    At my Wits end! Overscan/Underscan. Nothing changes
    11 Posts 4 Posters 5.7k Views 4 Watching
      JonoGee @evroom
      @evroom
      Hi buddy,
      I tried disabling out all overscan settings etc. It didn’t make the slightest change, neither did…
      hdmi_group=1
      hdmi_mode=16
      I am not sure where i should be putting…
      $ tvservice -m CEA
      $ tvservice -m DMT
      I checked out those links and nothing I do at all makes any change whatsoever. I see no adjustment or anything. I’d be happy if i did then i could keep adjusting, rebooting, and re-adjust accordingly until it was right.
      THankyou for your time anyway trying to help me sort this. I really appreciate it.
      BR
      • evroomE Online
        evroom
        @JonoGee said in At my Wits end! Overscan/Underscan. Nothing changes:
        They are not config entries.
        Just execute those commands from the command-line.
        The config file entries in your first post, are they yours or just an example ?
        Let’s start with the tvservice commands.
        Please post the output, then we take it from there.
        $ tvservice -m CEA
        $ tvservice -m DMT
        $ tvservice -s
        Not an expert on the topic, but who knows we straighten this out together :-)
        MagicMirror version: 2.33.0
        Test environment:
        MagicMirror version: v2.33.0
        • cirdanC Offline
          cirdan
          Sometimes you can fix/set overscan in the menu of the monitor, may be this helps?
          Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
            JonoGee @cirdan
            @cirdan It was displaying fine with a black border actually during the Raspi setup and I ticked something during setup and its been like this since.
              JonoGee
              Any other device, PC, DVD Player, PS4, what ever i plug it its fine. Raspi homepage. spilling outside screen area.
              • evroomE Online
                evroom
                @JonoGee
                Did you ever touch the /boot/config.txtfile ?
                Or only did the config using $ sudo raspi-config or via the GUI ?
                It can be you selected Overscan there.
                Can you also show the output of this command ?
                $ cat /boot/config.txt | grep -v '^#' | egrep 'overscan|framebuffer|hdmi|dtoverlay'
                Test environment:
