    [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates
    76 Posts 13 Posters 76.7k Views 13 Watching
    • Cr4z33C Offline
      Cr4z33 @bolish
      @bolish as I wrote before that’s EXACTLY what I already did. ;)
      Terminal commands work straight away while the same commands in MMM-Remote-Control have no effect when used by tapping the buttons in the menu.
        bolish
        @Cr4z33
        So, the ouput you got in the terminal by sending the “pow 0” command is in line with what is written into node helper.js line 610 / 620?
        • Cr4z33C Offline
          Cr4z33 @bolish
          @bolish yep 100% that’s why I tried reporting that to @shbatm , but he didn’t reply about that yet. :grimacing_face:
            bolish
            @Cr4z33
            Strange, it worked for me… FMI, what output do you get in the terminal with “echo pow 0 | cec-client -s -d 1”.
            When the screen is ON? When the screen is “OFF”?
            • Cr4z33C Offline
              Cr4z33 @bolish
              @bolish depending wheter the TV is on or off it says power status: on or power status: standby.
                bolish
                @Cr4z33 same as me…let’s try to cross check our node helper .js to see if they are written the same on line 610 and 620.
                • Cr4z33C Offline
                  Cr4z33 @bolish
                  @bolish wait cannot remember if I am using perhaps the developer version, but line numbers are different.
                  Mine are 601 (on), 604 (off) and 607 (status).
                    bolish
                    This is what I did on my side :
                                if (["MONITORTOGGLE", "MONITORSTATUS", "MONITORON"].indexOf(action) !== -1) {
                                    screenStatus = exec(monitorStatusCommand, opts, (error, stdout, stderr) => {
                                        if (stdout.indexOf("TV is off") !== -1 || stdout.indexOf("false") !== -1) { // REPLACE "TV is off" or "false" by "power status: standby"
                                            // Screen is OFF, turn it ON
                                            status = "off";
                                            if (action === "MONITORTOGGLE" || action === "MONITORON") {
                                                exec(monitorOnCommand, opts, (error, stdout, stderr) => {
                                                    this.checkForExecError(error, stdout, stderr, res, { monitor: "on" });
                                                this.sendSocketNotification("USER_PRESENCE", true);
                                                return;
                                        } else if (stdout.indexOf("HDMI") !== -1 || stdout.indexOf("true") !== -1) { // REPLACE "HDMI" OR "true" by "power status: on"
                                            // Screen is ON, turn it OFF
                                            status = "on";
                                            if (action === "MONITORTOGGLE") {
                                                this.monitorControl("MONITOROFF", opts, res);
                                                return;
                    At least this is what worked for me.
                    • Cr4z33C Offline
                      Cr4z33 @bolish
                      @bolish what about the previous lines?
                      I thought that was the part to edit by replacing monitor commands with HDMI CEC ones like mines?
                              monitorControl: function(action, opts, res) {
                                  let status = "unknown";
                                  let monitorOnCommand = (this.initialized && "monitorOnCommand" in this.thisConfig.customCommand) ?
                                      this.thisConfig.customCommand.monitorOnCommand :
                                      "echo on 0 | cec-client -s -d 1";
                                  let monitorOffCommand = (this.initialized && "monitorOffCommand" in this.thisConfig.customCommand) ?
                                      this.thisConfig.customCommand.monitorOffCommand :
                                      "echo standby 0 | cec-client -s -d 1";
                                  let monitorStatusCommand = (this.initialized && "monitorStatusCommand" in this.thisConfig.customCommand) ?
                                      this.thisConfig.customCommand.monitorStatusCommand :
                                      "echo pow 0 | cec-client -s -d 1";
                        bolish
                        No. From my understanding, you only need to modify the customcommands into your config file not in the node.js.
                        The one you mention into your post (extract of node.js) are the default ones, don’t modify them.
