Unsolved MM won't run, blank screen with cursor showing after updating
@jmartin1009 said in MM won't run, blank screen with cursor showing after updating:
from your response> this._psc = spawn('pocketsphinx_continuous', [ > '-adcdev', > mic, > '-inmic', > 'yes', > '-lm', > `modules/${this.setId}/${this.setId}.lm`, > '-dict', > `modules/${this.setId}/${this.setId}.dic` > ]); >
so, only the path to the files can be wrong…
so, change them to (assume u are running as user pi)
this._psc = spawn('pocketsphinx_continuous', [ '-adcdev', mic, '-inmic', 'yes', '-lm', `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.lm`, '-dict', `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.dic` ]);
@jmartin1009 you have the file with my fixes in it… btw
@sdetweil which file? and i’ll go change those right now
~/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx_continuous/index.js
same file u just showed me
@sdetweil oh yeah, im going to change the file paths in it right now in the one you sent last.
@sdetweil just changed those file paths, tried running MM, still getting “ERROR undefined” next to the little microphone
@jmartin1009 yeh, only care about the debug log
@sdetweil ```
INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
Current configuration:
[NAME] [DEFLT] [VALUE]
-agc none none
-agcthresh 2.0 2.000000e+00
-allphone
-allphone_ci yes yes
-alpha 0.97 9.700000e-01
-ascale 20.0 2.000000e+01
-aw 1 1
-backtrace no no
-beam 1e-48 1.000000e-48
-bestpath yes yes
-bestpathlw 9.5 9.500000e+00
-ceplen 13 13
-cmn live batch
-cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
-compallsen no no
-dict /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
-dictcase no no
-dither no no
-doublebw no no
-ds 1 1
-fdict
-feat 1s_c_d_dd 1s_c_d_dd
-featparams
-fillprob 1e-8 1.000000e-08
-frate 100 100
-fsg
-fsgusealtpron yes yes
-fsgusefiller yes yes
-fwdflat yes yes
-fwdflatbeam 1e-64 1.000000e-64
-fwdflatefwid 4 4
-fwdflatlw 8.5 8.500000e+00
-fwdflatsfwin 25 25
-fwdflatwbeam 7e-29 7.000000e-29
-fwdtree yes yes
-hmm /usr/local/share/pocketsphinx/model/en-us/en-us
-input_endian little little
-jsgf
-keyphrase
-kws
-kws_delay 10 10
-kws_plp 1e-1 1.000000e-01
-kws_threshold 1e-30 1.000000e-30
-latsize 5000 5000
-lda
-ldadim 0 0
-lifter 0 22
-lm /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.lm
-lmctl
-lmname
-logbase 1.0001 1.000100e+00
-logfn
-logspec no no
-lowerf 133.33334 1.300000e+02
-lpbeam 1e-40 1.000000e-40
-lponlybeam 7e-29 7.000000e-29
-lw 6.5 6.500000e+00
-maxhmmpf 30000 30000
-maxwpf -1 -1
-mdef
-mean
-mfclogdir
-min_endfr 0 0
-mixw
-mixwfloor 0.0000001 1.000000e-07
-mllr
-mmap yes yes
-ncep 13 13
-nfft 512 512
-nfilt 40 25
-nwpen 1.0 1.000000e+00
-pbeam 1e-48 1.000000e-48
-pip 1.0 1.000000e+00
-pl_beam 1e-10 1.000000e-10
-pl_pbeam 1e-10 1.000000e-10
-pl_pip 1.0 1.000000e+00
-pl_weight 3.0 3.000000e+00
-pl_window 5 5
-rawlogdir
-remove_dc no no
-remove_noise yes yes
-remove_silence yes yes
-round_filters yes yes
-samprate 16000 1.600000e+04
-seed -1 -1
-sendump
-senlogdir
-senmgau
-silprob 0.005 5.000000e-03
-smoothspec no no
-svspec 0-12/13-25/26-38
-tmat
-tmatfloor 0.0001 1.000000e-04
-topn 4 4
-topn_beam 0 0
-toprule
-transform legacy dct
-unit_area yes yes
-upperf 6855.4976 6.800000e+03
-uw 1.0 1.000000e+00
-vad_postspeech 50 50
-vad_prespeech 20 20
-vad_startspeech 10 10
-vad_threshold 3.0 3.000000e+00
-var
-varfloor 0.0001 1.000000e-04
-varnorm no no
-verbose no no
-warp_params
-warp_type inverse_linear inverse_linear
-wbeam 7e-29 7.000000e-29
-wip 0.65 6.500000e-01
-wlen 0.025625 2.562500e-02INFO: feat.c(715): Initializing feature stream to type: ‘1s_c_d_dd’, ceplen=13, CMN=‘batch’, VARNORM=‘no’, AGC=‘none’
INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
INFO: acmod.c(113): Attempting to use PTM computation module
INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
INFO: ms_gauden.c(244): 128x13
INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
INFO: ms_gauden.c(304): 222 variance values floored
INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION
INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126
INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones
INFO: ptm_mgau.c(837): Maximum top-N: 4
INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries
INFO: dict.c(333): Reading main dictionary: /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
INFO: dict.c(336): 29 words read
INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
INFO: dict.c(361): 5 words read
INFO: dict2pid.c(396): Building PID tables for dictionary
INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones
INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones
INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
INFO: ngram_model_trie.c(365): Header doesn’t match
INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
INFO: ngram_model_trie.c(193): LM of order 3
INFO: ngram_model_trie.c(195): #1-grams: 25
INFO: ngram_model_trie.c(195): #2-grams: 46
INFO: ngram_model_trie.c(195): #3-grams: 23
INFO: lm_trie.c(474): Training quantizer
INFO: lm_trie.c(482): Building LM trie
INFO: ngram_search_fwdtree.c(74): Initializing search tree
INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
INFO: ngram_search_fwdtree.c(186): Creating search channels
INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41Error opening audio device plughw:1,0 for capture: Invalid argument
FATAL: “continuous.c”, line 245: Failed to open audio device -
FATAL: “continuous.c”, line 245: Failed to open audio deviceI don’t know…
i would open an issue on the MMM-voice github repo, with the log file and ask for help .
@sdetweil done, thank you for all of your help, I appreciate you taking time out of your day to troubleshoot this with me, you’ve helped me with a ton of stuff and i really appreciate it.
