    Raspberry Pi 4 Released !
    65 Posts 16 Posters 55.4k Views 13 Watching
      SH20192
      Base package installed and runs fine. Moving on to the modules now.
        SH20192
        All my modules work except MMM-SingleStock. So far it loads much faster than the Pi 3. I had to abandon using MM2 because I could not run it for more than 3 hours without crashing. Fingers crossed the 4 is more stable. Will let it run overnight to see.
          dazza120 @SH20192
          @SH20192 said in Raspberry Pi 4 Released !:
          Yeah my Pi 3 seems to run out of memory, I opted for 4Gb model should have enough grunt to run everything with any issues
            SH20192 @dazza120
            @dazza120 Pi 4 has been running for 10 hours now and no issues. Had never been able to run the Pi 3 overnight so I think we have a winner!
            Cr4z33C 1 Reply Last reply Reply Quote 2
            • Cr4z33C
              Cr4z33 @SH20192
              @SH20192 are you using any cooling system and if yes what? :)
                SH20192 @Cr4z33
                @Cr4z33 said in Raspberry Pi 4 Released !:
                Yes, a small fan on an open plexiglass case. No heatsink. Without the fan it would complain about overheating.
                Should mention it’s running 4 RTSP streams.
                • lavolp3L
                  lavolp3 Module Developer @SH20192
                  @SH20192 MM system works without changes on Raspbian Buster with the new kernel?
                  I’m positively surprised…
                  Gotta order a second one. Lol!
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                  D S 2 Replies Last reply Reply Quote 1
                    dazza120 @lavolp3
                    @lavolp3 said in Raspberry Pi 4 Released !:
                    Can I just upgrade the Pi 3 to the Buster OS so i can just swap the ssd over. Can someone confirm if it’s a plug and play boot from OS on an SSD? Rather than through the bios bit to enable it. Really looking forward to this PI I might get a heat sink but I want a big one not the little ones, need to see if I still have the one from the sky box, got a fan already for it but only activates when the TV is on
                      SH20192 @lavolp3
                      Except for the one module mentioned above everything working for me on Buster. Haven’t looked at logs or anything to see if there are errors being thrown that I don’t notice but so far so good.
                      • Cr4z33C
                        Cr4z33 @SH20192
                        @SH20192 I see.
                        I will start with an old Intel heatsink.
                        I got very good cooling results with a Rock Pi 4 B so I don’t think it will be any worse hehe.
                          dazza120 @Cr4z33
                          @SH20192 I see.
                          Would that even fit on the Pi?
                            SH20192
                            Unfortunately didn’t make it 24 hours of being up. :(
                              dazza120 @SH20192
                              Nooooooooooo with that spec I wouldn’t have thought there would be any problems 🤦🏾‍♂️😢
                              • Cr4z33C
                                Cr4z33 @dazza120
                                @dazza120 ouch correct. :smiling_face_with_open_mouth_cold_sweat:
                                On the other board I could place it on the bottom side while on the Rpi you can’t.
                                  SH20192 @dazza120
                                  @dazza120 said in Raspberry Pi 4 Released !:
                                  Me too. The first test I just lost the HDMI signal but it seemed to be up. Second test it all locked up around 4 hours in.
                                  • Cr4z33C
                                    Cr4z33 @SH20192
                                    @SH20192 just out of curiosity were you running MagicMirror?
                                    And if so were you running MMM-Spotify?
                                    I ask because last update of this module is giving me a black screen.
                                    My Rpi 4 arrived a couple of hours ago, but I still have to take it out of the box.
                                    S S 2 Replies Last reply Reply Quote 0
                                      sdetweil @Cr4z33
                                      @Cr4z33 black screen means error in the UI code… so, open the developers window, ctrl-shift-i, select the console tab, and scroll up to find the error…
                                        SH20192 @Cr4z33
                                        Yes to MagicMirror. Only thing running on it. I was not running Spotify.
                                          dazza120 @SH20192
                                          is it over heating? ETA prime has his overclocked to 1.7Ghz CPU and 600Mhz on the GPU 😳 it must be on fire 🔥 😂
                                            SH20192 @dazza120
                                            Probably not. There was a fan on it.
                                            • 2 / 4
