    MMM-Temperature/Humidity Module (DHT11, DHT22 and AM2302 sensors.)
    34 Posts 11 Posters 38.2k Views 10 Watching
    • pskP Offline
      psk
      oops!! I forgot to post the link. My bad :|
      The module can be found here.
      P.S.K
      • cowboysdudeC Offline
        What is the brand and perhaps part number you’re using for this? Wiring?
        • BangeeB Offline
          Bangee Module Developer
          @psk Do you need to run magicmirror as root?
          I try to find a solution to do the same as pi
            Jopyth Moderator
            @Bangee As far as I know, the normal pi user has sudo rights already. I use a module to shutdown the mirror which needs sudo rights, but works fine with exec from a normal node_helper.
            • BangeeB Offline
              @Jopyth yes, he has, but he’s going to start the MagicMirror with sudo npm start
              for security reasons I try to run everything without sudo commands.
              • pskP Offline
                psk
                @cowboysdude DHT11 - This is the sensor that I am using.
                It has three pins -
                +ve - Connected to 5v
                -ve - Ground
                Data - Connected to pin 2
                @Bangee Now, I am running as sudo npm start. Without sudo, it will throw an exception that says it cannot open dev/mem
                P.S.K
                • BangeeB Offline
                  I’m using node-dht-sensor
                  As user pi I don’t have an error but after starting MagicMirror thers a crash.
                  @psk you should cool down your room :-)
                    I really do like this! Great job!
                    • pskP Offline
                      psk
                      @Bangee According to bcm2835 v1.50-
                      "Running as root
                      Prior to the release of Raspbian Jessie in Feb 2016, access to any peripheral device via /dev/mem on the RPi required the process to run as root. Raspbian Jessie permits non-root users to access the GPIO peripheral (only) via /dev/gpiomem, and this library supports that limited mode of operation.
                      If the library runs with effective UID of 0 (ie root), then bcm2835_init() will attempt to open /dev/mem, and, if successful, it will permit use of all peripherals and library functions.
                      If the library runs with any other effective UID (ie not root), then bcm2835_init() will attempt to open /dev/gpiomem, and, if successful, will only permit GPIO operations. In particular, bcm2835_spi_begin() and bcm2835_i2c_begin() will return false and all other non-gpio operations may fail silently or crash."
                      So i guess we have run with sudo until some other library comes up :D
                      PS: I should!! Its too hot in here… :D :D
                      @cowboysdude Thanks! Cheers :D
                      P.S.K
                        jsyzthz
                        @psk i’m following your steps.but got some errors
                        0_1475156462089_upload-b782b89f-2067-4c7d-92ed-d69124b72d1c
                        can you help me to take a look? thanks!
                        pskP 1 Reply Last reply Reply Quote 0
                        • 1 / 4
