    Raspberry Pi 4 Released !
    65 Posts 16 Posters 56.7k Views 13 Watching
      SH20192
      Unfortunately didn’t make it 24 hours of being up. :(
      D 1 Reply Last reply
        dazza120 @SH20192
        @SH20192 said in Raspberry Pi 4 Released !:
        Nooooooooooo with that spec I wouldn’t have thought there would be any problems 🤦🏾‍♂️😢
        • Cr4z33C
          Cr4z33 @dazza120
          @dazza120 ouch correct. :smiling_face_with_open_mouth_cold_sweat:
          On the other board I could place it on the bottom side while on the Rpi you can’t.
            SH20192 @dazza120
            @dazza120 said in Raspberry Pi 4 Released !:
            Me too. The first test I just lost the HDMI signal but it seemed to be up. Second test it all locked up around 4 hours in.
            Cr4z33C 1 Reply Last reply
            • Cr4z33C
              Cr4z33 @SH20192
              @SH20192 just out of curiosity were you running MagicMirror?
              And if so were you running MMM-Spotify?
              I ask because last update of this module is giving me a black screen.
              My Rpi 4 arrived a couple of hours ago, but I still have to take it out of the box.
              S S 2 Replies Last reply
                sdetweil @Cr4z33
                @Cr4z33 black screen means error in the UI code… so, open the developers window, ctrl-shift-i, select the console tab, and scroll up to find the error…
                  SH20192 @Cr4z33
                  @Cr4z33 said in Raspberry Pi 4 Released !:
                  Yes to MagicMirror. Only thing running on it. I was not running Spotify.
                    dazza120 @SH20192
                    is it over heating? ETA prime has his overclocked to 1.7Ghz CPU and 600Mhz on the GPU 😳 it must be on fire 🔥 😂
                      SH20192 @dazza120
                      Probably not. There was a fan on it.
                      • Cr4z33C
                        Cr4z33
                        My issue with the Pi and MM is different.
                        After installing MM, configuring autostart I rebooted, but now the max resolution is 1024x768… 😣
                        • Cr4z33C
                          Cr4z33 @Cr4z33
                          OK problem sorted and… one suggestion for every body going to buy a Rpi 4:
                          DO NOT USE MICRO HDMI TO HDMI ADAPTER! IT’S CRAP AND CAUSES ISSUES WITH HDMI RESOLUTION!
                          D lavolp3L 2 Replies Last reply
                            dazza120 @Cr4z33
                            @Cr4z33 crap that’s all I have PS there is a new update of buster out now see if that is any better, I’m just upgrading my pi 3B+ From stretch to buster does any one know if it boots from SSD as standard? Oh well guess I’ll find out soon😬
                              dazza120
                              Well what a bust upgraded it and it won’t display at all, so clean install 👎🏾 Everything running on the Pi 3B+ at the mo, guess no boot from USB for the pi 4 then 😭
                                bhepler Module Developer
                                The local retailer was sold out. So I bought another Raspi 3B+. Looks like I’m building another mirror. :)
                                • lavolp3L
                                  lavolp3 Module Developer @Cr4z33
                                  @Cr4z33 ho ho, hold on you’re quite fast here with your conclusions.
                                  What else should one do to deliver the picture via HDMI?
                                  Have you heard of more people having problems with HDMI adapters and the Pi 4?
                                  How to troubleshoot modules
                                  MMM-soccer v2, MMM-AVStock
                                  • lavolp3L
                                    lavolp3 Module Developer @dazza120
                                    Can I just upgrade the Pi 3 to the Buster OS so i can just swap the ssd over. Can someone confirm if it’s a plug and play boot from OS on an SSD? Rather than through the bios bit to enable it. Really looking forward to this PI I might get a heat sink but I want a big one not the little ones, need to see if I still have the one from the sky box, got a fan already for it but only activates when the TV is on
                                    No you can’t!
                                    But I guess you know that by now.
                                    Buster on the Pi3B+ and Buster on the Pi 4 need different kernel drivers.
                                    So just switching the card won’t work.
                                    A clean install is the best way at least on the Pi 4.
                                    After all you can try to just move the MM directory to the Pi 4, but honestly I would install the modules and dependencies again as well.
                                      dazza120 @lavolp3
                                      @lavolp3 said in Raspberry Pi 4 Released !:
                                      No you can’t!
                                      Yeah learnt this the hard way 😂, but right now I can’t even use my pi 4 I need boot from usb as that’s how I’m running my 3B+ Also need my heat sinks to come in so I can see what one to use
                                      lavolp3L 1 Reply Last reply
                                      • lavolp3L
                                        @dazza120 I’m afraid a heatsink won’t help much but am curious about your results. I haven’t had good results with heatsinks in the past.
                                        • Cr4z33C
                                          Cr4z33 @lavolp3
                                          Yes on a Rpi Facebook group.
                                          It surely might depend also on what adapter you are going to use, but don’t expect 100% guarantee that it will work fine at 4K@60Hz.
                                          I spent € 7,00 for that crap adapter, sent it back to Amazon and got a proper micro HDMI to HDMI cable certified for 4K for the same amount.
                                            dazza120 @lavolp3
                                            Only because you haven’t seen my thermal solution lol, this is one seriously hot chip, had it upto 82 for one reading on the stress test but still at 1.5Ghz on the CPU after that reading it dropped to 80degress this is with just the heat sink no fan. 82degress was during my second stress test and that was just one reading the gap between tests was about 30seconds during both tests no CPU throttling happened. I have put a cable tie around the board and heatsink to keep the pressure on it so it transfers good heat. Not the prettiest but behind a tv well it’s not out of place at all. PS the stress test is 100% cpu usage and no let up during the test had task manager up and CPU usage never fell below 💯
                                            1_1562257847858_883A09A1-4444-452C-92CD-6F401131E452.jpeg 0_1562257847857_177EFE9A-8D8A-4D4B-AD2C-6168ABC1BAC1.jpeg
                                            PS works fine on HDMI cable no issues at all
                                            • 2 / 4
