    At my Wits end! Overscan/Underscan. Nothing changes
    11 Posts 4 Posters 6.6k Views 4 Watching
      is this the pi desktop that is too big, or the MagicMirror UI ?
        JonoGee @sdetweil
        @sdetweil It is the Pi desktop that is too big mate. but equally makes the MM too big too when launched.
          sdetweil @JonoGee
          @JonoGee ok… don’t have a solution myself, just trying to help others get clear idea of problem… I searched and all the things I saw are the same as what you have done
          • evroomE Offline
            evroom
            @JonoGee
            See these URLs for details, if not known already:
            https://www.raspberrypi.org/documentation/configuration/hdmi-config.md
            https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
            Can you try this ?
            $ tvservice -m CEA
            $ tvservice -m DMT
            This will give you the hdmi_group that can be used and the preferred hdmi_mode.
            hdmi_group=1
            hdmi_mode=16
            This means CEA 1080p @60Hz.
            And what happens when you comment out disable_overscan and the overscan settings ?
            MagicMirror version: 2.37.0
              JonoGee @evroom
              @evroom
              Hi buddy,
              I tried disabling out all overscan settings etc. It didn’t make the slightest change, neither did…
              hdmi_group=1
              hdmi_mode=16
              I am not sure where i should be putting…
              $ tvservice -m CEA
              $ tvservice -m DMT
              I checked out those links and nothing I do at all makes any change whatsoever. I see no adjustment or anything. I’d be happy if i did then i could keep adjusting, rebooting, and re-adjust accordingly until it was right.
              THankyou for your time anyway trying to help me sort this. I really appreciate it.
              BR
              • evroomE Offline
                evroom
                @JonoGee said in At my Wits end! Overscan/Underscan. Nothing changes:
                They are not config entries.
                Just execute those commands from the command-line.
                The config file entries in your first post, are they yours or just an example ?
                Let’s start with the tvservice commands.
                Please post the output, then we take it from there.
                $ tvservice -m CEA
                $ tvservice -m DMT
                $ tvservice -s
                Not an expert on the topic, but who knows we straighten this out together :-)
                • cirdanC Offline
                  cirdan
                  Sometimes you can fix/set overscan in the menu of the monitor, may be this helps?
                  Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
                    JonoGee @cirdan
                    @cirdan It was displaying fine with a black border actually during the Raspi setup and I ticked something during setup and its been like this since.
                      JonoGee
                      Any other device, PC, DVD Player, PS4, what ever i plug it its fine. Raspi homepage. spilling outside screen area.
                      • evroomE Offline
                        evroom
                        @JonoGee
                        Did you ever touch the /boot/config.txtfile ?
                        Or only did the config using $ sudo raspi-config or via the GUI ?
                        It can be you selected Overscan there.
                        Can you also show the output of this command ?
                        $ cat /boot/config.txt | grep -v '^#' | egrep 'overscan|framebuffer|hdmi|dtoverlay'
