    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 136.2k Views 38 Watching
    • A
      AgP42 Project Sponsor Module Developer @rafaelcota
      @rafaelcota
      I didn’t know the MMM-TelegramBot, but I just check the documentation (incredibly well written ! :face_with_tears_of_joy: ) and it seams very easy to integrate, so I will add it on my coding to do list for the next version !
      Thanks for the tip !
      • swvalentiS
        swvalenti Project Sponsor
        Question, so this could display a RTSP security camera feed?
        A 1 Reply Last reply Reply Quote -1
        • A
          AgP42 Project Sponsor Module Developer @swvalenti
          @swvalenti
          No, it can display anything (or almost) that can be displayed on a web browser, so not an RTSP camera feed.
          But for this you can use MMM-RTSPStream
          swvalentiS 1 Reply Last reply Reply Quote 0
          • swvalentiS
            swvalenti Project Sponsor @AgP42
            @agp42 said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
            @swvalenti
            @AgP42 Understood thanks for responding.
              shbatm Module Developer @AgP42
              Did you create a dedicated post for your fork and API ?
              https://forum.magicmirror.builders/topic/9291/mmm-remote-control-v2-dev-extensible-rest-api-dynamic-menus-and-socket-communications-plus-other-updates
              @Jopyth is still the maintainer of MMM-Remote-Control, and I’ve sent a PR to have my changes included in the official repo; if he’s anything like me, this is a hobby and efforts on it come and go as time and other projects allow. Feel free to use my fork for now and if/when they get merged, I’ll let you know. I’ve been trying to include several Issue fixes in my branch as well to wrap them all up into 1 update.
              • Z
                Zwirbel
                @AgP42 Could you explain how to “declare several instances” with this module? I tried to add it twice (once for bottom_left and once for bottom_middle, but it only shows the iFrame of bottom_left…
                • Z
                  Zwirbel
                  Ok, I have found the error myself: the position “bottom_middle” does not exist, I have to use “bottom_center”. Now it works!
                  • A
                    Anthony Project Sponsor
                    @AgP42
                    I already have installed MMM-RemoteControl in my MM. If I remove it and reinstall it from your repository will it install the new feture as well to control SWD?
                      peterh
                      I’m loving this module, but having slight issue. it seems if i use the adjustment for height or width the area resizes but does not scale the image by the percentage as i would expect.
                                                  height:"50 %", //hauteur du cadre en pixel ou %
                                                  width:"50 %", //largeur
                      produces a 50 pixel square image
                      and
                                                height:"50%", //hauteur du cadre en pixel ou %
                                                  width:"50%", //largeur
                      produces an image that is half the size but cropped, showing only the top left 1/4 of the image.
                      If anyone can see an error in my config please let me know :-)
                        module: 'MMM-SmartWebDisplay',
                        header: "South Doodlakine Radar",
                        position: 'bottom_right',       // This can be any of the regions.
                                       logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
                                       //height:"524", //hauteur du cadre en pixel ou %
                                       //width:"564", //largeur
                                       updateInterval: 1,
                                       NextURLInterval: 0.5,
                                       displayStateInfos: false,
                                       displayLastUpdate: false,
                                       displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                                       url: ["http://www.bom.gov.au/radar/IDR58B.gif?123", "http://www.bom.gov.au/radar/IDR58B.gif?345"],
                                       scrolling: "no"
                      regards
                      PeterH
                      A TazDevT 2 Replies Last reply Reply Quote 0
                      • L
                        lukas1760
                        Great job! But…is it possible to show html file saved in rpi folder?
                        • Z
                          zjonesz
                          Have the same problem as PeterH, does anyone have a fix?
                            smassy
                            @AgP42 said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                            through notification by any other module
                            First: Good job, module is very nice and easy to implement.
                            I have a little problem to understand how to change URL by notification from another module. I am using MMM-Assistant2 with a recipe but I’m not sure how to configure it. A little help would be greatly appreciated.
