    [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates
    76 Posts 13 Posters 76.7k Views 13 Watching
      shbatm Module Developer @robiv8
      @robiv8 make sure your are on the develop branch (git checkout develop from a command line inside the module folder).
      https://github.com/shbatm/MMM-Remote-Control/blob/develop/node_helper.js#L988
        robiv8 @shbatm
          robiv8
          OK So i can see that:
          REMOTE_CLIENT_CONNECTED {}
          0|mm  | REMOTE_ACTION { data: 'translations' }
          0|mm  | REMOTE_ACTION { action: 'SHOW_ALERT',
          0|mm  |   type: 'alert',
          0|mm  |   title: 'Test',
          0|mm  |   message: 'This is a test text',
          0|mm  |   timer: '4' }
          but nothing happened!
          The Devtools says:
          alert is suspended.
          updatenotification is suspended.
          so I mean you are right with MMM-Page-Selector
          Good to know on the one hand,
          but on the other SHIT
          I spent a lot of time making it look and working with the page selector.
          Now I can start over :-(
            robiv8
            One more question!
            Now I have 6 pages that I use with physical buttons.
            If I restart the setup now with Carousel which example am I taking?
            Global, Positional or Slides
            I found it out myself. :-)
            Thank you
            • Cr4z33C Offline
              Cr4z33 @shbatm
              @shbatm I need to replace the monitor ON / OFF commands with these TV ones from the package ‘cec-client’.
              Where do I have to look at?
              TV ON:
              echo on 0 | cec-client -s -d 1
              TV OFF:
              echo standby 0 | cec-client -s -d 1
              TV Status:
              echo pow 0 | cec-client -s -d 1
              • swvalentiS Offline
                swvalenti Project Sponsor @shbatm
                @shbatm said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                @nobita said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                I have to Remove from jopyth or not
                You can checkout my fork/branch without removing @Jopyth’s by adding a remote:
                $ cd ~/MagicMirror/modules/MMM-Remote-Control
                $ git remote add shbatm https://github.com/shbatm/MMM-Remote-Control.git
                $ git fetch shbatm
                $ git checkout -b shbatm-develop shbatm/develop
                $ npm install
                After that you can switch back and forth using git checkout master and git checkout shbatm-develop
                @shbatm
                I followed this and I am on the dev branch but when I launch the remote in browser I don’t see any of the added features?
                  shbatm Module Developer @swvalenti
                  @swvalenti Most of the changes are in the background with the API and are enabled by default, but the new front-end features have to be turned on in your config:
                      module: 'MMM-Remote-Control'
                      // , position: 'bottom_left'
                          customCommand: {},  // Optional, See "Using Custom Commands" below
                          customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                          showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                          pm2ProcessName: "mm",  // Optional, if you don't use the default PM2 process, provide the name here.
                          apiKey: "",         // Optional, See API/README.md for details
                  • Cr4z33C Offline
                    Cr4z33 @shbatm
                    @shbatm please see my post. ;)
                      I am unable to switch back to master after git checkout master in the $ cd ~/MagicMirror/modules/MMM-Remote-Control what am I doing wrong?
                      • Cr4z33C Offline
                        Cr4z33 @Cr4z33
                        @cr4z33 said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                        TV ON:
                        TV OFF:
                        TV Status:
                        @shbatm so I found out by myself the lines to edit in node_helper.js.
                        I can succesfully turn off the TV by using the remote module, but for some unknown reason I can’t turn it on… :thinking_face:
                        Running the command from the terminal works perfectly.
                          sdetweil @swvalenti
                          @swvalenti what does the command say? also do git branch to see what branch you are on
                          swvalentiS 1 Reply Last reply Reply Quote 0
                            swvalenti Project Sponsor @sdetweil
                            @sdetweil on the dev branch below is the error
                            git checkout master
                            error: pathspec ‘master’ did not match any file(s) known to git.
                              sdetweil @swvalenti
                              @swvalenti ok, what does git branch say
                                @sdetweil develop
                                • shbatm-develop
                                  sdetweil @swvalenti
                                  @swvalenti so there is no branch called ‘master’
                                    @sdetweil oh boy that is odd, how do I get the master back?
                                      sdetweil @swvalenti
                                      @swvalenti rename the current folder/directory out of the way, and git clone the remote repo (your fork or his ) again.
                                      then get to the right branch, and then copy any modified files from the saved repo into this new copy,
                                      once complete, remove the old saved directory
                                        sdetweil @swvalenti
                                        @swvalenti the master repo has master and develop as branches
                                          shbatm Module Developer @Cr4z33
                                          @cr4z33 try adding them using the customCommands config setting (see the develop branch README.
                                          Cr4z33C 2 Replies Last reply Reply Quote 0
                                          • Cr4z33C Offline
                                            Cr4z33 @shbatm
                                            @shbatm OK thanks I will try that tomorrow.
                                            • 2 / 4
