    Creating Module with API Key/Secret
    15 Posts 4 Posters 6.1k Views 4 Watching
    • L Offline
      lilpkstud Module Developer
      I read the “Head first developing MM module for extreme beginners” but I am still confused how I can configure it.
      I want to create a MM-Yelp
      I created my app on Yelp Fusion and I have an api_key and secret. Where do I store this api_key? My main.js or into my node_helper.js?
      Sorry, I am a total beginner with JS
      S lavolp3L 3 Replies Last reply Reply Quote 0
        sdetweil @lilpkstud
        @lilpkstud U put the default config in the module. If the helper needs it, the module sends it down
        See my Sample module.
        https://github.com/sdetweil/SampleModule
        • lavolp3L Offline
          lavolp3 Module Developer @lilpkstud
          @lilpkstud said in Creating Module with API Key/Secret:
          Neither nor.
          You would create a string variable for both in the module defaults.
          THen in config.js which is only present on your device and not shared via github or else, you can overwrite the empty variable with your api_key and secret.
          There are loads of examples, a few coming to my mind are MMM-Strava or MMM-DarkSkyForecast (or nearly any other weather app.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • lavolp3L Offline
            @lilpkstud Taking MMM-Strava as an example:
            MMM-Strava.js (the main js file)
            Module.register("MMM-Strava", {
                // Default module config.
                defaults: {
                    client_id: "",
                    client_secret: "",
                    period: "recent",
            config.js:
                    //disabled: true,
                    module: 'MMM-Strava',
                    position: 'center',
                        client_id: "my_id",
                        client_secret: "hereisthesecrethidden",
            • L Offline
              @lavolp3 Thanks for the example I will look into it more
              However, is there a way to put my request token inside of the request header?
              • lavolp3L Offline
                @lilpkstud
                Well, you can call any variable from your config/defaults using the reference this.config.variable.
                Or this.config.requestToken respectively.
                Something important to remember:
                Sometimes, e.g. when you use a callback function, note that the this reference may change (better: the context changes).
                Therefore you will often see something like this in the module codes early in a function:
                self = this
                And later on in the callback function
                self.config.requestToken
                Here, the “this” instance that is bound to its context, gives it’s properties to the global variable “self” that can then be used in any context (because it is global).
                For (much) more information check out https://scotch.io/@alZami/understanding-this-in-javascript
                • L Offline
                  Having trouble displaying the information that I received from Yelp API
                   getDom: function() {
                          var self = this;
                          //If this.dataRequest is not empty
                          if(this.data && this.data.length > 0){
                              console.log("MMM-Test: This.data is set" + this.data);
                              //Name of Business
                              var wrapperDataRequest = document.createElement("h1");
                              wrapperDataRequest.innerHTML = this.data;
                              wrapperDataRequest.className = 'yelpBusinessName';
                              wrapper.appendChild(imgDataRequest);
                              wrapper.appendChild(wrapperDataRequest);
                          } else {
                              console.log("MMM-Test: this.data couldn't be found");
                              wrapper.innerHTML = "This didn't work";
                          return wrapper;
                  MMM-Test: This.data is set{"id":"E8RJkjfdcwgtyoPMjQ_Olg","alias":"four-barrel-coffee-san-francisco","name":"Four Barrel Coffee","image_url":"https://s3-media1.fl.yelpcdn.com/bphoto/-_Ks4eF8aZcm3GZgUf5Urg/o.jpg","is_closed":false,"url":"https://www.yelp.com/biz/four-barrel-coffee-san-francisco?adjust_creative=joufChkTQP-Ru-G_5cRrMA&utm_campaign=yelp_api_v3&utm_medium=api_v3_business_search&utm_source=joufChkTQP-Ru-G_5cRrMA","review_count":2069,"categories":[{"alias":"coffee","title":"Coffee & Tea"}],"rating":4,"coordinates":{"latitude":37.7670169511878,"longitude":-122.42184275},"transactions":[],"price":"$","location":{"address1":"375 Valencia St","address2":"","address3":"","city":"San Francisco","zip_code":"94103","country":"US","state":"CA","display_address":["375 Valencia St","San Francisco, CA 94103"]},"phone":"+14158964289","display_phone":"(415) 896-4289","distance":1452.8696502343696}
                  How can I display name?
                  I tried this.data[0].name or this.data.name but no luck
                  • lavolp3L Offline
                    @lilpkstud this.data is an object, not an array. So this.data.name should do the trick. In the code above you have only this.data!?
                    • L Offline
                      lilpkstud Module Developer @lavolp3
                      @lavolp3 I deleted this.data.name because I was getting undefined and I still am
                      • L Offline
                        @lavolp3
                        This line of code will show a { on my mirror so I’m assuming everything is turned into a string?
                        I used JSON.stringify() in my node_helper file
                                    wrapperDataRequest.innerHTML = this.data[0];
