    Can't upgrade MM 2.7.0 on Raspberry Pi Zero W
    9 Posts 5 Posters 3.7k Views 6 Watching
      maxberger
      Looks like electron 3.x is no longer available for the pi zero.
      I had to go back to the old version:
      diff --git a/package.json b/package.json
      index 14c7874..7a2aff4 100644
      --- a/package.json
      +++ b/package.json
      @@ -58,7 +58,7 @@
           "ajv": "6.5.5",
           "body-parser": "^1.18.2",
           "colors": "^1.1.2",
      -    "electron": "^3.0.13",
      +    "electron": "^2.0.18",
           "express": "^4.16.2",
           "express-ipfilter": "0.3.1",
           "feedme": "latest",
      See also: https://github.com/MichMich/MagicMirror/issues/1500 ; I just undid the change from that patch.
      Not sure if that has any other implications, for now this is still installing/building, let’s see if this works.
      Max
      qu1queQ 1 Reply Last reply Reply Quote 0
      • qu1queQ Offline
        qu1que Project Sponsor @maxberger
        @maxberger
        The thing is that I’ve updated MM, but it returns me that error on rpi Zero, but the final result is that MM finally is updated, and everything works ok in all the modules I have installed. How can I downgrade to the old version of electron?
        Thanks.
        Quique.
        • L Offline
          liamangelus
          did you find any solution to this issue?
          • qu1queQ Offline
            @liamangelus
            No at this moment. Here there is another user with the same problem:
            https://forum.magicmirror.builders/topic/9386/installing-on-a-pi-zero/52?page=6
            • T Offline
              tjk031
              I would also like to know… How can I downgrade to the old version of electron?
                sdetweil @tjk031
                @tjk031 edit the package.json and change the electron version from ^3.0.13 to ^2.0.4
                then erase node_modules
                rm -rf node_modules
                and then
                npm install
                again
                • T Offline
                  tjk031
                  Thanks!!!
                  • qu1queQ Offline
                    Again the same problem when updating to 2.8.0 version
