    Multiple instances of MMM-DarkSkyForecast with MMM-pages
    18 Posts 5 Posters 6.9k Views 5 Watching
      he copied the model to a new name MMM-dsf
      and then put two modules into config… well… not sure… cause I don’t see the config info only the pages info
        module: 'MMM-pages',
        config: { modules: [ ["calendar", "MMM-DarkSkyForecast"],
                              ["calendar", "MMM-dsf"] ],
                  fixed: ["clock", "MMM-page-indicator"]}
      • justjim1220J Offline
        justjim1220 Module Developer @popeofmope
        @popeofmope
        you need to add this to your pages module to get it to auto scroll:
        animationTime: 1000,
        rotationTime: 30 * 60 * 1000,
        rotationDelay: 500
        like so…
            modules:
              fixed: ["clock", "MMM-page-indicator"],
              rotationTime: 30 * 60 * 1000, // this is to change the page every 30 minutes,
              rotationDelay: 500
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          popeofmope @justjim1220
          @justjim1220 Since I have such small screen real estate I wanted page 1 to exactly mirror page 2 except for the hourly vs daily forecast display, and then have MMM-Pages auto rotate the pages. Seems this might not be possible…
          justjim1220J 2 Replies Last reply Reply Quote 0
            @popeofmope
            what time frame between rotations?
            You can also use https://github.com/edward-shen/MMM-page-indicator to manually change the pages
            I use both so if I want to see a different page and not have to wait the 30 minutes between rotations, I can just click on the page indicator to show the page I want to see
            What you are asking is doable ;)
            Jim Hallock - 1995
              @popeofmope
              OK…
              I think I got pretty close to what you are asking for…
              Page 1
              Page 2
              modules: [{
                          module: "alert",
                          module: "updatenotification",
                          position: "top_bar"
                          module: 'MMM-Cursor',
                              timeout: 1000
                                  ["calendar", "MMM-DarkSkyForecast2"]
                              rotationTime: 3 * 60 * 1000, // this is to change the page every 3 minutes,
                              rotationDelay: 500
                          module: 'MMM-page-indicator',
                          position: 'bottom_bar',
                              pages: 2
                          module: "clock",
                          position: "top_center"
                          header: "Holidays",
                              colored: true,
                              coloredSymbolOnly: true,
                              calendars: [{
                                  url: 'https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics',
                                  symbol: 'calendar',
                                  auth: {
                                      user: 'justjim1220@gmail.com',
                                      pass: 'abcde12345',
                                      method: 'basic'
                          disabled: false,
                          module: "MMM-DarkSkyForecast", // HOURLY
                          header: "Weather - Hourly Forecast",
                              apikey: "abcde12345abcde12345abcde12345ab",
                              latitude: "40.26189",
                              longitude: "-94.03534",
                              iconset: "4c",
                              concise: false,
                              showHourlyForecast: true,
                              hourlyForecastInterval: 1,
                              maxHourliesToShow: 6,
                              showDailyForecast: false,
                              maxDailiesToShow: 3,
                              forecastLayout: "tiled"
                          disabled: false,
                          module: "MMM-DarkSkyForecast2", // DAILY
                          header: "Weather - Daily Forecast",
                              iconset: "5c",
                              concise: false,
                              showHourlyForecast: false,
                              hourlyForecastInterval: 3,
                              maxHourliesToShow: 3,
                              showDailyForecast: true,
                              maxDailiesToShow: 6,
              I hope this helps! ;)
              Jim Hallock - 1995
              P C 2 Replies Last reply Reply Quote 0
                @justjim1220 Yes! This is what I was after! Thank you! Your repo, https://github.com/justjim1220/MMM-DarkSkyForecast2, doesn’t include the icons directory so I had to copy from MMM-DarkSkyForecast, symlink didn’t work.
                  Clubjack @justjim1220
                  @justjim1220
                  I want Do this with different calendar on different pages.
                  Can You Tell me, how You copy a module and rename it?
                  • FoziF Offline
                    Fozi Project Sponsor @Clubjack
                    @Clubjack I had recently exactly the same issue with MMM-ioBroker, where I needed 2 instances of that module running. Finally, after some research I found the solution and documented in my private Wiki. Here is the documentation I wrote. After setting up that 2nd instance you can configure each instance separately and declare it in MMM-pages.
                    Here we go:
                    Problem
                    In some cases you may need to run 2 or more instances of the same module in MM, e.g. for public transportation. Some MMMs can then be put into config.js just on a different position and parameterized as needed. Unfortunatelly, not all MMMs support that.
                    The reason is that all those instances will share the same node_helper and therefore get the same socketnotifications.
                    Solution
                    To solve this problem you can try to duplicate the MMM with a different name and call it in the config.js. There is no guarantee that it works, but worth to try.
                    Following steps have to be done:
                    1. Go to the modules folder and copy the whole module with a different name (in this example I’ll refer to MMM-ioBroker)
                    $ cd ~/MagicMirror/modules
                    $ cp -a MMM-ioBroker/ MMM-ioBroker2
                    1. Go to ./MMM-ioBroker2 and change the .js of the module script accordingly
                    $ mv MMM-ioBroker.js MMM-ioBroker2.js
                    1. Edit in MMM-ioBroker2.js the string to
                    Module.register('MMM-ioBroker2', {
                    1. In some cases it might also be necessary to change the .css file name, too, incl. any reference to the instance name in the file.
                    $ mv MMM-ioBroker.css MMM-ioBroker2.css
                    And then edit or replace all occurences of ‘MMM-ioBroker’ with ‘MMM-ioBroker2’ in MMM-ioBroker2.css.
                    C 2 Replies Last reply Reply Quote 1
                      Clubjack @Fozi
                      @Fozi
                      Thank You guy.
                      I will test it at the weekend.
                      That sounds good. 👍🏽
                        Clubjack @Fozi
                        @Fozi
                        Tryed your way, but get some issues with the modules. Is it right that i must use mv and not cp for the namechange from the. js?
                        S FoziF 2 Replies Last reply Reply Quote 0
                          sdetweil @Clubjack
                          @Clubjack said in Multiple instances of MMM-DarkSkyForecast with MMM-pages:
                          mv and not cp
                          correct…
                          mv is the rename
                          • FoziF Offline
                            @Clubjack if you use ‘cp’ then the file is really copied under a new name. The original file will still exist.
                            If you use ‘mv’ then the file will be renamed, there will no copy of that file.
                            Thus use ‘mv’ to rename the files. Otherwise you’ll have two .js files in your module.
                            Edit: @sdetweil was 10 sec. quicker than me:face_with_tears_of_joy:
                              Clubjack
                              Thanks. But i think it dosnt work with this Module.
