Unsolved Mirror starts not correct
A reinstall wouldnt be the Problem. It is not the first time i have to do this ^^
But i really dont unterstand why he wont start anymore. I also had this before the update, forgot to write. From one to the other the Mirror doesnt starts just with the first start of the day. When i reboot or just unplug the Pi, the mirror starts correct
@thedk said in Mirror starts not correct:
I hope you’re shutting down correctly before pulling the plug on the Pi. Your SD card will likely become corrupted. Just something you should think about.
@Mykle1 one of my sd cards suddenly became read only… no fix…
had to buy new sd card
@Mykle1
I just unplug the Pi sometimes since he is not starting anymore
I know thats not the best way, it’s my 4th Pi ;) -
You can’t choose “Shut Down” from the desktop? Once the shut down is complete, THEN pull the plug to power down the Pi
@sdetweil said in Mirror starts not correct:
had to buy new sd cardSux! :-(
@Mykle1
No i cant. I just can reboot or shutdown the Pi by Terminal.
I know i shouldnt unplug the Pi ^^ -
Jusat am month ago, it starts again, but with an other fault
0|mm | > magicmirror@2.8.0 start /home/pi/MagicMirror 0|mm | > sh run-start.sh 0|mm | /home/pi/MagicMirror/node_modules/electron/dist/electron: relocation error: /home/pi/MagicMirror/node_modules/electron/dist/libffmpeg.so: symbol cnprantf, version GLIBC_2.4 not defined in file libc.so.6 with link time reference 0|mm | npm 0|mm | ERR! file sh 0|mm | npm ERR! code ELIFECYCLE 0|mm | npm ERR! errno ENOENT 0|mm | npm ERR! syscall spawn 0|mm | npm 0|mm | ERR! magicmirror@2.8.0 start: `sh run-start.sh` 0|mm | npm ERR! spawn ENOENT 0|mm | npm 0|mm | ERR! 0|mm | npm ERR! Failed at the magicmirror@2.8.0 start script. 0|mm | npm ERR! This is probably not a problem with npm. There is likely additional logging output above. 0|mm | npm ERR! A complete log of this run can be found in: 0|mm | npm ERR! /home/pi/.npm/_logs/2019-08-12T05_54_45_996Z-debug.log
I didnt changed anything, the error came from one day to the other an i just see the startscreen and the mirror wont start.
Could somebody help?
@thedk Have you upgraded your installation of Raspbian before updating the MM? You would also have to check every module folder that has a package.json and run npm install in the module folder. This has generally worked for most of the guys with the same issue as you have.
I didnt upgrade, i made an complete new installation cause of the issue i had before.
Since two days the mirror has no error and everything goes fine, dont know why. I made no upgrade or similar but will do this now. Maybe the issue is gone with that.
Thanks for your help.
