    Multiple instances of MMM-DarkSkyForecast with MMM-pages
    18 Posts 5 Posters 6.7k Views 5 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @popeofmope
      @popeofmope
      you have both modules (calendar & DarkSkyForecast) on both pages…
      try it like this:
          module: 'MMM-pages',
                  ["calendar"],
                  ["MMM-DarkSkyForecast"]
              fixed: ["clock", "MMM-page-indicator"]
      hope this helps
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
        popeofmope @justjim1220
        @justjim1220
        I’m trying to get 2 instances of MMM-DarkSkyForecast on 2 separate pages. Page 1 would display hourly forecast, page 2 would show daily forecast.
        I tried to clone a 2nd copy of the module to a separate folder ../modules/MMM-dsf and then rename the ../MMM-dsf/MMM-DarkSkyForecast.js to ../MMM-dsf/MMM-dsf.js and then configure the pages module as follows
          config: { modules: [ ["calendar", "MMM-DarkSkyForecast"],
                                ["calendar", "MMM-dsf"] ],
                    fixed: ["clock", "MMM-page-indicator"]}
        S justjim1220J 3 Replies Last reply Reply Quote 0
          sdetweil @popeofmope
          @popeofmope and u had a { module : …}, block for each instance, right? so before using pages, you should see two on the screen
            @popeofmope
            OK, sorry, I understand now…
            I am not too sure you can have more than one instance of that module shown on your MM at the same time. At least, I am not able to get it to work anyways.
            But, since you are wanting one to show the HOURLY and the other to show the DAILY, I would use MMM-darksky–hourly (https://github.com/jacquesCedric/MMM-darksky-hourly), then set MMM-DarkSkyForecast to only show the DAILY.
            EDIT: you are able to show 2 different instances of MMM-DarkSkyForecast, using the following code in your config.js…
                        disabled: false,
                        module: "MMM-DarkSkyForecast", // HOURLY
                        header: "Weather",
                            apikey: "Super_Secret_API",
                            latitude: "40.26189",
                            longitude: "-94.03534",
                            iconset: "4c",
                            concise: false,
                            showHourlyForecast: true,
                            hourlyForecastInterval: 3,
                            maxHourliesToShow: 3,
                            showDailyForecast: false,
                            maxDailiesToShow: 3,
                            forecastLayout: "tiled"
                        disabled: false,
                        module: "MMM-DarkSkyForecast", // DAILY
                        header: "Weather",
                            iconset: "5c",
                            concise: false,
                            showHourlyForecast: false,
                            showDailyForecast: true,
            this is the result I have with it…
            Jim Hallock - 1995
              he copied the model to a new name MMM-dsf
              and then put two modules into config… well… not sure… cause I don’t see the config info only the pages info
                @popeofmope
                you need to add this to your pages module to get it to auto scroll:
                animationTime: 1000,
                rotationTime: 30 * 60 * 1000,
                rotationDelay: 500
                like so…
                    modules:
                      fixed: ["clock", "MMM-page-indicator"],
                      rotationTime: 30 * 60 * 1000, // this is to change the page every 30 minutes,
                      rotationDelay: 500
                Jim Hallock - 1995
                  @justjim1220 Since I have such small screen real estate I wanted page 1 to exactly mirror page 2 except for the hourly vs daily forecast display, and then have MMM-Pages auto rotate the pages. Seems this might not be possible…
                  justjim1220J 2 Replies Last reply Reply Quote 0
                    @popeofmope
                    what time frame between rotations?
                    You can also use https://github.com/edward-shen/MMM-page-indicator to manually change the pages
                    I use both so if I want to see a different page and not have to wait the 30 minutes between rotations, I can just click on the page indicator to show the page I want to see
                    What you are asking is doable ;)
                    Jim Hallock - 1995
                      @popeofmope
                      OK…
                      I think I got pretty close to what you are asking for…
                      Page 1
                      Page 2
                      modules: [{
                                  module: "alert",
                                  module: "updatenotification",
                                  position: "top_bar"
                                  module: 'MMM-Cursor',
                                      timeout: 1000
                                          ["calendar", "MMM-DarkSkyForecast2"]
                                      rotationTime: 3 * 60 * 1000, // this is to change the page every 3 minutes,
                                      rotationDelay: 500
                                  module: 'MMM-page-indicator',
                                  position: 'bottom_bar',
                                      pages: 2
                                  module: "clock",
                                  position: "top_center"
                                  header: "Holidays",
                                      colored: true,
                                      coloredSymbolOnly: true,
                                      calendars: [{
                                          url: 'https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics',
                                          symbol: 'calendar',
                                          auth: {
                                              user: 'justjim1220@gmail.com',
                                              pass: 'abcde12345',
                                              method: 'basic'
                                  disabled: false,
                                  header: "Weather - Hourly Forecast",
                                      apikey: "abcde12345abcde12345abcde12345ab",
                                      iconset: "4c",
                                      concise: false,
                                      hourlyForecastInterval: 1,
                                      maxHourliesToShow: 6,
                                  disabled: false,
                                  module: "MMM-DarkSkyForecast2", // DAILY
                                  header: "Weather - Daily Forecast",
                                      iconset: "5c",
                                      concise: false,
                                      maxDailiesToShow: 6,
                      I hope this helps! ;)
                      Jim Hallock - 1995
                      P C 2 Replies Last reply Reply Quote 0
                        @justjim1220 Yes! This is what I was after! Thank you! Your repo, https://github.com/justjim1220/MMM-DarkSkyForecast2, doesn’t include the icons directory so I had to copy from MMM-DarkSkyForecast, symlink didn’t work.
