    MMM-MLB Scores not loading
    7 Posts 2 Posters 2.0k Views 2 Watching
    • K
      kc0bra
      Re: MMM-MLB
      I can’t seem to get the scores to load. I get the logo and it says MLB Scores (and if I change mode to standings logo changes) but no real-time data loads. Here is what my config looks like.
      module: ‘MMM-MLB’,
      position: ‘top_right’,
      maxWidth: “400px”,
      header: true,
      logo: true,
      I appreciate any suggestions on how to troubleshoot this. Thanks!
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @kc0bra
        @kc0bra
        I just installed it and it’s working. You’re missing a curly bracket (there should be two after logo:true) and you do need a comma after the closing curly bracket }
        You can just copy and paste the below entry and paste it into your config if you like.
            module: "MMM-MLB",
            position: "top_center",
            config: { // See "Configuration options" for more information.
              maxWidth: "400px",
              header: true,
              logo: true,
        //      focus_on: ["Indians", "Braves", "Yankees"]
        • K
          kc0bra
          Hmmm. I just removed mine completely and pasted your example in and I’m still getting the same thing. For some reason the scores aren’t loading. Is there an API key or anything that I need to put in somewhere? Similar to what needs to be generated and installed for weather apps?
          • Mykle1M
            @kc0bra said in Scores not loading:
            No sir, no API key necessary for this module. It doesn’t even require dependencies of any kind. You can do three things.
            1. Post your config entry in a code block so that I can take a look at it. Click the </> icon above your message window when you are replying. It’s at the far right. Paste your code in the highlighted code_text that will appear. That will format your entry.
            2. Start your mirror in the MM directory with the command npm start dev. This will open the Developers Tools window. Click the Console tab at the top left of the window. Scroll through the output looking for errors in red. Report here.
            3. Delete your current MMM-MLB folder from the modules folder and clone it again from https://github.com/cowboysdude/MMM-MLB. Then try it with my config example above.
            • K
              kc0bra
              Hey Mykle1, deleting the directly and re-cloning from Git did the trick. I now have the scores coming in regularly. Thanks a lot for your help!
              Mykle1M 2 Replies Last reply
              • Mykle1M
                @kc0bra
                Ahh, have fun!
                • Mykle1M
                  @kc0bra
                  You can mark this post as solved by clicking the three verticle dots to the right of the post that helped you.
