    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 136.4k Views 38 Watching
    • A
      AgP42 Project Sponsor Module Developer @lukas1760
      @lukas1760 : Normaly yes, any html/css/javascript file can be executed.
      Did you test to be able to confirm that it works ?
      • A
        AgP42 Project Sponsor Module Developer @smassy
        @smassy
        the configuration of MMM-SmartWebDisplay seams ok
        I don’t know the module MMM-Assistant2, is it this one : https://github.com/eouia/MMM-AssistantMk2 ?
        If not, can you send me the link on it’s documentation ?
        To be able to send a new url to display to the MMM-SmartWebDisplay, the configuration has to be exactly like that :
        {notification: “SWD_URL”, payload: {url:[“https://magicmirror.builders/”]}}
        This line means : send to the system a “notification” (it is a MagicMirror mecanism) with the topic “SWD_URL” (so my module knows that this notification is for him), and then you have to send a “payload” (extra infos) with the URL you want to use.
        Does that helps ? If yes please let us know the solution !
        Bye,
        AgP
          smassy
          @AgP42
          Thank for answering! :-)
          Yes the Assistant is https://github.com/eouia/MMM-AssistantMk2
          I will test with your recommendation and let you know if I’m able to make it work.
          See ya!
            smassy
            @AgP42
            Good news, I was able to make it work thanks to you! But…there is a but… The youtube link with autoplay is not working :-(
            This simple url
            https://www.youtube.com/embed/JGwWNGJdvx8?autoplay=1
            Will give you ‘video unavailable’ error, remove the autoplay tag and it will show (not play).
            Trying to find out how to make it work and I will post my config as soon as I get the hang of it.
            See ya!
              sdetweil @smassy
              @smassy are you on version 2.8.0?
              We put a fix in for video not autoplay
                smassy
                Ok I finally got that you were talking about magic mirror, yes it’s 2.8.0. But does it affect smartwebdisplay? I thought the module was independent.
                  sdetweil @smassy
                  @smassy well it’s MMM-smartwebdisplay, so I assume it’s a module for MagicMirror.
                    smassy @sdetweil
                    Yes, I restarted my Pi and normal link is playing video now
                    ~~My playlist is still not working
                    https://www.youtube.com/embed/0-rG98j2DWE?list=PLa51J4RKCoTXCfr-qubj2FUgPADypF3Gk?autoplay=1~~
                    scratch that it’s working!!! :-) something must needed a refresh in the services
                    A 1 Reply Last reply
                      Chris62
                      Hi
                      I am not able to get anything to display using my own url in this module. The default config urls work fine but not mine. I am trying to display a video feed from a D-Link camera using a url in this format - http://user:password@ipaddress:port/video/mjpg.cgi. This works fine from this camera when pasted into any web browser but not in my mirror. Any suggestions would be gratefully received.
                      Chris.
                      • A
                        AgP42 Project Sponsor Module Developer @Chris62
                        Hi @Chris62 ,
                        unfortunately it is not easy, this is due to safety mechanisms of iframes that prevent to send password…
                        Personally I just removed the password of my camera :face_screaming_in_fear:
                        But you can try some cleverer solutions, search google for “iframe password” or “iframe authentifaction” and you can try to get some clues.
                        Here is one answer that I found interesting : https://stackoverflow.com/questions/15639280/basic-authentication-for-a-url-in-an-iframe
                        If you find a way, please let us know !
                        (and if it include some change on the code, I can also implement it, but so far I didn’t find any technical way…)
                        Good luck !
                        C 1 Reply Last reply
                        • A
                          @smassy said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                          Great !
                          Happy to read that ! Enjoy your wonderfull Mirror :smiling_face_with_open_mouth_smiling_eyes:
                            Chris62 @AgP42
                            @AgP42
                            Hi
                            I don’t actually have a password set for the camera, it has been factory reset to the defaults which just gives a username admin and a blank password field. My url looks like this http://admin:@ipaddress:port/video/mjpg.cgi. Maybe this is the cause of the issue?
                            Chris.
                              smassy
                              @AgP42
                              Hello again, I’m trying to use the embeded calls “SWD_…” but there is something I’m not getting.
