    Pi 4 storage used up in weeks?
    12 Posts 4 Posters 4.7k Views 4 Watching
      dazza120
      Anyone else having issues with there Pi4 storage SD card being totally full in the matter of weeks? This is a 32gb card running buster but the archive version so is only a 1Gb download OS then it expands to 3Gb or 4Gb which leaves a lot of room for storage still I have only got MMM-Remote-Control-repositories MMM-Remote-control —mmm-SystemStatus mmm-nest-status mmm-hue-lights MMM-NOAA3 with just these I’m left with 0gb of space in the matter is weeks. Is this happening to anyone else?
      • johnnyboyJ Offline
        johnnyboy
        Did you format the SD to use ALL the available space, for MM? and not just allocate it a small portion?
          dazza120 @johnnyboy
          @johnnyboy yes but now thinking it’s a dud card from amazon as this is how much is showing as used and that’s not equivalent to 28Gb
          Size Used Avail Use% Mounted on
          /dev/root 30G 28G 0 100% /
          devtmpfs 1.8G 0 1.8G 0% /dev
          tmpfs 1.9G 16K 1.9G 1% /dev/shm
          tmpfs 1.9G 8.5M 1.9G 1% /run
          tmpfs 5.0M 4.0K 5.0M 1% /run/lock
          tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
          /dev/mmcblk0p1 253M 40M 213M 16% /boot
          tmpfs 386M 0 386M 0% /run/user/1000
          • evroomE Offline
            evroom @dazza120
            @dazza120
            I would suspect either /tmp being filled up or some log directory being filled up.
            Or a log file going AWOL.
            You can try to find out which directory under / is using the most:
            $ sudo find / -xdev -maxdepth 1 -type d -exec du -s {} \; | sort -rn
            When it is working again (perhaps after a reboot you have enough space again), you can look periodically which files are touched / created in the last 60 minutes:
            $ sudo find / -xdev -mmin -60 -type f -exec ls -als  {} \;
            MagicMirror version: 2.37.0
              dazza120 @evroom
              @evroom hi the first pi code just comes up no access and the other code comes up with a lot of other code thats above my pay grade lol, you could be right but its writting something like a Gb every two hours.
              • evroomE Offline
                evroom @dazza120
                @dazza120
                I have no idea what you mean with “first pi code” and “the other code”.
                2 Pi’s with 2 Magic Mirror instances running?
                Do you have ssh access to your Pi 4?
                If / is 100% full it normally does not allow you to.
                You need to have access again and disable all your modules.
                Then check if the / usage is increasing.
                If not, or in normal quantity, then allow the modules again one by one, checking the usage after every step.
                A reboot might grant you access again, or you might need to take the card out and use a card reader to have access via your PC.
                Cleanup /tmp and try to boot from it with your Pi again.
                Free space :
                sudo df -h /
                Usage:
                sudo du -sh /
                sudo du -sh /tmp
                sudo du -sh /home/pi
                Until you have access, trouble shooting is not possible.
                Good luck.
                  dazza120
                  Hi found its the MagicMirror-error.log in /home/pi/.pm2/logs its 7.9Gb and MagicMirror-out.log in /home/pi/.pm2/logs is 3.3Gb with your help ive found it but how do i fix it? looks like its @cowboysdude Module MMM-NOAA3 that is causing the issue never had an issue with this before @cowboysdude can you help?
                  TypeError: Cannot read property 'pollution' of undefined
                      at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:182:35)
                      at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:174:28)
                      at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                      at Request.emit (events.js:182:13)
                      at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
                      at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
                      at Object.onceWrapper (events.js:273:13)
                      at IncomingMessage.emit (events.js:187:15)
                      at endReadableNT (_stream_readable.js:1090:12)
                    dazza120
                    I have disabled the NAAO3 module and enabled the default Weather is working fine, stable 25Gb left of space on the SD card. log file is now just 3bytes so hundred percent MMM-NAAO3 is causing the excessive storage useage.
                    • evroomE Offline
                      evroom @dazza120
                      @dazza120
                      I found this to keep the pm2 log under control, pm2-logrotate:
                      http://pm2.keymetrics.io/docs/usage/log-management/#pm2-logrotate-module
                      Of course the module needs to be fixed, but this could prevent you from getting a full log again.
                      I do not have it in use myself.
                        dazza120 @evroom
                        @evroom thanks but I’ll wait for a fix, everything is running great at the mo so the mirror is nearly ready to go back on the wall I don’t really want to be taking it down again so I’ll wait for a hard fix. But thanks a lot for your help
                        • cowboysdudeC Offline
                          cowboysdude Module Developer @dazza120
                          @dazza120 It is a provider file issue… and that is the air pollution part of it. If you installed a newer version of MM you may have to run npm install in the NOAA3 dir again…
                          I am going to try and run it on the Dev machine right now…
                          I found the issue…go to AirVisual and get a new key… it told me mine was expired…so get a new key and try it again :)
                            dazza120 @cowboysdude
                            @cowboysdude hi the key was still active it had 135days to go, I never even clocked that it had an expiration date. Don’t know why they just can’t give a permanent key I don’t want to be changing it every year 😢 got enough tech to keep on top off lol
