    MMM-Memo - Add some memos on your page and manage them through HTTP request
    41 Posts 23 Posters 32.0k Views 23 Watching
    • wiresharkW
      wireshark @wireshark
      • N
        nobita @schnibel
        @schnibel , If I would like to make this module without use voice command (Jarvis)
        and add event by manual (like default calendar module), or add event in google calendar
        question: How to do it? Thanks for your help
        • E
          efl23
          Thanks for this great module.
          but when I do this command “http://192.168.0.60:8080/AddMemo?memoTitle=SHOPPING&item=Fruits&level=INFO”, I have this message
          “Cannot GET /AddMemo”
          but this command “http://192.168.0.60:8080” show MagicMirror
          Can you please help me?
          Thanks a lot for you help and support
          E 1 Reply Last reply
          • E
            efl23 @efl23
            @efl23
            Eureka, just a bad name of the module
            • JanneJ
              Janne
              Just a help to other magic Mirror builders.
              I have implemented this nice module. :smiling_face_with_heart-eyes:
              When I send URL-request I got the error “No memo file found”. After some grumbling and deep dive I found that it was because my language was not supported (Danish).
              I added my language-file under the translation directory and added the yellow line.
              Hope it can be of help to others. :smiling_face_with_smiling_eyes:
              Reply Quote 2
                Crayyy
                I still am unable to add or modify the memos in any way :) I don’t understand how to use the HTTP command to pass commands to the module, Here is what I typed at the SSH command prompt. “http://192.168.1.175:8080/AddMemo?memoTitle=SHOPPING&item=Fruits&level=INFO” but I get the following errors and no memo on my mirror :( “-bash: http://192.168.1.175:8080/AddMemo?memoTitle=: No such file or directory
                [7]- Exit 127 http://192.168.1.175:8080/AddMemo?memoTitle=SHOPPING
                [8]+ Done item=Fruits” please help :)
                F 1 Reply Last reply
                • L
                  lovesicker
                  @schnibel
                  Thank you for providing us this fantastic module! It’s so useful.
                  I have a suggestion: could you merge multiple instances of MMM-Memo into only one instance? Like the following:
                  module: ‘MMM-Memo’,
                  config{
                  memo1
                  memoTitle: XXXX
                  position:
                  memo2
                  memoTitle:YYYY
                  position:
                  Because there are six instances of MMM-Memo at least, the system performance will be affected and there are always many notifications about this module in console log when any notifications send by any modules.
                    Robinson128
                    Thank you for this module that I like a lot despite the harm I had to use it without Jarvis. :) beginner in computer science and big noob for HTML CSS and many other things. I search a little but I did not find how to make notes appear after each other in the same memo. The oldest note in 1 and the most recent in 2,3 or 4 and so on. Thanks for your help.
                    (Google traduction)
                    • WasupDudeW
                      WasupDude Banned
                      Such a usefull topic,thanks
                      • WasupDudeW
                        WasupDude Banned
                        • F
                          FruityBebbles @Crayyy
                          @Crayyy same issue… did you find a fix?
                            ok… I installed this module…
                            u define in the config.js a tag to identify acceptable incoming ‘memos’…
                            memoTitle
                            once I did that I was able, in a browser to do
                            http://192.168.2.26:8086/addMemo?memoTitle=testing&item=foobar
                            and I got back
                            {“status”:“success”,“item”:{“memoTitle”:“testing”,“level”:“INFO”,“item”:“foobar”,“timestamp”:“2019-09-16T00:12:05.199Z”}}
                            and a memo appears on the mirror screen
                            192.168.2.26 is my mirror ip address, and 8086 is the port in the config.js
                            in config.,js I have
                              address: "", // Address to listen on, can be:
                              port: 8086,
                              ipWhitelist: [],   // allow anyone to connect
                            if address:“localhost” then only from INSIDE the mirror machine is allowed to make connections to mirror application
                            if I do this
                            the response is
                            {"status":"failed","error":"No 'memoTitle' given."}
                            if I do this
                            where memoTitle matches the value specified in config.js
                                    module: 'MMM-Memo',
                                    position: 'top_left',
                                    classes: 'default everyone',        // if using MMM-ProfileSwitcher module
                                        memoTitle: "testing"
                            then i get this
                            {"status":"failed","error":"No 'item' given."}
                            so, http://192.168.2.26:8086/addMemo?memoTitle=testing&item=
                            note to have multiple memo pages, you need to add the module to the config.js multiple times, with different memoTitle values…
                            readme
                            If you declare several modules in the config/config.js file, you will get several memo notes on your MagicMirror2 profile.
                            • G
                              gschmall
                              There needs to be a config switch to disable the showing of the pin. Like “showPin” which is set to true by default. I have a small mirror and the pin takes up a lot of vertical space.
