    MMM-Temperature/Humidity Module (DHT11, DHT22 and AM2302 sensors.)
    34 Posts 11 Posters 41.9k Views 10 Watching
    • pskP
      psk
      Temperature and Humidity monitoring Module for MagicMirror2 that works for DHT11, DHT22 and AM2302 sensors.
      Dependancy : rpi-dht-sensor
      For some reason, the module requires elevated permissions to run.(sudo npm start).
      It would be great if someone could help in this regard.
      Hope it comes of use to somebody else.
      Cheers.
      P.S.K
      • paviroP
        paviro
        Please also share a link to your module and some screenshots!
        – The Doctor
        • pskP
          psk
          oops!! I forgot to post the link. My bad :|
          The module can be found here.
          P.S.K
          • cowboysdudeC
            What is the brand and perhaps part number you’re using for this? Wiring?
            • BangeeB
              Bangee Module Developer
              @psk Do you need to run magicmirror as root?
              I try to find a solution to do the same as pi
                Jopyth Moderator
                @Bangee As far as I know, the normal pi user has sudo rights already. I use a module to shutdown the mirror which needs sudo rights, but works fine with exec from a normal node_helper.
                • BangeeB
                  @Jopyth yes, he has, but he’s going to start the MagicMirror with sudo npm start
                  for security reasons I try to run everything without sudo commands.
                  • pskP
                    psk
                    @cowboysdude DHT11 - This is the sensor that I am using.
                    It has three pins -
                    +ve - Connected to 5v
                    -ve - Ground
                    Data - Connected to pin 2
                    @Bangee Now, I am running as sudo npm start. Without sudo, it will throw an exception that says it cannot open dev/mem
                    P.S.K
                    • BangeeB
                      I’m using node-dht-sensor
                      As user pi I don’t have an error but after starting MagicMirror thers a crash.
                      @psk you should cool down your room :-)
                      • cowboysdudeC
                        I really do like this! Great job!
                        • pskP
                          psk
                          @Bangee According to bcm2835 v1.50-
                          "Running as root
                          Prior to the release of Raspbian Jessie in Feb 2016, access to any peripheral device via /dev/mem on the RPi required the process to run as root. Raspbian Jessie permits non-root users to access the GPIO peripheral (only) via /dev/gpiomem, and this library supports that limited mode of operation.
                          If the library runs with effective UID of 0 (ie root), then bcm2835_init() will attempt to open /dev/mem, and, if successful, it will permit use of all peripherals and library functions.
                          If the library runs with any other effective UID (ie not root), then bcm2835_init() will attempt to open /dev/gpiomem, and, if successful, will only permit GPIO operations. In particular, bcm2835_spi_begin() and bcm2835_i2c_begin() will return false and all other non-gpio operations may fail silently or crash."
                          So i guess we have run with sudo until some other library comes up :D
                          PS: I should!! Its too hot in here… :D :D
                          @cowboysdude Thanks! Cheers :D
                          P.S.K
                          Reply Quote 2
                            jsyzthz
                            @psk i’m following your steps.but got some errors
                            0_1475156462089_upload-b782b89f-2067-4c7d-92ed-d69124b72d1c
                            can you help me to take a look? thanks!
                            pskP 1 Reply Last reply
                            • pskP
                              psk
                              @jsyzthz I ran into the same while setting up!
                              try this. Go to MMM-Temperature-Humidity,
                              npm rebuild --runtime=electron --target=1.4.0 --disturl=https://atom.io/download/atom-shell --build-from-source
                              My Electron version is 1.4.0. If yours is different, replace accordingly. :D
                              This is a known issue which is caused by the serialport module using native code that is built for a different version of Node. You can read a bit more about addons here, if you’re interested; they’re just modules written in C/C++ that can interface with Node so the module can interface with the hardware more easily.
                              Credits : stackoverflow.com
                              P.S.K
                              • pskP
                                psk @jsyzthz
                                @jsyzthz
                                I’m not sure whether to rebuild in MMM-Temperature-humidity directory or the Magic Mirror directory.
                                Try executing in the MagicMirror directory first.
                                Also you can find the electron version by : npm list
                                Just in case, i had this in my commands history :D
                                npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49 -d
                                P.S.K
                                J 1 Reply Last reply
                                  jsyzthz @psk
                                  @psk i use the first command. it woks now.thx!
                                  • pskP
                                    psk @jsyzthz
                                    @jsyzthz Glad I could help :D :D
                                    P.S.K
                                    • H3L1o150H
                                      H3L1o150
                                      Hi, i am really new on this, someone can help me, with the code on config.js file?
                                                      module: 'MMM-Temperature-Humidity',
                                                      position: 'bottom_bar',
                                                        var dht = new rpiDhtSensor.DHT11(21);
                                      thanks
                                      yawnsY 1 Reply Last reply
                                      • yawnsY
                                        yawns Moderator @H3L1o150
                                        @H3L1o150
                                        No, you need to edit the file node_helper.js in the modules folder
                                        Currently you cannot define the pin and the sensor type in the config section. But I think this should be improved in a future release
                                        • H3L1o150H
                                          H3L1o150
                                          @yawns so i left the config.js file like that?
                                                    position: 'top_right',
                                          • yawnsY
                                            I never played around with this module. But I would use this:
                                            { module: 'MMM-Temperature-Humidity', position: 'top_right' }
                                            And then you edit node_helper.js to set for DHT11 or DHT22 and the correct pin in ( )
