    Mirror supplier - Stockholm, Sweden
    17 Posts 8 Posters 16.6k Views 7 Watching
    • GooMagicG Offline
      GooMagic @meanmidge
      @meanmidge I ordered a glass (170 x 65 cm) cut in Norrköping and mirror film from MD Supplies (http://www.mdpsupplies.se/onewaymirror.asp). I plan to finish the mirror this wekeend. I’ll try to remember to post a picture then.
      • N Offline
        Notumlord @OlofL
        @OlofL
        Oh sorry, totally forgot to upload my mirror, i’ll be sure to do it once i get home.
        @GooMagic That’s the same place i bought my mirror film from.
          meanmidge
          thanks, still looking forward to seeing some decent photos of the film. most of the ones i have seen with film were nightmare-ish.
          And thank god that you made it home from work finally notum ;) we were worried about you for a while!
          • N Offline
            Notumlord
            Here you go, the quality isnt the best but hopefully good enough for you to get an idea what the result could look like. :)
            http://imgur.com/a/FiAWC
            • yawnsY Offline
              yawns Moderator @Notumlord
              @Notumlord cool, looks good except the small part at the top, there seem to be some bubbles, right?
              • N Offline
                Notumlord @yawns
                @yawns Yep, those are some small bubbles
                • giovannaG Offline
                  giovanna
                  Hiya all! So, would there be somewhere in Stockholm where you can actually get hold of a proper mirror as I know I’d mess things up applying film (as by MDP) myself. I got a little bit of a large donor, two if the widest STAVE by IKEA so I’m sure tinkering with film is not an option. It would be ideal to be able to go and see it irl as well. Glass would prolly be to heavy for me I assume. /Gio
                  • brobergB Offline
                    broberg Project Sponsor
                    If someone is having troubles getting a proper mirror in Sweden, get to a local Glass-company and ask if they buy glass from Pilkington. If not, try another company.
                    If they do, get them to order the Pilkington Mirropane Chrome for you.
                    (https://www.pilkington.com/sv-se/se/produkter/funktionsomrade/specialglas/pilkington-mirropane-chrome#allmnt)
                    I received mine a couple of days ago from the local glass-company (Nöjds glas i Åtvidaberg),
                    120cm x 60cm, 6mm thick. cost me 1500Sek (that would be around 150 Eur depending on the currency rate).
                    It’s a 20x better mirror than the crappy foil I first ordered, I’m really happy with the glass.
                    Edit : Pilkington also has their MirroView glass with higher light transmission.
                    (The mirropane has 3%, the mirroview has 20% and 45% light transmission. 3% could be slightly dim in bright rooms)
                    MrHM 1 Reply Last reply Reply Quote 1
                    • MrHM Offline
                      MrH @broberg
                      @broberg Any chance you could provide a couple of photos of your mirror? 3% sounds really low… Thanks for the tip
                      brobergB 2 Replies Last reply Reply Quote 0
                      • brobergB Offline
                        broberg Project Sponsor @MrH
                        @MrH will try to get some pictures up tonight, yes 3% isn’t optimal, it works in the current room it’s in, but I’m afraid that it won’t be usable in the room it will be in when it’s finished. To late for me, but thats why I suggest the MirrowView also :)
