Loading an image properly
I’m sure this shouldn’t be this hard but I’ve been stuck on it a few hours now. I’m trying to load a transparent background .png with a white image into the mirror.
I’ve tried loading it as a background img through the custom.css file, which worked except its in the background… (obviously)
body {
background-image: url(White.png");
background-repeat: no-repeat;
[/code]So to get around the manual padding adjustment I’m wondering if there is a way to load in an img into the “Position: top_left” area so any modules also in that area auto adjust?
I also tried adding to the index.html but that simply resulted in an “X” broken link icon.
{ module: "helloworld", position: "top_left", config: { text: "<img src='path_or_link_to_your_image'>" } } -
Thanks for your help strawberry pi.
I was having additional issues with the code finding the img.
In case this helps someone else, this is what I ended up with:{ module: 'helloworld', position: 'top_left', config: { text: "<img src='./config/White.png' height='186' width='341'>" } } ,
