MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
Great job! But…is it possible to show html file saved in rpi folder?
Have the same problem as PeterH, does anyone have a fix?
@AgP42 said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
through notification by any other module
First: Good job, module is very nice and easy to implement.
I have a little problem to understand how to change URL by notification from another module. I am using MMM-Assistant2 with a recipe but I’m not sure how to configure it. A little help would be greatly appreciated.
config.js:
module: ‘MMM-SmartWebDisplay’,
position: ‘bottom_left’, // This can be any of the regions.
// See ‘Configuration options’ for more information.
logDebug: false, //set to true to get detailed debug logs. To see them : “Ctrl+Shift+i”
height:“200px”, //hauteur du cadre en pixel ou %
width:“300px”, //largeur
updateInterval: 0, //in min. Set it to 0 for no refresh (for videos)
NextURLInterval: 0, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
displayStateInfos: false, //to display if the module is on autoloop, or stop.
displayLastUpdate: true, //to display the last update of the URL
displayLastUpdateFormat: ‘ddd - HH:mm:ss’, //format of the date and time to display
url: [“https://www.youtube.com/embed/9xXww6Yyl34?list=PLa51J4RKCoTXCfr-qubj2FUgPADypF3Gk”], //source of the URL to be displayed
scrolling: “no” // allow scrolling or not. html 4 only
},Recipe (playlist.js)
var recipe = {
transcriptionHook: {
“playlist_sylvain”: {
pattern: “liste sylvain”,
command: “playlist_1”
command: {
“playlist_1”: {
moduleExec: {
module: [“MMM-SmartWebDisplay”],
exec: (module, params, key) => {
module: ({url: [“http://www.google.com”]}) //test url
exports.recipe = recipeWhat I am missing?
Thank you!
sorry guys not having answering before, I will try to answer all your questions now !
@Zwirbel Great, thanks that you could confirm it’s works, thanks ! :smiling_face_with_smiling_eyes:
@Anthony : Yes absolutely ! Did you try it and can confirm it works fine ?
@lukas1760 : Normaly yes, any html/css/javascript file can be executed.
Did you test to be able to confirm that it works ?
the configuration of MMM-SmartWebDisplay seams ok
I don’t know the module MMM-Assistant2, is it this one : https://github.com/eouia/MMM-AssistantMk2 ?
If not, can you send me the link on it’s documentation ?To be able to send a new url to display to the MMM-SmartWebDisplay, the configuration has to be exactly like that :
{notification: “SWD_URL”, payload: {url:[“https://magicmirror.builders/”]}}
This line means : send to the system a “notification” (it is a MagicMirror mecanism) with the topic “SWD_URL” (so my module knows that this notification is for him), and then you have to send a “payload” (extra infos) with the URL you want to use.Does that helps ? If yes please let us know the solution !
Bye,
AgP -
Thank for answering! :-)
Yes the Assistant is https://github.com/eouia/MMM-AssistantMk2
I will test with your recommendation and let you know if I’m able to make it work.
See ya!
Good news, I was able to make it work thanks to you! But…there is a but… The youtube link with autoplay is not working :-(
This simple url
https://www.youtube.com/embed/JGwWNGJdvx8?autoplay=1Will give you ‘video unavailable’ error, remove the autoplay tag and it will show (not play).
Trying to find out how to make it work and I will post my config as soon as I get the hang of it.
See ya!
@smassy are you on version 2.8.0?
We put a fix in for video not autoplay -
Ok I finally got that you were talking about magic mirror, yes it’s 2.8.0. But does it affect smartwebdisplay? I thought the module was independent.
@smassy well it’s MMM-smartwebdisplay, so I assume it’s a module for MagicMirror.
Yes, I restarted my Pi and normal link is playing video now
https://www.youtube.com/embed/JGwWNGJdvx8?autoplay=1~~My playlist is still not working
https://www.youtube.com/embed/0-rG98j2DWE?list=PLa51J4RKCoTXCfr-qubj2FUgPADypF3Gk?autoplay=1~~scratch that it’s working!!! :-) something must needed a refresh in the services
Hi
I am not able to get anything to display using my own url in this module. The default config urls work fine but not mine. I am trying to display a video feed from a D-Link camera using a url in this format - http://user:password@ipaddress:port/video/mjpg.cgi. This works fine from this camera when pasted into any web browser but not in my mirror. Any suggestions would be gratefully received.
Chris.
Hi @Chris62 ,
unfortunately it is not easy, this is due to safety mechanisms of iframes that prevent to send password…
Personally I just removed the password of my camera :face_screaming_in_fear:
But you can try some cleverer solutions, search google for “iframe password” or “iframe authentifaction” and you can try to get some clues.
Here is one answer that I found interesting : https://stackoverflow.com/questions/15639280/basic-authentication-for-a-url-in-an-iframeIf you find a way, please let us know !
(and if it include some change on the code, I can also implement it, but so far I didn’t find any technical way…)Good luck !
@smassy said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
Great !
Happy to read that ! Enjoy your wonderfull Mirror :smiling_face_with_open_mouth_smiling_eyes:
Hi
I don’t actually have a password set for the camera, it has been factory reset to the defaults which just gives a username admin and a blank password field. My url looks like this http://admin:@ipaddress:port/video/mjpg.cgi. Maybe this is the cause of the issue?
Chris.
Hello again, I’m trying to use the embeded calls “SWD_…” but there is something I’m not getting.
var recipe = { transcriptionHook: { "playlist_sylvain": { pattern: "liste sylvain", command: "playlist_1" }, "playlist_lewis": { pattern: "liste lewis capaldi", command: "playlist_2" }, "playlist_pause": { pattern: "arrêt lecture", command: "playlist_pause" }, "playlist_play": { pattern: "démarre lecture", command: "playlist_play" }, }, command: { "playlist_1": { notificationExec: { notification: "SWD_URL", payload: { url:["https://www.youtube.com/embed/0-rG98j2DWE?list=PLa51J4RKCoTXCfr-qubj2FUgPADypF3Gk&autoplay=1"], } } }, "playlist_2": { notificationExec: { notification: "SWD_URL", payload: { url:["https://www.youtube.com/embed/bCuhuePlP8o?list=RDEMsPjiovzEgfLLK2w1FvFTOg&autoplay=1"], } } }, "playlist_pause": { notificationExec: { notification: "SWD_PAUSE", } }, "playlist_play": { notificationExec: { notification: "SWD_PLAY", } }, }, } exports.recipe = recipeLists are starting correctly but when calling SWD_PAUSE it’s doing nothing and SWD_PLAY restart the list at beginning. Any clue?
