    MMM-MyStandings
    24 Posts 12 Posters 16.6k Views 13 Watching
    • V
      vinp Module Developer
      Thanks for the feedback ! Glad you are enjoying it. I love seeing sports updates on the mirror!
        my_nerdy_account
        I love this module! Thanks so much for sharing it.
        I’ve modified the css and .njk template to something I really like. What I need now is for the leagues to rotate through in a specific order. It seems like they load in a random order every time I restart MM.
        FLhTF V 2 Replies Last reply
        • FLhTF
          FLhT @my_nerdy_account
          These are Cool! I’m inspired to (eventually) adapt this to display FIRST Tech Challenge and FIRST Robotics Competition Stats.
          • A
            alecbalec
            Great module, I forked it on github and added the English Premier League.
            V 1 Reply Last reply
            • V
              vinp Module Developer @my_nerdy_account
              @my_nerdy_account that looks awesome! Care to share your branch in GitHub?
              • V
                vinp Module Developer @alecbalec
                @alecbalec I’m testing out the ability to add many more soccer leagues… stay tuned for an update
                • V
                  I’ve added NCAAM Basketball and lots of different Soccer leagues from ESPN. It should be able to handle all the soccer leagues that have standings/tables available. I looked at how MMM-MyScoreboard did the soccer leagues and used the same naming. Have a look at my code (get latest) and let me know how it goes. thanks!
                  • N
                    Newtothis
                    @vinp Hi
                    Thanks for the module, really enjoying it and thanks for updating it. I was just wondering if it is possible to have two leagues showing at the same time?
                    I tried using two instances of the configuration (One for NBA and one for Premier League) in the config.js but this didn’t work. Very new at all of this, so please excuse me if it is really obvious answer
                    Thanks!
                    Reply Quote 2
                    • V
                      vinp Module Developer @Newtothis
                      @Newtothis I dont think this module supports that. I think I read on this forum that if the module uses a node_helper.js it wont be possible. Otherwise you could try copying and renaming a similar folder and setup the MM config with both names. There is a issue logged on my github with your same suggestion. I just haven’t had the chance to look to see how much effort it would take to implement.
                        sdetweil @vinp
                        @vinp said in MMM-MyStandings:
                        it IS possible… just have to think thru the choices of the solution…
                        there is only ONE node_helper loaded for all instances of the module.
                        any sendSocketNotification from the helper to the module (instances) goes to ALL instances at once.
                        so, one could send the module identifier from the module.js to the node_helper, and use THAT as a key into a storage area saved by module instance (config from module _1, module_2, etc)…
                        config: {},
                        this.config[module_id].config_variable
                        and then on the send BACK, return the module identifier as part of the data, and the module checks to see if the response is for that instance…
                        another way, to avoid the storage, is for the module to send config every time, and the identifier, and
                        the node helper send back the identifier as part of the response… and module checks… same as before…
                        I created a module that does option 2 , never stores any module instance data in node_helper
                        https://github.com/sdetweil/NewBusTimes
                        N 1 Reply Last reply
                        • cowboysdudeC
                          Excellent!
                          • N
                            Newtothis @sdetweil
                            @sdetweil Thank you!
                            I managed to get it working by renaming the module and replacing all instances of the module name with something different.
                            I am having trouble getting ‘ENG_NATIONAL’, ‘ENG_LEAGUE_1’ AND ‘ENG_LEAGUE_2’ tables to appear, do you have any ideas on how to get them working?
                            Thank you
                            S V 2 Replies Last reply
                              sdetweil @Newtothis
                              @Newtothis sorry. No idea how the module works
                              • V
                                @Newtothis said in MMM-MyStandings:
                                ENG_NATIONAL
                                Your config should look something like :
                                            module: "MMM-MyStandings",
                                                sports: [
                                		    { league: "ENG_LEAGUE_1" },
                                You can add more leagues to rotate by adding a similar format inside of the sports [] array
                                { league: “ENG_LEAGUE_1” },
                                { league: “ENG_LEAGUE_2” },
                                { league: “ENG_NATIONAL” },
                                  Dropzone1969
                                  Is there a way to make the NFL rotate between NFC and AFC?
                                    chanster
                                    Love this module ! Instead of grouping by divisions, is there a way group by conference instead for NBA?
                                      ricochetd
                                      Got a pretty basic config where I’m just starting with only NHL standings. The config.js below is the only thing that works, but it only gives the NHL Central Division standings. If showByDivision is set to true, any other Division is listed or even commented out, it shows no standings at all; just a black screen. I included a header so that I know it’s actually loading; it’s not providing any results. I’ve done a git pull and it says it’s up to date. If I change the league to NBA, it loads all of the divisions. Also, is it possible to show by overall league standings?
                                      Here’s my config.js code and screenshots:
                                      module: “MMM-MyStandings”,
                                      header: “My Standings”,
                                      position: “top_right”,
                                      updateInterval: 60 * 60 * 1000, // every 60 minutes
                                      rotateInterval: 1 * 60 * 1000, // every 1 minute
                                      sports: [
                                      { league: “NHL” },
                                      nameStyle: “short”,
                                      showLogos: true,
                                      useLocalLogos: true,
                                      showByDivision: false,
                                      fadeSpeed: 1000,
