    MMM-CalendarExt2
    486 Posts 83 Posters 960.6k Views 83 Watching
      code999
      alright thanks
      • F Offline
        fnudd
        First of all, thanks for this module, so far it’s filled all my needs of a calendar. One thing I’m struggling with though is that it seems to redraw itself every minute? And since I’m running MM on a raspberry pi zero the drawing takes something like 3 seconds, which makes it a little irritating. Is there anyway to control the re-drawing? I’ve tried setting the scanInterval, but that doesn’t have any effect.
        I also get some CALEXT2_CALENDAR_MODIFIED notifications at fairly regular intervals, even when my calendar hasn’t been changed, but they don’t seem correlated to the redrawing. I’m only using google calendars, if that’s of any help.
        Thanks again, awesome module!
          A Former User @fnudd
          @fnudd
          https://github.com/eouia/MMM-CalendarExt2/wiki/2e.-Configuration:Others#other-configurations
          rotateInterval(When you are using multi-scenes) or updateInterval would be an answer.
          • F Offline
            fnudd @Guest
            @Sean Look at that, I missed that. So many options:-) Thanks alot, and again, great work!
              Subintro
              Hey, so I’ve been using CalendarExt2 for a while for the ‘Current’ calendar feature, but I’m having to move the calendar I use over to private, I have an account with full authorization to view the calendar but when I add
              	auth: {
              		user: "blahblahblah@gmail.com",
              		pass: "password",
              		method: 'basic'
              to my calendar config, it stops working and kind of causes my whole MagicMirror to crash after a while. The logs show everything loading as normal.
              My full config is
              	module: "MMM-CalendarExt2",
              	calendars : [
              		scanInterval: 120000,
              		maxItems: 4,
              		url: "",
              		auth: {
              				user: "",
              				pass: "",
              				method: "basic",
              	views: [
              		mode: "current",
              		position: "bottom_center",
              		calendars: [],
              		slotTitle: "Current Event",
               scenes: [
              		views: [],
              I do use this with another calendar module, that one works fine with the authentication though.
              Thank you for the great module otherwise!
                A Former User @Subintro
                @Subintro
                Can you send your ics url and account information? I need those info to examine.
                If you don’t care, send me by email. (eouia0819@gmail.com)
                • W Offline
                  wegz15
                  Hello, I’m having several issues. Im new to coding for the most part. I took a couple basic web design classes about 12 years ago.
                  I was working on my magic mirror for about 12 hours yesterday. The major issue being my events are not loading from my Google calendar. I used it in the standard upcoming holidays module to make sure I was linking it correctly. They show up there, but not in the calenderext2. The other issue is sizing. Its larger than the screen viewing area. I’m sure I’m doing something wrong. I copied the example that was posted in the file and it changes the css look but not the size and events still dont show up. Any help would be appreciated.
                    Subintro @Guest
                    @Sean
                    Damn, I appreciate you trying to take a look but I technically cant due to HIPAA compliance.
                    Have you heard of anyone having any issues with the auth before?
                    • W Offline
                      wegz15
                      So, I tried a public google calendar as well as 2 of my private shared google calendars. The shared public one does not work, 1 of my shared one works, and 1 does not within the module. However, all of these calendars work in the default upcoming events module. Any suggestions on why this is? Also, I tried changing the “calendarfetcher.js” in the default calendar folder and with that change the default calendar stopped working, but the mmm-calendarext2 worked.
                      W ? 2 Replies Last reply Reply Quote 0
                      • W Offline
                        wegz15 @wegz15
                        I think I figured out the problem. I can see other recent events added to these calendars. I think since they are older calendars they fall outside of the maxItems: 100, beforeDays: 60, afterDays: 365, maxIterations: 100 ranges. I tried adjusting those to go back to the start of the calendars and when I do it doesn’t pull in any events from any of my calendars. I’m not sure how to fix this.
                          A Former User @wegz15
                          @wegz15
                          maybe some repeated events couldn’t be parsed. this is using different parser with default module. it is faster and has more features. but occasionally it fails some repeated events.
                          i’m researching how to improve but not yet success. i may return but need more time to consider.
                            @wegz15
                            anyway, can you send me your ics url and configuration? my mail is eouia0819@gmail.com
                              @wegz15
                              Now I think found something. set your maxIteration to 1000.
                              The reason is, your “Red Shift” events is started from too past, so even after 100(default value) occurrences it couldn’t reach to present age.
                              • W Offline
                                wegz15
                                Yep, that worked. Thank you. I tried that, but I had it in the wrong spot. Its been trial and error trying to learn which values effect what on the main screen. If any one knows, is there a way to make the calendar not try to take up the full screen with the normal size text? Maybe use the % somewhere? I also have not been able to figure out how to get rid of the week number, I’m somehow missing a day, and I can’t figure out a way to get rid of the “last tuesday, Yesterday, today”. I’d also like to make that bottom weather “shorter”.
                                Im just not sure how or where to edit these values. Is there maybe a tutorial or video to learn how to “edit” magicmirror and modules?
                                ? C 2 Replies Last reply Reply Quote 0
                                  @wegz15
                                  month or week view might be too huge even for 1920*1080 size.
                                  • To get rid of week number, open your css/custom.css then add this.
                                  .CX2 .weeksmark {
                                    display:none;
                                  • To adjust day format, add this in your view configuration
                                  slotTitleFormat: "D",
                                  slotSubTitleFormat: "ddd",
                                  I think you’ve set above fields in defaultSet, but each view can have it’s own setting. Especially, week and month could have different behaviors with other views for settings. Read the wiki carefully. https://github.com/eouia/MMM-CalendarExt2/wiki/2d.-Configuration:defaultSet
                                  • W Offline
                                    wegz15
                                    I guess what is confusing me the most is where to actually put each piece. I have that in currently and I am still seeing the “last, next today…”
                                    module: 'MMM-CalendarExt2',
                                    		scenes:[
                                    				views: ["Monthly"],
                                    		views:[
                                    				mode: "Month",
                                    				locale: "en",
                                    				slotMaxHeight: "70px",
                                    				dateFormat: "M/D",
                                    				weeksFormat: " ",
                                    				slotSubTitle:"ddd",
                                    				slotSubTitle:"",
                                    				dateTimeFormat: "ddd mm/dd",
                                    				timeFormat:"h:mm A",
                                    				slotCount: 5,
                                    				showWeekends: true,
                                    				hideOverflow: true,
                                    				filterPassedEvent: false,
                                    				calendars: ["Work"],
                                    And I guess I’m asking if in general there is a way to scale the whole module so I can have a whole calendar fit into the open space. Thank you for all the help so far. This is my 3rd “day” working with magicmirror.
                                      Very weird. I use your configuration (even with your ics)
                                      And this is what my screen shows.
                                      There might be more configuration values than you posted. Give me whole configuration.
                                      • W Offline
                                        wegz15
                                        I emailed you my whole set up earlier. I think there is something, somewhere in another folder I must have messed with. I deleted everything but my clock and pasted just the calendar and it is showing up as pictured. Maybe a fresh install of MM or MMM-calendarext2. 0_1558118108866_Screenshot (1).png
                                          Jerrylein
                                          @Sean thanks for the great module.
                                          I would like to change the design of calendar as in calendarext (Weekdays and monthTitleFormat)
                                          alt text
                                          is this possible or should I use calendarext v1?
                                          ? D 2 Replies Last reply Reply Quote 0
                                            A Former User @Jerrylein
                                            @Jerrylein
                                            weekdays name could be cutomizable, but calext2 doesn’t have monthtitle on monthview
                                            • 24
                                            • 25
                                            • 2 / 25
