    [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates
    76 Posts 13 Posters 76.1k Views 13 Watching
      robiv8 @shbatm
      @shbatm
      are you sure with console.log(notification, payload); to Line #988
      my node_helper.js is going only to line 958
        shbatm Module Developer @Cr4z33
        @cr4z33 thanks! I’ll add it when I get a chance.
          shbatm Module Developer @robiv8
          @robiv8 make sure your are on the develop branch (git checkout develop from a command line inside the module folder).
          https://github.com/shbatm/MMM-Remote-Control/blob/develop/node_helper.js#L988
            robiv8 @shbatm
              robiv8
              OK So i can see that:
              REMOTE_CLIENT_CONNECTED {}
              0|mm  | REMOTE_ACTION { data: 'translations' }
              0|mm  | REMOTE_ACTION { action: 'SHOW_ALERT',
              0|mm  |   type: 'alert',
              0|mm  |   title: 'Test',
              0|mm  |   message: 'This is a test text',
              0|mm  |   timer: '4' }
              but nothing happened!
              The Devtools says:
              alert is suspended.
              updatenotification is suspended.
              so I mean you are right with MMM-Page-Selector
              Good to know on the one hand,
              but on the other SHIT
              I spent a lot of time making it look and working with the page selector.
              Now I can start over :-(
                robiv8
                One more question!
                Now I have 6 pages that I use with physical buttons.
                If I restart the setup now with Carousel which example am I taking?
                Global, Positional or Slides
                I found it out myself. :-)
                Thank you
                • Cr4z33C Offline
                  Cr4z33 @shbatm
                  @shbatm I need to replace the monitor ON / OFF commands with these TV ones from the package ‘cec-client’.
                  Where do I have to look at?
                  TV ON:
                  echo on 0 | cec-client -s -d 1
                  TV OFF:
                  echo standby 0 | cec-client -s -d 1
                  TV Status:
                  echo pow 0 | cec-client -s -d 1
                  • swvalentiS Offline
                    swvalenti Project Sponsor @shbatm
                    @shbatm said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                    @nobita said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                    I have to Remove from jopyth or not
                    You can checkout my fork/branch without removing @Jopyth’s by adding a remote:
                    $ cd ~/MagicMirror/modules/MMM-Remote-Control
                    $ git remote add shbatm https://github.com/shbatm/MMM-Remote-Control.git
                    $ git fetch shbatm
                    $ git checkout -b shbatm-develop shbatm/develop
                    $ npm install
                    After that you can switch back and forth using git checkout master and git checkout shbatm-develop
                    @shbatm
                    I followed this and I am on the dev branch but when I launch the remote in browser I don’t see any of the added features?
                      shbatm Module Developer @swvalenti
                      @swvalenti Most of the changes are in the background with the API and are enabled by default, but the new front-end features have to be turned on in your config:
                          module: 'MMM-Remote-Control'
                          // , position: 'bottom_left'
                              customCommand: {},  // Optional, See "Using Custom Commands" below
                              customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                              showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                              pm2ProcessName: "mm",  // Optional, if you don't use the default PM2 process, provide the name here.
                              apiKey: "",         // Optional, See API/README.md for details
                      • Cr4z33C Offline
                        Cr4z33 @shbatm
                        @shbatm please see my post. ;)
                          I am unable to switch back to master after git checkout master in the $ cd ~/MagicMirror/modules/MMM-Remote-Control what am I doing wrong?
                          • Cr4z33C Offline
                            Cr4z33 @Cr4z33
                            @cr4z33 said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                            TV ON:
                            TV OFF:
                            TV Status:
                            @shbatm so I found out by myself the lines to edit in node_helper.js.
                            I can succesfully turn off the TV by using the remote module, but for some unknown reason I can’t turn it on… :thinking_face:
                            Running the command from the terminal works perfectly.
                              sdetweil @swvalenti
                              @swvalenti what does the command say? also do git branch to see what branch you are on
                              swvalentiS 1 Reply Last reply Reply Quote 0
                                swvalenti Project Sponsor @sdetweil
                                @sdetweil on the dev branch below is the error
                                git checkout master
                                error: pathspec ‘master’ did not match any file(s) known to git.
                                  sdetweil @swvalenti
                                  @swvalenti ok, what does git branch say
                                    @sdetweil develop
                                    • shbatm-develop
                                      sdetweil @swvalenti
                                      @swvalenti so there is no branch called ‘master’
                                        @sdetweil oh boy that is odd, how do I get the master back?
                                          sdetweil @swvalenti
                                          @swvalenti rename the current folder/directory out of the way, and git clone the remote repo (your fork or his ) again.
                                          then get to the right branch, and then copy any modified files from the saved repo into this new copy,
                                          once complete, remove the old saved directory
                                            sdetweil @swvalenti
                                            @swvalenti the master repo has master and develop as branches
                                            • 2 / 4