                                roccodicarlo
                                  roccodicarlo
                                  I installed jarvis and have it sort of working but I am not sure how you convert numbers that are text (one, two, three) from the STT engine to integers for the phone number or memo item number etc. that must be included in the HTTP get quest
                                  • E
                                    Ernst
                                    Hello
                                    Maybe it is off use to anyone
                                    I made a html offline document on my phone to add and remove items from memo’s.
                                    It is not super clean but it is an start :face_with_stuck-out_tongue_winking_eye:
                                    alt text
                                    http://192.168.178.23:8080/AddMemo?memoTitle=TODO&item=LED%20Driver&level=INFO
                                    http://192.168.178.23:8080/RemoveMemo?memoTitle=TODO&item=1
                                    <a href="//192.168.178.23:8080/RemoveMemo?memoTitle=TODO&item=1"><button type="submit">Item 1</button>
                                    <html>
                                      <head>
                                        <title>Smart mirror form</title>
                                        <style>
                                          body, div, form, input, select, p {
                                          font-family: Roboto, Arial, sans-serif;
                                          font-size: 14px;
                                          color: #666;
                                          h1 {
                                          margin: 0;
                                          font-weight: 400;
                                          h3 {
                                          margin: 12px 0;
                                          color: #8ebf42;
                                          .main-block {
                                          display: flex;
                                          justify-content: center;
                                          align-items: center;
                                          background: #fff;
                                          form {
                                          width: 80%;
                                          padding: 20px;
                                          fieldset {
                                          border: 1px solid #8ebf42;
                                          label {
                                          padding: 0 5px;
                                          text-align: right;
                                          vertical-align: middle;
                                          input {
                                          padding: 5px;
                                          .checkbox {
                                          margin-bottom: 10px;
                                          select {
                                          background: transparent;
                                    	  width: 100px;
                                          .checkbox input, .children input {
                                          width: auto;
                                          margin: -2px 10px 0 0;
                                          .checkbox a {
                                          color: #8ebf42;
                                          .checkbox a:hover {
                                          color: #82b534;
                                          button {
                                          width: 75px;
                                          padding: 10px 0;
                                          margin: 10px auto;
                                          border-radius: 5px;
                                          border: none;
                                          background: #8ebf42;
                                          font-size: 14px;
                                          font-weight: 600;
                                          color: #fff;
                                          button:hover {
                                          background: #82b534;
                                          label {
                                          width: 40%;
                                          input {
                                          width: 100px;
                                    	  .center {
                                    		margin-left: auto;
                                    		margin-right: auto;
                                    		table {
                                    			width: 80%;
                                    			border: 1px solid black;
                                        </style>
                                      </head>
                                      <body>
                                      <center>
                                        <div class="main-block">
                                    	<!-- http://192.168.178.23:8080/?name=niks
                                        <form action="http://192.168.178.23:8080/AddMemo" method="get">
                                          <h1>Smart mirror</h1>
                                          <fieldset>
                                            <legend>
                                              <h3>Add/Remove item</h3>
                                            </legend>
                                            <fieldset>
                                            <br>
                                            <!--<input type="hidden" name="memoTitle" value="ToDo"> -->
                                    		<label>Add item</label><input type="text" name="item" required>
                                    		<select name="memoTitle" >
                                    		        <option value="" disabled selected hidden> Lijst Name</option>
                                                    <option value="ToDo">ToDo</option>
                                                    <option value="Test">Test</option>
                                            </select>
                                    		<input type="hidden" name="level" value="INFO">
                                          . <button type="submit" href="/">Add</button>
                                    	  </form>
                                    	  </fieldset>
                                    	  <fieldset>
                                        <form action="http://192.168.178.23:8080/RemoveMemo" method="get">
                                    	<label>Remove Item</label>
                                            </select>
                                                  <select name="item" >
                                                    <option value="" disabled selected hidden> Lijst Nr</option>
                                                    <option value="1">1</option>
                                                    <option value="2">2</option>
                                                    <option value="3">3</option>
                                                    <option value="4">5</option>
                                                    <option value="5">5</option>
                                                    <option value="6">6</option>
                                                  </select>
                                         .        <button type="submit" href="/">Remove</button>
                                    	</form>
                                    	<!--<a href="http://192.168.178.23:8080/RemoveMemo?memoTitle=TODO&item=1"><button type="button">Item 1</button> -->
                                      </div>
                                    code_text
                                    • E
                                      Ernst @Ernst
                                      @Ernst
                                      Hmm I can’t post html code here
                                      Does anyone know how?
                                        sdetweil @Ernst
                                        @Ernst u have to have a space after every <
                                        terrible,… no workaround
                                        • E
                                          Ernst @sdetweil
                                          Alright another way :-)
                                          link file
                                          You can download it over there :face_with_stuck-out_tongue_winking_eye:
                                          • 2 / 3
