    MMM-Temperature/Humidity Module (DHT11, DHT22 and AM2302 sensors.)
    34 Posts 11 Posters 41.9k Views 10 Watching
      Jopyth Moderator
      @Bangee As far as I know, the normal pi user has sudo rights already. I use a module to shutdown the mirror which needs sudo rights, but works fine with exec from a normal node_helper.
      • BangeeB
        Bangee Module Developer
        @Jopyth yes, he has, but he’s going to start the MagicMirror with sudo npm start
        for security reasons I try to run everything without sudo commands.
        • pskP
          psk
          @cowboysdude DHT11 - This is the sensor that I am using.
          It has three pins -
          +ve - Connected to 5v
          -ve - Ground
          Data - Connected to pin 2
          @Bangee Now, I am running as sudo npm start. Without sudo, it will throw an exception that says it cannot open dev/mem
          P.S.K
          • BangeeB
            I’m using node-dht-sensor
            As user pi I don’t have an error but after starting MagicMirror thers a crash.
            @psk you should cool down your room :-)
            • cowboysdudeC
              I really do like this! Great job!
              • pskP
                psk
                @Bangee According to bcm2835 v1.50-
                "Running as root
                Prior to the release of Raspbian Jessie in Feb 2016, access to any peripheral device via /dev/mem on the RPi required the process to run as root. Raspbian Jessie permits non-root users to access the GPIO peripheral (only) via /dev/gpiomem, and this library supports that limited mode of operation.
                If the library runs with effective UID of 0 (ie root), then bcm2835_init() will attempt to open /dev/mem, and, if successful, it will permit use of all peripherals and library functions.
                If the library runs with any other effective UID (ie not root), then bcm2835_init() will attempt to open /dev/gpiomem, and, if successful, will only permit GPIO operations. In particular, bcm2835_spi_begin() and bcm2835_i2c_begin() will return false and all other non-gpio operations may fail silently or crash."
                So i guess we have run with sudo until some other library comes up :D
                PS: I should!! Its too hot in here… :D :D
                @cowboysdude Thanks! Cheers :D
                P.S.K
                Reply Quote 2
                  jsyzthz
                  @psk i’m following your steps.but got some errors
                  0_1475156462089_upload-b782b89f-2067-4c7d-92ed-d69124b72d1c
                  can you help me to take a look? thanks!
                  pskP 1 Reply Last reply
                  • pskP
                    psk
                    @jsyzthz I ran into the same while setting up!
                    try this. Go to MMM-Temperature-Humidity,
                    npm rebuild --runtime=electron --target=1.4.0 --disturl=https://atom.io/download/atom-shell --build-from-source
                    My Electron version is 1.4.0. If yours is different, replace accordingly. :D
                    This is a known issue which is caused by the serialport module using native code that is built for a different version of Node. You can read a bit more about addons here, if you’re interested; they’re just modules written in C/C++ that can interface with Node so the module can interface with the hardware more easily.
                    Credits : stackoverflow.com
                    P.S.K
                    • pskP
                      psk @jsyzthz
                      @jsyzthz
                      I’m not sure whether to rebuild in MMM-Temperature-humidity directory or the Magic Mirror directory.
                      Try executing in the MagicMirror directory first.
                      Also you can find the electron version by : npm list
                      Just in case, i had this in my commands history :D
                      npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49 -d
                      P.S.K
                      J 1 Reply Last reply
                        jsyzthz @psk
                        @psk i use the first command. it woks now.thx!
                        • pskP
                          psk @jsyzthz
                          @jsyzthz Glad I could help :D :D
                          P.S.K
                          • H3L1o150H
                            H3L1o150
                            Hi, i am really new on this, someone can help me, with the code on config.js file?
                                            module: 'MMM-Temperature-Humidity',
                                            position: 'bottom_bar',
                                              var dht = new rpiDhtSensor.DHT11(21);
                            thanks
                            yawnsY 1 Reply Last reply
                            • yawnsY
                              yawns Moderator @H3L1o150
                              @H3L1o150
                              No, you need to edit the file node_helper.js in the modules folder
                              Currently you cannot define the pin and the sensor type in the config section. But I think this should be improved in a future release
                              • H3L1o150H
                                H3L1o150
                                @yawns so i left the config.js file like that?
                                          position: 'top_right',
                                • yawnsY
                                  I never played around with this module. But I would use this:
                                  { module: 'MMM-Temperature-Humidity', position: 'top_right' }
                                  And then you edit node_helper.js to set for DHT11 or DHT22 and the correct pin in ( )
                                  • H3L1o150H
                                    H3L1o150
                                    @yawns Tanks for the help
                                    maybe i’m wrong in code. with me show a white screen
                                    • pskP
                                      psk @H3L1o150
                                      @H3L1o150 currently, to define the pin to which sensor is connected, you need to edit the node_helper.js file ind MMM-Temperature-Humidity directory and edit line number 12.
                                      var dht = new rpiDhtSensor.DHT11(2); to var dht = new rpiDhtSensor.DHT11(21);
                                      you can leave the config as
                                      			position: 'bottom_right',
                                      				refreshInterval: 10000,
                                      				temperaturePrefix: "Room temperature: ",
                                      				temperatureSuffix: "°C",
                                      				humidityPrefix: "Humidity: ",
                                      				humiditySuffix: "%"
                                      guess this needs to be improved in future release… :D
                                      P.S.K
                                      • H3L1o150H
                                        H3L1o150
                                        Tanks @psk
                                          jsyzthz
                                          i found MMM cannot auto startup if use it. because it must be run with sudo. but i don’t know how to run sudo with ‘DISPLAY=:0’? @psk
                                          • BangeeB
                                            @jsyzthz checkt this out: https://forum.magicmirror.builders/topic/738/mmm-dht22-humidity-and-temperature-module
