    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 232.4k Views 20 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      Errr, in your package.json you have a reference to Wunderlist module in the description.
      paviroP 1 Reply Last reply Reply Quote 1
      • paviroP Offline
        paviro @KirAsh4
        @KirAsh4 Fixed thanks :)
        – The Doctor
        • pugslyP Offline
          pugsly
          I don’t have the sensor yet, but installed the module and put the entry into my config.js and when I start mm I get a white screen. Is that normal because I do not have the sensor hooked up yet?
          paviroP 1 Reply Last reply Reply Quote 0
          • EoFE Offline
            EoF
            This is awesome! I will definitely be using this when I get my mirror built.
            • paviroP Offline
              paviro @pugsly
              @pugsly I am busy this weekend but I will check next week, for the time being check your web inspector for any errors and make sure there is no mistake in your formatting of the config.js file!
              – The Doctor
                PtrBld Module Developer
                @pugsly: Are you using Node v6? I had the same issue this weekend.
                • I Offline
                  incubik
                  Hi! Im having the same issue as @pugsly. I do already have the PIR sensor connected but once I launch the MagicMirror the screen goes white.
                  This is what I have in the config.js:
                  module: "MMM-PIR-Sensor',
                  sensorPIN: '2'
                  Any thoughts? Thx!
                  • I Offline
                    incubik
                    There was a type on my message… sorry. This is what I have done:
                    module: 'MMM-PIR-Sensor’,
                    sensorPIN: ‘2’
                    Note from admin: Please use Markdown on code snippets so it is easier to read!
                    • paviroP Offline
                      paviro @incubik
                      @incubik have you checked your Web inspector?
                      – The Doctor
                      • I Offline
                        incubik
                        I have Raspbian install so Im using Epiphany. Does this browser has a web inspector? if so, where? Thx
                        • 12
                        • 13
                        • 1 / 13
