    MM won't run, blank screen with cursor showing after updating
    81 Posts 2 Posters 52.2k Views 2 Watching
      sdetweil @jmartin1009
      @jmartin1009 said in MM won't run, blank screen with cursor showing after updating:
      from your response
      > this._psc = spawn('pocketsphinx_continuous', [
      >       '-adcdev',
      >       mic,
      >       '-inmic',
      >       'yes',
      >       '-lm',
      >       `modules/${this.setId}/${this.setId}.lm`,
      >       '-dict',
      >       `modules/${this.setId}/${this.setId}.dic`
      so, only the path to the files can be wrong…
      so, change them to (assume u are running as user pi)
             '-adcdev',
             mic,
             '-inmic',
             'yes',
             '-lm',
             `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.lm`,
             '-dict',
             `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.dic`
        @jmartin1009 you have the file with my fixes in it… btw
          jmartin1009 @sdetweil
          @sdetweil which file? and i’ll go change those right now
            @jmartin1009
            ~/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx_continuous/index.js
            same file u just showed me
              @sdetweil oh yeah, im going to change the file paths in it right now in the one you sent last.
                @sdetweil just changed those file paths, tried running MM, still getting “ERROR undefined” next to the little microphone
                  @jmartin1009 yeh, only care about the debug log
                    @sdetweil ```
                    INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
                    Current configuration:
                    [NAME] [DEFLT] [VALUE]
                    -agc none none
                    -agcthresh 2.0 2.000000e+00
                    -allphone
                    -allphone_ci yes yes
                    -alpha 0.97 9.700000e-01
                    -ascale 20.0 2.000000e+01
                    -aw 1 1
                    -backtrace no no
                    -beam 1e-48 1.000000e-48
                    -bestpath yes yes
                    -bestpathlw 9.5 9.500000e+00
                    -ceplen 13 13
                    -cmn live batch
                    -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
                    -compallsen no no
                    -dict /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
                    -dictcase no no
                    -dither no no
                    -doublebw no no
                    -ds 1 1
                    -fdict
                    -feat 1s_c_d_dd 1s_c_d_dd
                    -featparams
                    -fillprob 1e-8 1.000000e-08
                    -frate 100 100
                    -fsg
                    -fsgusealtpron yes yes
                    -fsgusefiller yes yes
                    -fwdflat yes yes
                    -fwdflatbeam 1e-64 1.000000e-64
                    -fwdflatefwid 4 4
                    -fwdflatlw 8.5 8.500000e+00
                    -fwdflatsfwin 25 25
                    -fwdflatwbeam 7e-29 7.000000e-29
                    -fwdtree yes yes
                    -hmm /usr/local/share/pocketsphinx/model/en-us/en-us
                    -input_endian little little
                    -jsgf
                    -keyphrase
                    -kws
                    -kws_delay 10 10
                    -kws_plp 1e-1 1.000000e-01
                    -kws_threshold 1e-30 1.000000e-30
                    -latsize 5000 5000
                    -lda
                    -ldadim 0 0
                    -lifter 0 22
                    -lm /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.lm
                    -lmctl
                    -lmname
                    -logbase 1.0001 1.000100e+00
                    -logfn
                    -logspec no no
                    -lowerf 133.33334 1.300000e+02
                    -lpbeam 1e-40 1.000000e-40
                    -lponlybeam 7e-29 7.000000e-29
                    -lw 6.5 6.500000e+00
                    -maxhmmpf 30000 30000
                    -maxwpf -1 -1
                    -mdef
                    -mean
                    -mfclogdir
                    -min_endfr 0 0
                    -mixw
                    -mixwfloor 0.0000001 1.000000e-07
                    -mllr
                    -mmap yes yes
                    -ncep 13 13
                    -nfft 512 512
                    -nfilt 40 25
                    -nwpen 1.0 1.000000e+00
                    -pbeam 1e-48 1.000000e-48
                    -pip 1.0 1.000000e+00
                    -pl_beam 1e-10 1.000000e-10
                    -pl_pbeam 1e-10 1.000000e-10
                    -pl_pip 1.0 1.000000e+00
                    -pl_weight 3.0 3.000000e+00
                    -pl_window 5 5
                    -rawlogdir
                    -remove_dc no no
                    -remove_noise yes yes
                    -remove_silence yes yes
                    -round_filters yes yes
                    -samprate 16000 1.600000e+04
                    -seed -1 -1
                    -sendump
                    -senlogdir
                    -senmgau
                    -silprob 0.005 5.000000e-03
                    -smoothspec no no
                    -svspec 0-12/13-25/26-38
                    -tmat
                    -tmatfloor 0.0001 1.000000e-04
                    -topn 4 4
                    -topn_beam 0 0
                    -toprule
                    -transform legacy dct
                    -unit_area yes yes
                    -upperf 6855.4976 6.800000e+03
                    -uw 1.0 1.000000e+00
                    -vad_postspeech 50 50
                    -vad_prespeech 20 20
                    -vad_startspeech 10 10
                    -vad_threshold 3.0 3.000000e+00
                    -var
                    -varfloor 0.0001 1.000000e-04
