found out by myself the lines to edit in node_helper.js.
                                  I can succesfully turn off the TV by using the remote module, but for some unknown reason I can’t turn it on… :thinking_face:
                                  Running the command from the terminal works perfectly.
                                    sdetweil @swvalenti
                                    @swvalenti what does the command say? also do git branch to see what branch you are on
                                    swvalentiS 1 Reply Last reply Reply Quote 0
                                      swvalenti Project Sponsor @sdetweil
                                      @sdetweil on the dev branch below is the error
                                      git checkout master
                                      error: pathspec ‘master’ did not match any file(s) known to git.
                                        sdetweil @swvalenti
                                        @swvalenti ok, what does git branch say
                                          @sdetweil develop
                                          • shbatm-develop
                                            sdetweil @swvalenti
                                            @swvalenti so there is no branch called ‘master’
                                            • 2 / 4
