    Mirror supplier - Stockholm, Sweden
    17 Posts 8 Posters 17.1k Views 7 Watching
      meanmidge
      Hello all,
      New here, love the project! Saw it yesterday, already got everything at home except the glass/ mirror.
      Is there anyone in/around Stockholm who knows a decent place to get a custom sized piece of 2-way mirror cut?
      I have an existing mirror/ cabinet in my bathroom that I’d like to dedicate half of for the project…
      Any help would be appreciated.
      (tried searching, btw- might just be blinded by work at the moment, but can’t wait to get home to start making this project a reality)
      N GooMagicG 2 Replies Last reply Reply Quote 0
      • N Offline
        Notumlord @meanmidge
        @meanmidge
        I had the same problem i Gothenburg, couldn’t find any suppliers other then making a custom order from glassmakers which would cost around 2000SEK for my mirror. What i did instead was buy regular clear windows glass and attach a 2way mirror film instead which turned out pretty good.
          meanmidge @Notumlord
          @Notumlord
          any chance that you could share a photo of how your build turned out? I am a bit on the fence with how to finish it…
          thanks.
          • N Offline
            @meanmidge Sure, i’ll post a pic once i get home from work.
            • O Offline
              OlofL
              @Notumlord did u get home from work yet?
              • GooMagicG Offline
                GooMagic @meanmidge
                @meanmidge I ordered a glass (170 x 65 cm) cut in Norrköping and mirror film from MD Supplies (http://www.mdpsupplies.se/onewaymirror.asp). I plan to finish the mirror this wekeend. I’ll try to remember to post a picture then.
                • N Offline
                  Notumlord @OlofL
                  @OlofL
                  Oh sorry, totally forgot to upload my mirror, i’ll be sure to do it once i get home.
                  @GooMagic That’s the same place i bought my mirror film from.
                    meanmidge
                    thanks, still looking forward to seeing some decent photos of the film. most of the ones i have seen with film were nightmare-ish.
                    And thank god that you made it home from work finally notum ;) we were worried about you for a while!
                    • N Offline
                      Notumlord
                      Here you go, the quality isnt the best but hopefully good enough for you to get an idea what the result could look like. :)
                      http://imgur.com/a/FiAWC
                      • yawnsY Offline
                        yawns Moderator @Notumlord
                        @Notumlord cool, looks good except the small part at the top, there seem to be some bubbles, right?
                        • N Offline
                          Notumlord @yawns
                          @yawns Yep, those are some small bubbles
                          • giovannaG Offline
                            giovanna
                            Hiya all! So, would there be somewhere in Stockholm where you can actually get hold of a proper mirror as I know I’d mess things up applying film (as by MDP) myself. I got a little bit of a large donor, two if the widest STAVE by IKEA so I’m sure tinkering with film is not an option. It would be ideal to be able to go and see it irl as well. Glass would prolly be to heavy for me I assume. /Gio
                            • brobergB Offline
                              broberg Project Sponsor
                              If someone is having troubles getting a proper mirror in Sweden, get to a local Glass-company and ask if they buy glass from Pilkington. If not, try another company.
                              If they do, get them to order the Pilkington Mirropane Chrome for you.
                              (https://www.pilkington.com/sv-se/se/produkter/funktionsomrade/specialglas/pilkington-mirropane-chrome#allmnt)
                              I received mine a couple of days ago from the local glass-company (Nöjds glas i Åtvidaberg),
                              120cm x 60cm, 6mm thick. cost me 1500Sek (that would be around 150 Eur depending on the currency rate).
                              It’s a 20x better mirror than the crappy foil I first ordered, I’m really happy with the glass.
                              Edit : Pilkington also has their MirroView glass with higher light transmission.
                              (The mirropane has 3%, the mirroview has 20% and 45% light transmission. 3% could be slightly dim in bright rooms)
                              MrHM 1 Reply Last reply Reply Quote 1
                              • MrHM Offline
                                MrH @broberg
                                @broberg Any chance you could provide a couple of photos of your mirror? 3% sounds really low… Thanks for the tip
                                brobergB 2 Replies Last reply Reply Quote 0
                                • brobergB Offline
                                  broberg Project Sponsor @MrH
                                  @MrH will try to get some pictures up tonight, yes 3% isn’t optimal, it works in the current room it’s in, but I’m afraid that it won’t be usable in the room it will be in when it’s finished. To late for me, but thats why I suggest the MirrowView also :)
                                  • brobergB Offline
                                    @MrH
                                    Sorry about the quality of the photo, but this is what it looks like in it’s current lighting condition, 3% mirropane in a medium lit room. (the screen is also not up against the glass since it just for you to see the light transmission)
                                    0_1483891444565_IMG_20170108_165224.jpg image url)
                                    MrHM 1 Reply Last reply Reply Quote 0
                                    • MrHM Offline
                                      MrH @broberg
                                      @broberg thanks! well that looks pretty good for 3%. My supplier has a 8% mirror and I didn’t think it would be enough but perhaps I should give it a try :)