                    -varnorm no no
                    -verbose no no
                    -warp_params
                    -warp_type inverse_linear inverse_linear
                    -wbeam 7e-29 7.000000e-29
                    -wip 0.65 6.500000e-01
                    -wlen 0.025625 2.562500e-02
                    INFO: feat.c(715): Initializing feature stream to type: ‘1s_c_d_dd’, ceplen=13, CMN=‘batch’, VARNORM=‘no’, AGC=‘none’
                    INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
                    INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                    INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
                    INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                    INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
                    INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
                    INFO: acmod.c(113): Attempting to use PTM computation module
                    INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
                    INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
                    INFO: ms_gauden.c(244): 128x13
                    INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
                    INFO: ms_gauden.c(304): 222 variance values floored
                    INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
                    INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION
                    INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126
                    INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones
                    INFO: ptm_mgau.c(837): Maximum top-N: 4
                    INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
                    INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries
                    INFO: dict.c(333): Reading main dictionary: /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
                    INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
                    INFO: dict.c(336): 29 words read
                    INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
                    INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                    INFO: dict.c(361): 5 words read
                    INFO: dict2pid.c(396): Building PID tables for dictionary
                    INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                    INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones
                    INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones
                    INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                    INFO: ngram_model_trie.c(365): Header doesn’t match
                    INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                    INFO: ngram_model_trie.c(193): LM of order 3
                    INFO: ngram_model_trie.c(195): #1-grams: 25
                    INFO: ngram_model_trie.c(195): #2-grams: 46
                    INFO: ngram_model_trie.c(195): #3-grams: 23
                    INFO: lm_trie.c(474): Training quantizer
                    INFO: lm_trie.c(482): Building LM trie
                    INFO: ngram_search_fwdtree.c(74): Initializing search tree
                    INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                    INFO: ngram_search_fwdtree.c(186): Creating search channels
                    INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                    INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                    INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                    INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41
                    Error opening audio device plughw:1,0 for capture: Invalid argument
                    FATAL: “continuous.c”, line 245: Failed to open audio device
                      I don’t know…
                      i would open an issue on the MMM-voice github repo, with the log file and ask for help .
                        @sdetweil done, thank you for all of your help, I appreciate you taking time out of your day to troubleshoot this with me, you’ve helped me with a ton of stuff and i really appreciate it.
                          @jmartin1009 glad I could help… sorry we couldn’t push it over the line
                            @sdetweil no worries! i wish i just could have found a voice control program that didn’t cause me to rip my hair out and give up and try another one by now haha i’ve tried a bunch and they always seem to fail for me.
                              @jmartin1009 just one more thing… after u installed MMM-voice, did u run the module/installers/dependencies.sh?
                              Installation
                              Clone this repo into ~/MagicMirror/modules directory.
                              Run command bash dependencies.sh in ~/MagicMirror/modules/MMM-voice/installers directory, to install all dependencies. This will need a couple of minutes.
                                @sdetweil i thought i did, but i’ll do it again just to be safe, if that won’t mess up anything
                                  @jmartin1009 shouldnt
                                    @sdetweil its installing pocketsphinx again so i wonder if it will change the file we changed with the paths and the plughw and stuff
                                      @sdetweil same thing in the debug log, so hopefully i’ll get an answer on github, thanks for the help! If you discover anything else or have any other ideas i’ll give them a shot tomorrow, otherwise don’t sweat it. Thanks!
                                        @jmartin1009 run this to see if all required libs loaded
                                        ldd /usr/local/bin/pocketsphinx_continuous
                                          @jmartin1009 did u make any progress ?
                                          • 4 / 5