                              var recipe = {
                                transcriptionHook: {
                                  "playlist_sylvain": {
                                    pattern: "liste sylvain",
                                    command: "playlist_1"
                                  "playlist_lewis": {
                                    pattern: "liste lewis capaldi",
                                    command: "playlist_2"
                                  "playlist_pause": {
                                    pattern: "arrêt lecture",
                                    command: "playlist_pause"
                                  "playlist_play": {
                                    pattern: "démarre lecture",
                                    command: "playlist_play"
                                command: {
                                   "playlist_1": {
                                           notificationExec: {
                                                   notification: "SWD_URL",
                                                   payload: {
                                                           url:["https://www.youtube.com/embed/0-rG98j2DWE?list=PLa51J4RKCoTXCfr-qubj2FUgPADypF3Gk&autoplay=1"],
                                   "playlist_2": {
                                           notificationExec: {
                                                  payload: {
                                                          url:["https://www.youtube.com/embed/bCuhuePlP8o?list=RDEMsPjiovzEgfLLK2w1FvFTOg&autoplay=1"],
                                   "playlist_pause": {
                                           notificationExec: {
                                                  notification: "SWD_PAUSE",
                                   "playlist_play": {
                                           notificationExec: {
                                                  notification: "SWD_PLAY",
                              exports.recipe = recipe
                              Lists are starting correctly but when calling SWD_PAUSE it’s doing nothing and SWD_PLAY restart the list at beginning. Any clue?
                              • A
                                @AgP42
                                yes, it is (unfortunately) the normal behavior, as written on the documentation :
                                - Play(or restart)/Pause/Stop the update and rotation of URLs
                                In fact I cannot stop the video itself, as it would imply to be connected to YouTube API. Here we “just” display the video. The function “play/pause” are for the rotation of the videos or playlist. If you want to stop the video, the best way will be to have an empty playlist that you can start to stop everything else.
                                I know it is bad looking and not intuitive, but I cannot do better with the technical solution with iFrames…
                                Sorry !
                                • N
                                  Newtothis @AgP42
                                  @AgP42
                                  Hi!
                                  Love the module, very well done!
                                  I am using MMM-TelegramBot to control my Mirror, did you ever look into seeing if you could intergrate your module with Telegram?
                                  A 2 Replies Last reply
                                  • A
                                    AgP42 Project Sponsor Module Developer @Newtothis
                                    @Newtothis said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                                    @AgP42
                                    Hi!
                                    yes I remember that I had a look on it some months ago and by that time I thought it will not be very complicated to do…
                                    I don’t really have much time thoses weeks (even months…), but yes someday I may develop that interface ;-)
                                    N 1 Reply Last reply
                                    • N
                                      Newtothis @AgP42
                                      @AgP42 No worries! Thanks for the reply :)
                                      • U
                                        ueffchen
                                        Hi
                                        the module loads initially after updating config.js or rebooting the MM, but it doesn’t refresh the iframe.
                                        Is there anything in the settings that I should do different?
                                        Thanks, ueffchen
                                        		module: 'MMM-SmartWebDisplay',
                                        		position: 'top_right',	// This can be any of the regions.
                                        			logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
                                        			height:"330px", //hauteur du cadre en pixel ou %
                                        			width:"330px", //largeur
                                                       		updateInterval: 30, //in min. Set it to 0 for no refresh (for videos)
                                                        	NextURLInterval: 30, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                                                        	displayStateInfos: false,	//to display if the module is on autoloop, or stop.
                                                        	displayLastUpdate: false, //to display the last update of the URL
                                        			displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                                                        	url: ["https://gadgets.buienradar.nl/gadget/zoommap/?lat=51.29724&lng=6.84929&overname=2&zoom=11&naam=ratingen&size=2b&voor=1"],
                                        			scrolling: "no" // allow scrolling or not. html 4 only
                                        A A 2 Replies Last reply
                                        • A
                                          Alain @ueffchen
                                          @ueffchen I have the exact same problem. However, for some reason, when I turn the “displayLastUpdate:” to “true”, it begins updating at the interval set in “updateInterval”. Turn it back to “false”, and it stops updating.
                                          Not ideal, since it displays a line of information I don’t want to see; but it does refresh.
                                          If someone could help, I would appreciate it too!
                                          Thank you
                                          Alain
                                          • A
                                            AgP42 Project Sponsor Module Developer @ueffchen
                                            @ueffchen said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                                            Hi
                                            Thanks, ueffchen
                                            Hi @ueffchen,
                                            when I test the url on iFrame tester (here : iFrame), I don’t need any refresh, the radar is live display without any refresh.
                                            Isn’t it the same on the mirror ?
                                            Otherwise on the config, as you have only 1 URL, this param "NextURLInterval: 30, " has to be set to 0 (but it cannot be the reason of non-refresh…)
                                            And as you set the "updateInterval: 30, ", then here you request a refresh every 30 MINUTES, was it the refresh you wanted ?
                                            Bye,
                                            AgP
                                            • 2 / 5