                        What you need to modify into node.js are the ouput conditions as I posted above because the way the node.js is written (and how it’s explained on git) those commands will only work if your ouput are :
                        customCommand: {
                                monitorOnCommand: 'shell command to turn on your monitor',
                                monitorOffCommand: 'shell command to turn off your monitor',
                                monitorStatusCommand: 'shell command to return status of monitor, must return either "HDMI" or "true" if screen is on; or "TV is Off" or "false" if it is off to be recognized'
                        That’s why we need to replace those conditions into the node.js by the one we get with our TV’s (which are different than the “true” / “flase” “TV is on” etc… but are “power status : stand by” and “power status: on”).
                        Clear now??
                        • Cr4z33C Offline
                          Cr4z33 @bolish
                          @bolish sorry, but it is quite hard to get the difference for me lol. :smiling_face_with_open_mouth_cold_sweat:
                          Do you mind doing please a pastebin of your edited node_helper.js so that I can try it out?
                            bolish
                            Just replace related lines by the following ones (it’s approx. around line 610) into your node.js :
                                                if (stdout.indexOf("power status: standby") !== -1 || stdout.indexOf("false") !== -1) { // MODIF DONE HERE
                                                    status = "off";
                                                        return;
                                                } else if (stdout.indexOf("power status: on") !== -1 || stdout.indexOf("true") !== -1) { // MODIF DONE HERE
                                                    status = "on";
                                                        return;
                            Cr4z33C 2 Replies Last reply Reply Quote 0
                            • Cr4z33C Offline
                              Cr4z33 @bolish
                              @bolish OK thanks now the TV can be turned off succesfully, but still can’t be turned on ( although I keep getting the Done! confirmation message ) . :thinking_face:
                              • Cr4z33C Offline
                                Cr4z33 @bolish
                                @bolish OK something weird happened.
                                After let’s say 1 minute the TV turned ON by itself (can’t say really…) and there’s now no signal on the (proper) HDMI port.
                                I have the feeling the module is still sending monitor commands and NOT cec-utils package ones! :thinking_face:
                                  bolish
                                  @Cr4z33 indeed, strange, I will check my code this evening (I did it by “memory” since this morning…).
                                  • Cr4z33C Offline
                                    Cr4z33 @Cr4z33
                                    @bolish in addition to what I wrote in my last post I forgot that I actually have entered the custom commands in the module config section so it is twice weird as it should execute those commands.
                                      mohace @Cr4z33
                                      @Cr4z33 said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                                      @mohace huh?
                                      I don’t have those menu’s entries at all.
                                      Are you using a custom version of the module or? :confused_face:
                                      Not at all. You can see same pic in shbatm second post, after the first one you replyed.
                                      @shbatm said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                                      Additional Features Added:
                                      • Dynamic Module Control menu – uses the new API to create a Module Control menu on the remote page to control other modules via notifications.
                                      • Custom Menu – ability to specify your own custom menu items from a file (for advanced users)
                                      • Use PM2 API to control restarts/stops of MM. Can also support starting/stopping other PM2 scripts by passing processName: “scriptToUse” in the query payload.
                                      Example Dynamic Menu for MMM-Carousel w/ Navigation
                                      It seems that you need activate some features in modules to show them in this menu. But I don’t know what needs Newsfeed, for to have active his entry.
                                      • Cr4z33C Offline
                                        Cr4z33 @mohace
                                        @mohace Oh yes you are correct I forgot that we can have custom entries indeed.
                                        Well in my case Newsfeed is showing up by default without having to enable manually something. :man_shrugging_light_skin_tone:
                                        • L Offline
                                          Lowis
                                          I don’t have these entries
                                          reinstalled twice the module without luck.
                                          when i first installed this module the entries was there .
                                          my config.js
                                                module: 'MMM-Remote-Control',
                                                position: 'bottom_left',
                                                  customCommand: {},
                                                  customMenu: 'custom_menu.json',
                                                  showModuleApiMenu: true,
                                                  apiKey: ''
                                          • swvalentiS Offline
                                            swvalenti Project Sponsor
                                            Any idea why my remote control looks like this? It’s lacking the right buttons etc…0_1557623899958_MM.PNG
                                            • 3 / 4
