    MM on Mac mini with motion to turn monitor off
    12 Posts 4 Posters 4.9k Views 4 Watching
    • T Offline
      trividar
      I want to use my Mac Mini for my MM. Is there a way to implement motion detection with a cam and disable HDMI or monitor if no motion is capturing? I have this on my raspberry with motion and it works perfectly… this is for my one of the most important things! :smiling_face: thanks for any help…
        dxfan227
        I don’t see why it would be any different from your rpi
        • T Offline
          trividar @dxfan227
          @dxfan227 thank’s for your answer. I don’t know, is there a possibility to install motion on Mac osx and disable HDMI when motion is detected? Is motion compatible with os x?
          • StoffbeuteluweS Offline
            Stoffbeuteluwe Project Sponsor @trividar
            @trividar did you solved the Problem with the motion on Mac mini?
            • T Offline
              trividar @Stoffbeuteluwe
              @Stoffbeuteluwe Sorry for my late answer! No, unfortunately not! I have tried so many things, but I am not able to make it work ;o( Have you tried it?
              S StoffbeuteluweS 2 Replies Last reply Reply Quote 0
              • T Offline
                trividar
                oooh I found something amazing from @Mykle1 .
                I have to try it! Thanks @Mykle1 for that amazing work!
                https://forum.magicmirror.builders/topic/6376/macmirror
                  sdetweil @trividar
                  @trividar i just fixed MMM-SleepWake for mac…
                    @trividar No sorry I can’t found a solution on Mac, I tried logitec hub, and Pulse eight …I’m not able to make it work tv on and off.
                      sdetweil @Stoffbeuteluwe
                      @Stoffbeuteluwe ok, mine doesn’t either. So sleepwake supports hide/show…
                        Stoffbeuteluwe Project Sponsor @sdetweil
                        @sdetweil hide show the modules?
                          @sdetweil harmony hub can be a solution but not in my case because my tv fits exactly in the frame
                          If you have space around your tv you can use it to turn Mac and tv on and off and it works with Alexa
                            @Stoffbeuteluwe yes…
