    MMM-Temperature/Humidity Module (DHT11, DHT22 and AM2302 sensors.)
    34 Posts 11 Posters 41.4k Views 10 Watching
      paviro
      Please also share a link to your module and some screenshots!
      – The Doctor
        psk
        oops!! I forgot to post the link. My bad :|
        The module can be found here.
        P.S.K
        • cowboysdudeC
          What is the brand and perhaps part number you’re using for this? Wiring?
            Bangee Module Developer
            @psk Do you need to run magicmirror as root?
            I try to find a solution to do the same as pi
              Jopyth Moderator
              @Bangee As far as I know, the normal pi user has sudo rights already. I use a module to shutdown the mirror which needs sudo rights, but works fine with exec from a normal node_helper.
                @Jopyth yes, he has, but he’s going to start the MagicMirror with sudo npm start
                for security reasons I try to run everything without sudo commands.
                  psk
                  @cowboysdude DHT11 - This is the sensor that I am using.
                  It has three pins -
                  +ve - Connected to 5v
                  -ve - Ground
                  Data - Connected to pin 2
                  @Bangee Now, I am running as sudo npm start. Without sudo, it will throw an exception that says it cannot open dev/mem
                  P.S.K
                    I’m using node-dht-sensor
                    As user pi I don’t have an error but after starting MagicMirror thers a crash.
                    @psk you should cool down your room :-)
                    • cowboysdudeC
                      I really do like this! Great job!
                        psk
                        @Bangee According to bcm2835 v1.50-
                        "Running as root
                        Prior to the release of Raspbian Jessie in Feb 2016, access to any peripheral device via /dev/mem on the RPi required the process to run as root. Raspbian Jessie permits non-root users to access the GPIO peripheral (only) via /dev/gpiomem, and this library supports that limited mode of operation.
                        If the library runs with effective UID of 0 (ie root), then bcm2835_init() will attempt to open /dev/mem, and, if successful, it will permit use of all peripherals and library functions.
                        If the library runs with any other effective UID (ie not root), then bcm2835_init() will attempt to open /dev/gpiomem, and, if successful, will only permit GPIO operations. In particular, bcm2835_spi_begin() and bcm2835_i2c_begin() will return false and all other non-gpio operations may fail silently or crash."
                        So i guess we have run with sudo until some other library comes up :D
                        PS: I should!! Its too hot in here… :D :D
                        @cowboysdude Thanks! Cheers :D
                        P.S.K
                          jsyzthz
                          @psk i’m following your steps.but got some errors
                          0_1475156462089_upload-b782b89f-2067-4c7d-92ed-d69124b72d1c
                          can you help me to take a look? thanks!
                            psk
                            @jsyzthz I ran into the same while setting up!
                            try this. Go to MMM-Temperature-Humidity,
                            npm rebuild --runtime=electron --target=1.4.0 --disturl=https://atom.io/download/atom-shell --build-from-source
                            My Electron version is 1.4.0. If yours is different, replace accordingly. :D
                            This is a known issue which is caused by the serialport module using native code that is built for a different version of Node. You can read a bit more about addons here, if you’re interested; they’re just modules written in C/C++ that can interface with Node so the module can interface with the hardware more easily.
                            Credits : stackoverflow.com
                            P.S.K
                              psk @jsyzthz
                              @jsyzthz
                              I’m not sure whether to rebuild in MMM-Temperature-humidity directory or the Magic Mirror directory.
                              Try executing in the MagicMirror directory first.
                              Also you can find the electron version by : npm list
                              Just in case, i had this in my commands history :D
                              npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49 -d
                              P.S.K
                                jsyzthz @psk
                                @psk i use the first command. it woks now.thx!
                                  psk @jsyzthz
                                  @jsyzthz Glad I could help :D :D
                                  P.S.K
                                  • H
                                    H3L1o150
                                    Hi, i am really new on this, someone can help me, with the code on config.js file?
                                                    module: 'MMM-Temperature-Humidity',
                                                    position: 'bottom_bar',
                                                      var dht = new rpiDhtSensor.DHT11(21);
                                    thanks
                                    • Y
                                      yawns Moderator @H3L1o150
                                      @H3L1o150
                                      No, you need to edit the file node_helper.js in the modules folder
                                      Currently you cannot define the pin and the sensor type in the config section. But I think this should be improved in a future release
                                      • H
                                        H3L1o150
                                        @yawns so i left the config.js file like that?
                                                  position: 'top_right',
                                        • Y
                                          I never played around with this module. But I would use this:
                                          { module: 'MMM-Temperature-Humidity', position: 'top_right' }
                                          And then you edit node_helper.js to set for DHT11 or DHT22 and the correct pin in ( )
                                          • H
                                            H3L1o150
                                            @yawns Tanks for the help
                                            maybe i’m wrong in code. with me show a white screen
