    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 136.2k Views 38 Watching
    • A
      AgP42 Project Sponsor Module Developer @Zwirbel
      @Zwirbel Great, thanks that you could confirm it’s works, thanks ! :smiling_face_with_smiling_eyes:
      • A
        AgP42 Project Sponsor Module Developer @Anthony
        @Anthony : Yes absolutely ! Did you try it and can confirm it works fine ?
        • A
          AgP42 Project Sponsor Module Developer @peterh
          @peterh and @zjonesz : Unfortunatelly I don’t know also how to solve it…
          Maybe someone have a solution ?
          (I have to admit that I am not using that module myself anymore…)
          • A
            AgP42 Project Sponsor Module Developer @lukas1760
            @lukas1760 : Normaly yes, any html/css/javascript file can be executed.
            Did you test to be able to confirm that it works ?
            • A
              AgP42 Project Sponsor Module Developer @smassy
              @smassy
              the configuration of MMM-SmartWebDisplay seams ok
              I don’t know the module MMM-Assistant2, is it this one : https://github.com/eouia/MMM-AssistantMk2 ?
              If not, can you send me the link on it’s documentation ?
              To be able to send a new url to display to the MMM-SmartWebDisplay, the configuration has to be exactly like that :
              {notification: “SWD_URL”, payload: {url:[“https://magicmirror.builders/”]}}
              This line means : send to the system a “notification” (it is a MagicMirror mecanism) with the topic “SWD_URL” (so my module knows that this notification is for him), and then you have to send a “payload” (extra infos) with the URL you want to use.
              Does that helps ? If yes please let us know the solution !
              Bye,
              AgP
                smassy
                @AgP42
                Thank for answering! :-)
                Yes the Assistant is https://github.com/eouia/MMM-AssistantMk2
                I will test with your recommendation and let you know if I’m able to make it work.
                See ya!
                  smassy
                  @AgP42
                  Good news, I was able to make it work thanks to you! But…there is a but… The youtube link with autoplay is not working :-(
                  This simple url
                  https://www.youtube.com/embed/JGwWNGJdvx8?autoplay=1
                  Will give you ‘video unavailable’ error, remove the autoplay tag and it will show (not play).
                  Trying to find out how to make it work and I will post my config as soon as I get the hang of it.
                  See ya!
                    sdetweil @smassy
                    @smassy are you on version 2.8.0?
                    We put a fix in for video not autoplay
                      smassy
                      Ok I finally got that you were talking about magic mirror, yes it’s 2.8.0. But does it affect smartwebdisplay? I thought the module was independent.
                        sdetweil @smassy
                        @smassy well it’s MMM-smartwebdisplay, so I assume it’s a module for MagicMirror.
                          smassy @sdetweil
                          Yes, I restarted my Pi and normal link is playing video now
                          ~~My playlist is still not working
                          https://www.youtube.com/embed/0-rG98j2DWE?list=PLa51J4RKCoTXCfr-qubj2FUgPADypF3Gk?autoplay=1~~
                          scratch that it’s working!!! :-) something must needed a refresh in the services
                            Chris62
                            Hi
                            I am not able to get anything to display using my own url in this module. The default config urls work fine but not mine. I am trying to display a video feed from a D-Link camera using a url in this format - http://user:password@ipaddress:port/video/mjpg.cgi. This works fine from this camera when pasted into any web browser but not in my mirror. Any suggestions would be gratefully received.
                            Chris.
                            • A
                              AgP42 Project Sponsor Module Developer @Chris62
                              Hi @Chris62 ,
                              unfortunately it is not easy, this is due to safety mechanisms of iframes that prevent to send password…
                              Personally I just removed the password of my camera :face_screaming_in_fear:
                              But you can try some cleverer solutions, search google for “iframe password” or “iframe authentifaction” and you can try to get some clues.
                              Here is one answer that I found interesting : https://stackoverflow.com/questions/15639280/basic-authentication-for-a-url-in-an-iframe
                              If you find a way, please let us know !
                              (and if it include some change on the code, I can also implement it, but so far I didn’t find any technical way…)
                              Good luck !
                              • A
                                @smassy said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                                Great !
                                Happy to read that ! Enjoy your wonderfull Mirror :smiling_face_with_open_mouth_smiling_eyes:
                                  Chris62 @AgP42
                                  @AgP42
                                  Hi
                                  I don’t actually have a password set for the camera, it has been factory reset to the defaults which just gives a username admin and a blank password field. My url looks like this http://admin:@ipaddress:port/video/mjpg.cgi. Maybe this is the cause of the issue?
                                  Chris.
                                    smassy
                                    @AgP42
                                    Hello again, I’m trying to use the embeded calls “SWD_…” but there is something I’m not getting.
                                    var recipe = {
                                      transcriptionHook: {
                                        "playlist_sylvain": {
                                          pattern: "liste sylvain",
                                          command: "playlist_1"
                                        "playlist_lewis": {
                                          pattern: "liste lewis capaldi",
                                          command: "playlist_2"
                                        "playlist_pause": {
                                          pattern: "arrêt lecture",
                                          command: "playlist_pause"
                                        "playlist_play": {
                                          pattern: "démarre lecture",
                                          command: "playlist_play"
                                      command: {
                                         "playlist_1": {
                                                 notificationExec: {
                                                         notification: "SWD_URL",
                                                         payload: {
        url:["https://www.youtube.com/embed/0-rG98j2DWE?list=PLa51J4RKCoTXCfr-qubj2FUgPADypF3Gk&autoplay=1"],
                                         "playlist_2": {
                                                 notificationExec: {
                                                        payload: {
        url:["https://www.youtube.com/embed/bCuhuePlP8o?list=RDEMsPjiovzEgfLLK2w1FvFTOg&autoplay=1"],
                                         "playlist_pause": {
                                                 notificationExec: {
                                                        notification: "SWD_PAUSE",
                                         "playlist_play": {
                                                 notificationExec: {
                                                        notification: "SWD_PLAY",
                                    exports.recipe = recipe
                                    Lists are starting correctly but when calling SWD_PAUSE it’s doing nothing and SWD_PLAY restart the list at beginning. Any clue?
                                    • A
                                      @AgP42
                                      yes, it is (unfortunately) the normal behavior, as written on the documentation :
                                      - Play(or restart)/Pause/Stop the update and rotation of URLs
                                      In fact I cannot stop the video itself, as it would imply to be connected to YouTube API. Here we “just” display the video. The function “play/pause” are for the rotation of the videos or playlist. If you want to stop the video, the best way will be to have an empty playlist that you can start to stop everything else.
                                      I know it is bad looking and not intuitive, but I cannot do better with the technical solution with iFrames…
                                      Sorry !
                                      • N
                                        Newtothis @AgP42
                                        @AgP42
                                        Hi!
                                        Love the module, very well done!
                                        I am using MMM-TelegramBot to control my Mirror, did you ever look into seeing if you could intergrate your module with Telegram?
                                        A 2 Replies Last reply Reply Quote 0
                                        • A
                                          AgP42 Project Sponsor Module Developer @Newtothis
                                          @Newtothis said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                                          @AgP42
                                          Hi!
                                          yes I remember that I had a look on it some months ago and by that time I thought it will not be very complicated to do…
                                          I don’t really have much time thoses weeks (even months…), but yes someday I may develop that interface ;-)
                                          • N
                                            Newtothis @AgP42
                                            @AgP42 No worries! Thanks for the reply :)
                                            • 2 / 5
