    At my Wits end! Overscan/Underscan. Nothing changes
    11 Posts 4 Posters 6.1k Views 4 Watching
      JonoGee
      Hi Folks
      I have played around with this for hours on end. I have the Raspi up and running and have got MagicMirror installed. But for the love of money I can’t get the screen to stop overflowing past the edge of the monitor. The image I can see if too big for the screen i am using.
      In Raspi Configuration I have tried Underscan both Enabled and Disabled.
      In the config file i have tried allsorts of combinations of the following code…
      disable_overscan=1
      overscan_left=39
      overscan_right=39
      overscan_top=25
      overscan_bottom=23
      framebuffer_width=1920
      framebuffer_height=1080
      hdmi_group=1
      hdmi_mode=16
      Whether disabled or not, positive or negative values nothing makes any difference the the results I get.
      Its like a setting somewhere is overriding any of these settings.
      Can someone please take pity of a guy whose gonna rip his hair out anytime soon.
      Best Regards
        is this the pi desktop that is too big, or the MagicMirror UI ?
          JonoGee @sdetweil
          @sdetweil It is the Pi desktop that is too big mate. but equally makes the MM too big too when launched.
            sdetweil @JonoGee
            @JonoGee ok… don’t have a solution myself, just trying to help others get clear idea of problem… I searched and all the things I saw are the same as what you have done
            • evroomE Offline
              evroom
              @JonoGee
              See these URLs for details, if not known already:
              https://www.raspberrypi.org/documentation/configuration/hdmi-config.md
              https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
              Can you try this ?
              $ tvservice -m CEA
              $ tvservice -m DMT
              This will give you the hdmi_group that can be used and the preferred hdmi_mode.
              hdmi_group=1
              hdmi_mode=16
              This means CEA 1080p @60Hz.
              And what happens when you comment out disable_overscan and the overscan settings ?
              MagicMirror version: 2.35.0
              Test environment:
              MagicMirror version: 2.36.0-develop
                JonoGee @evroom
                @evroom
                Hi buddy,
                I tried disabling out all overscan settings etc. It didn’t make the slightest change, neither did…
                hdmi_group=1
                hdmi_mode=16
                I am not sure where i should be putting…
                $ tvservice -m CEA
                $ tvservice -m DMT
                I checked out those links and nothing I do at all makes any change whatsoever. I see no adjustment or anything. I’d be happy if i did then i could keep adjusting, rebooting, and re-adjust accordingly until it was right.
                THankyou for your time anyway trying to help me sort this. I really appreciate it.
                BR
                • evroomE Offline
                  evroom
                  @JonoGee said in At my Wits end! Overscan/Underscan. Nothing changes:
                  They are not config entries.
                  Just execute those commands from the command-line.
                  The config file entries in your first post, are they yours or just an example ?
                  Let’s start with the tvservice commands.
                  Please post the output, then we take it from there.
                  $ tvservice -m CEA
                  $ tvservice -m DMT
                  $ tvservice -s
                  Not an expert on the topic, but who knows we straighten this out together :-)
                  Test environment:
                  • cirdanC Offline
                    cirdan
                    Sometimes you can fix/set overscan in the menu of the monitor, may be this helps?
                    Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
                      JonoGee @cirdan
                      @cirdan It was displaying fine with a black border actually during the Raspi setup and I ticked something during setup and its been like this since.
                        JonoGee
                        Any other device, PC, DVD Player, PS4, what ever i plug it its fine. Raspi homepage. spilling outside screen area.
                        • evroomE Offline
                          evroom
                          @JonoGee
                          Did you ever touch the /boot/config.txtfile ?
                          Or only did the config using $ sudo raspi-config or via the GUI ?
                          It can be you selected Overscan there.
                          Can you also show the output of this command ?
                          $ cat /boot/config.txt | grep -v '^#' | egrep 'overscan|framebuffer|hdmi|dtoverlay'
                          Test environment:
