    Loading an image properly
    3 Posts 2 Posters 2.9k Views 2 Watching
    • KnoxK Offline
      Knox
      I’m sure this shouldn’t be this hard but I’ve been stuck on it a few hours now. I’m trying to load a transparent background .png with a white image into the mirror.
      I’ve tried loading it as a background img through the custom.css file, which worked except its in the background… (obviously)
      body {
      background-image: url(White.png");
      background-repeat: no-repeat;
      [/code]
      So to get around the manual padding adjustment I’m wondering if there is a way to load in an img into the “Position: top_left” area so any modules also in that area auto adjust?
      I also tried adding to the index.html but that simply resulted in an “X” broken link icon.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Knox
        @Knox
        			module: "helloworld",
        				text: "<img src='path_or_link_to_your_image'>"
        • KnoxK Offline
          Knox
          Thanks for your help strawberry pi.
          I was having additional issues with the code finding the img.
          In case this helps someone else, this is what I ended up with:
          			module: 'helloworld',
          			position: 'top_left',
          				text: "<img src='./config/White.png' height='186' width='341'>"
