    Can't upgrade MM 2.7.0 on Raspberry Pi Zero W
    9 Posts 5 Posters 3.7k Views 6 Watching
    • qu1queQ Offline
      qu1que Project Sponsor @maxberger
      @maxberger
      The thing is that I’ve updated MM, but it returns me that error on rpi Zero, but the final result is that MM finally is updated, and everything works ok in all the modules I have installed. How can I downgrade to the old version of electron?
      Thanks.
      Quique.
      • L Offline
        liamangelus
        did you find any solution to this issue?
        • qu1queQ Offline
          @liamangelus
          No at this moment. Here there is another user with the same problem:
          https://forum.magicmirror.builders/topic/9386/installing-on-a-pi-zero/52?page=6
          • T Offline
            tjk031
            I would also like to know… How can I downgrade to the old version of electron?
              sdetweil @tjk031
              @tjk031 edit the package.json and change the electron version from ^3.0.13 to ^2.0.4
              then erase node_modules
              rm -rf node_modules
              and then
              npm install
              again
              • T Offline
                tjk031
                Thanks!!!
                • qu1queQ Offline
                  Again the same problem when updating to 2.8.0 version
