    Raspberry Pi 4 Released !
    65 Posts 16 Posters 56.7k Views 13 Watching
    • lavolp3L
      lavolp3 Module Developer @SH20192
      @SH20192 MM system works without changes on Raspbian Buster with the new kernel?
      I’m positively surprised…
      Gotta order a second one. Lol!
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      D S 2 Replies Last reply
        dazza120 @lavolp3
        @lavolp3 said in Raspberry Pi 4 Released !:
        Can I just upgrade the Pi 3 to the Buster OS so i can just swap the ssd over. Can someone confirm if it’s a plug and play boot from OS on an SSD? Rather than through the bios bit to enable it. Really looking forward to this PI I might get a heat sink but I want a big one not the little ones, need to see if I still have the one from the sky box, got a fan already for it but only activates when the TV is on
        lavolp3L 1 Reply Last reply
          SH20192 @lavolp3
          Except for the one module mentioned above everything working for me on Buster. Haven’t looked at logs or anything to see if there are errors being thrown that I don’t notice but so far so good.
          • Cr4z33C
            Cr4z33 @SH20192
            @SH20192 I see.
            I will start with an old Intel heatsink.
            I got very good cooling results with a Rock Pi 4 B so I don’t think it will be any worse hehe.
            D 1 Reply Last reply
              dazza120 @Cr4z33
              @Cr4z33 said in Raspberry Pi 4 Released !:
              @SH20192 I see.
              Would that even fit on the Pi?
              Cr4z33C 1 Reply Last reply
                SH20192
                Unfortunately didn’t make it 24 hours of being up. :(
                  dazza120 @SH20192
                  @SH20192 said in Raspberry Pi 4 Released !:
                  Nooooooooooo with that spec I wouldn’t have thought there would be any problems 🤦🏾‍♂️😢
                  • Cr4z33C
                    Cr4z33 @dazza120
                    @dazza120 ouch correct. :smiling_face_with_open_mouth_cold_sweat:
                    On the other board I could place it on the bottom side while on the Rpi you can’t.
                      SH20192 @dazza120
                      @dazza120 said in Raspberry Pi 4 Released !:
                      Me too. The first test I just lost the HDMI signal but it seemed to be up. Second test it all locked up around 4 hours in.
                      • Cr4z33C
                        Cr4z33 @SH20192
                        @SH20192 just out of curiosity were you running MagicMirror?
                        And if so were you running MMM-Spotify?
                        I ask because last update of this module is giving me a black screen.
                        My Rpi 4 arrived a couple of hours ago, but I still have to take it out of the box.
                        S S 2 Replies Last reply
                          sdetweil @Cr4z33
                          @Cr4z33 black screen means error in the UI code… so, open the developers window, ctrl-shift-i, select the console tab, and scroll up to find the error…
                            SH20192 @Cr4z33
                            Yes to MagicMirror. Only thing running on it. I was not running Spotify.
                              dazza120 @SH20192
                              is it over heating? ETA prime has his overclocked to 1.7Ghz CPU and 600Mhz on the GPU 😳 it must be on fire 🔥 😂
                                SH20192 @dazza120
                                Probably not. There was a fan on it.
                                • Cr4z33C
                                  Cr4z33
                                  My issue with the Pi and MM is different.
                                  After installing MM, configuring autostart I rebooted, but now the max resolution is 1024x768… 😣
                                  • Cr4z33C
                                    Cr4z33 @Cr4z33
                                    OK problem sorted and… one suggestion for every body going to buy a Rpi 4:
                                    DO NOT USE MICRO HDMI TO HDMI ADAPTER! IT’S CRAP AND CAUSES ISSUES WITH HDMI RESOLUTION!
                                    D lavolp3L 2 Replies Last reply
                                      dazza120 @Cr4z33
                                      @Cr4z33 crap that’s all I have PS there is a new update of buster out now see if that is any better, I’m just upgrading my pi 3B+ From stretch to buster does any one know if it boots from SSD as standard? Oh well guess I’ll find out soon😬
                                        dazza120
                                        Well what a bust upgraded it and it won’t display at all, so clean install 👎🏾 Everything running on the Pi 3B+ at the mo, guess no boot from USB for the pi 4 then 😭
                                          bhepler Module Developer
                                          The local retailer was sold out. So I bought another Raspi 3B+. Looks like I’m building another mirror. :)
                                          • lavolp3L
                                            lavolp3 Module Developer @Cr4z33
                                            @Cr4z33 ho ho, hold on you’re quite fast here with your conclusions.
                                            What else should one do to deliver the picture via HDMI?
                                            Have you heard of more people having problems with HDMI adapters and the Pi 4?
                                            • 2 / 4
