    Hi very beginners question here.
    6 Posts 3 Posters 1.6k Views 3 Watching
      sdetweil @steveuk
      @steveuk it looks good… try running the checker
      npm run check:config
      from the MM folder
      u need all that upper stuff too, right?
        address: "", // Address to listen on, can be:
        port: 8086,
        ipWhitelist: [], // Set [] to allow all IP addresses
        language:  "en",
        timeFormat: 12,
        units: "imperial",
        steveuk @sdetweil
        Hi thanks the reply yeah I have all the upper parts as normal.
        I deleted the file and tried again with a different module following YouTube and got it to work.
        I noticed some of these instructions on the module installation come with extra bits of text I don’t need to copy and paste in, I think I’m confusing myself with when I need the { } and },
        But like I say I did get a module to show up but in the config I put “bottom_right” but it shows on the top left.
        Thanks again.
          sdetweil @steveuk
          @steveuk a module entry will have at LEAST this
              module: 'module_name',
              position: 'some_region_name',
                  // module specific info
          see here for the region definitions
          https://forum.magicmirror.builders/topic/286/regions
            Mykle1 Project Sponsor Module Developer @steveuk
            @steveuk said in Hi very beginners question here.:
            Could someone break it down for me with what I do with the above code on a fresh config file as I’m not actually sure where to do the curser click when I click paste is it after the last closed bracket ?
            It should look like this. Your entry was missing a comma after the last curly bracket.
                        module: 'MMM-Dad-Jokes',
                        position: 'bottom_left', // Or wherever you want
                            updateInterval: 60000,
                            fadeSpeed: 4000
            This will help you understand the format of a config entry.
            https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
              steveuk @Mykle1
              @Mykle1 @sdetweil
              That’s great
              Thanks for the help guys.
