Move Module to corner
9 Posts 4 Posters 7.5k Views 3 Watching
    andrewchumchal
    How can I move a module more to the corner so i can get ride of the blank space ? Corner Picture Will auto-remove after 30 days
    S 1 Reply Last reply Oct 3, 2016, 10:17 PM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @andrewchumchal
      @andrewchumchal the body has a margin in main.css
      body {
        margin: 60px;
        position: absolute;
        height: calc(100% - 120px);
        width: calc(100% - 120px);
      you could override that in custom.css
      • K Offline
        KirAsh4 Moderator
        Note that if you are trying to move it down, you won’t be able to because the newsfeed module takes up that space. Please look at the various regions on this post: https://forum.magicmirror.builders/topic/286/regions
        A 1 Reply Last reply Oct 3, 2016, 11:07 PM Reply Quote 0
          andrewchumchal @KirAsh4
          @KirAsh4 @strawberry-3-141
          Thanks Guys
            Patrick
            Did it work? I tried it aswell and have the problem, that i just adjust the left-margin?
            (tried it with custom & main.css)
            Can someone help? :-)
            S 1 Reply Last reply Oct 9, 2016, 4:34 PM Reply Quote 0
              strawberry 3.141 Project Sponsor Module Developer @Patrick
              @Patrick the correct css property is called margin-left not left-margin, maybe this was your mistake.
              you can post your css here so we can have a look on it
              P 1 Reply Last reply Oct 9, 2016, 5:05 PM Reply Quote 0
                Patrick @strawberry 3.141
                @strawberry-3.141 sorry for my wrong explanation.
                I just want to reduce the whole margin because my display is to small for weather + clock.
                So i tried to reduce it with the tags:
                • margin: xxx
                • margin-left: xxx in combination with margin-right: xxx
                  both didn’t work.
                  I had the problem that everything just moved to the left instead of providing more space.
                  So i had at the right a huge blank space which wasn’t my plan… (Check the attached picture)
                  Thank you for your help!
                S 1 Reply Last reply Oct 9, 2016, 5:06 PM Reply Quote 0
                  @Patrick I would try this
                  body {
                    margin: 10px;
                    position: absolute;
                    height: calc(100% - 20px);
                    width: calc(100% - 20px);
                  P 1 Reply Last reply Oct 9, 2016, 5:17 PM Reply Quote 0
                    @strawberry-3.141 Thank you! Now it works very well!
                    Don’t know why i didn’t thought about height & width before :D