                            config.js:
                            module: ‘MMM-SmartWebDisplay’,
                            position: ‘bottom_left’, // This can be any of the regions.
                            // See ‘Configuration options’ for more information.
                            logDebug: false, //set to true to get detailed debug logs. To see them : “Ctrl+Shift+i”
                            height:“200px”, //hauteur du cadre en pixel ou %
                            width:“300px”, //largeur
                            updateInterval: 0, //in min. Set it to 0 for no refresh (for videos)
                            NextURLInterval: 0, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                            displayStateInfos: false, //to display if the module is on autoloop, or stop.
                            displayLastUpdate: true, //to display the last update of the URL
                            displayLastUpdateFormat: ‘ddd - HH:mm:ss’, //format of the date and time to display
                            url: [“https://www.youtube.com/embed/9xXww6Yyl34?list=PLa51J4RKCoTXCfr-qubj2FUgPADypF3Gk”], //source of the URL to be displayed
                            scrolling: “no” // allow scrolling or not. html 4 only
                            Recipe (playlist.js)
                            var recipe = {
                            transcriptionHook: {
                            “playlist_sylvain”: {
                            pattern: “liste sylvain”,
                            command: “playlist_1”
                            command: {
                            “playlist_1”: {
                            moduleExec: {
                            module: [“MMM-SmartWebDisplay”],
                            exec: (module, params, key) => {
                            module: ({url: [“http://www.google.com”]}) //test url
                            exports.recipe = recipe
                            What I am missing?
                            Thank you!
                            • A
                              sorry guys not having answering before, I will try to answer all your questions now !
                              • A
                                AgP42 Project Sponsor Module Developer @Zwirbel
                                @Zwirbel Great, thanks that you could confirm it’s works, thanks ! :smiling_face_with_smiling_eyes:
                                • A
                                  AgP42 Project Sponsor Module Developer @Anthony
                                  @Anthony : Yes absolutely ! Did you try it and can confirm it works fine ?
                                  • A
                                    AgP42 Project Sponsor Module Developer @peterh
                                    @peterh and @zjonesz : Unfortunatelly I don’t know also how to solve it…
                                    Maybe someone have a solution ?
                                    (I have to admit that I am not using that module myself anymore…)
                                    • A
                                      AgP42 Project Sponsor Module Developer @lukas1760
                                      @lukas1760 : Normaly yes, any html/css/javascript file can be executed.
                                      Did you test to be able to confirm that it works ?
                                      • A
                                        AgP42 Project Sponsor Module Developer @smassy
                                        @smassy
                                        the configuration of MMM-SmartWebDisplay seams ok
                                        I don’t know the module MMM-Assistant2, is it this one : https://github.com/eouia/MMM-AssistantMk2 ?
                                        If not, can you send me the link on it’s documentation ?
                                        To be able to send a new url to display to the MMM-SmartWebDisplay, the configuration has to be exactly like that :
                                        {notification: “SWD_URL”, payload: {url:[“https://magicmirror.builders/”]}}
                                        This line means : send to the system a “notification” (it is a MagicMirror mecanism) with the topic “SWD_URL” (so my module knows that this notification is for him), and then you have to send a “payload” (extra infos) with the URL you want to use.
                                        Does that helps ? If yes please let us know the solution !
                                        Bye,
                                        AgP
                                          smassy
                                          @AgP42
                                          Thank for answering! :-)
                                          Yes the Assistant is https://github.com/eouia/MMM-AssistantMk2
                                          I will test with your recommendation and let you know if I’m able to make it work.
                                          See ya!
                                            smassy
                                            @AgP42
                                            Good news, I was able to make it work thanks to you! But…there is a but… The youtube link with autoplay is not working :-(
                                            This simple url
                                            https://www.youtube.com/embed/JGwWNGJdvx8?autoplay=1
                                            Will give you ‘video unavailable’ error, remove the autoplay tag and it will show (not play).
                                            Trying to find out how to make it work and I will post my config as soon as I get the hang of it.
                                            See ya!
                                            • 1 / 5
