    Error with launching the magic mirror Applicants. it said i need to create a config file.
    5 Posts 4 Posters 1.0k Views 4 Watching
      dearco
      WARNING! Could not find config file. Please create one. Starting with default configuration.
      Loading module helpers …
      No helper found for module: helloworld.
      All module helpers loaded.
      Starting server on port 8080 …
      Server started …
      Sockets connected & modules started …
      Whoops! There was an uncaught exception…
      { Error: listen EADDRINUSE 127.0.0.1:8080
      at Server.setupListenHandle [as _listen2] (net.js:1330:14)
      at listenInCluster (net.js:1378:12)
      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
      errno: ‘EADDRINUSE’,
      code: ‘EADDRINUSE’,
      syscall: ‘listen’,
      address: ‘127.0.0.1’,
      port: 8080 }
      mumblebajM Mykle1M 2 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        mumblebaj Module Developer @dearco
        @dearco said in Error with launching the magic mirror Applicants. it said i need to create a config file.:
        EADDRINUSE
        That usually means that something else is running on port 8080. Maybe you have two instances of MM running?
          Mykle1 Project Sponsor Module Developer @dearco
          And there is a problem with your config. This should help.
          https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
            sdetweil @Mykle1
            @Mykle1 probably pm2 started instance
              Ah, my bad.
